Supercharger compatibility list
tkarner
I'm trying to put together a list of games that are compatiblie with
an unmodified Supercharger.
Step one: Only games that are 2k or 4k. Easy.
Step two: This is the hard part. I could just try to load all the 2k and
4k games and see which crash and which don't. Problem with that
is that would take much too long. And even if I had the time/patience
to do it that way it wouldn't be definitive. Many games load fine but
don't crash until later in the game. The only way to be 100% sure
would be to play every game to completion. Not practical.
So I thought I might be able to tell by looking at the code.
After doing some research I learned that games that use
memory address $FFF8, the bank switching address, crash
on the Supercharger. So I thought I might write a couple
of scripts that would disassemble all the game BIN files,
then search the source code for "$FFF8". Easy enough,
ten minutes to write the scripts and a few moments to
run them. But first I decided to try this theory on a couple
games that are known to crash on the Supercharger,
Pac Man and Demon Attack. I disassembled them and
searched for $FFF8 and the search came up negative.
No sign of $FFF8. Yet the games still crash. There must
be something else causing them to crash. Any ideas from
the programmers out there? Is there another address I
should be looking for? Is my approach too simplistic?
Was I naive to think a simple text search for an offending
memory address would yield the results I'm looking for?
Thomas
The game could access that area without ever having an $FFF8 in ROM through indexing, indirect addressing, code executing in RAM, executing code there, etc. Games that WILL work may have all zeros in that area, but that's still no guarantee it will work.
I think you can actually prove that it's impossible to write a program to determine if the program accesses that location (automata theory). But you might be able to write a program that makes a good educated guess if you disassemble and research some games that do and do not work. It will take a lot more than a search for $FFF8 though.
-Paul
Yes, and there are also $1FF8, $3ff8, $5FF8...
And even games that have $xFF8 code inside might work:
ldx #2
.loop:
lda $FFF8,x
dex
bne .loop
So, IMO it's nearly impossible to automatically generate a list.
Hacking those games who are known to crash shoud be possible (and has been done before) but doing the mod is the easiest way for sure.
Thanks for all the insight. So a simple text search is out of
the question.
Off the Atari topic but it sounds like a job for FormalCheck.
That's a chip verification tool we developed while I worked
at Bell Labs. It checked the logic of VHDL and Verilog designs
with 100% state coverage. There was talk of applying it to software
verification but that never happened as far as I know. Sounds
like a good PhD thesis, any grad students out there looking
for a project?
Someone said it would be easier to just mod my Supercharger.
Maybe you're right but I was always better with a keyboard than
a soldering iron so that's why I went in that direction. I'm sure I'm
not alone. Lots of people are afraid to risk the most prized
item in their Atari collection. I wanted to make a CD for myself,
kind of like Worship the Woodgrain, but containing only games that
work on unmodified Superchargers. Now that I think about it, why
limit it to just myself? Would anyone else be interested in such
a CD? (Though I still don't have a guaranteed way of identifying
which games would work).
Thomas
Actually, this is on my todo list - To check and modify all 2K and 4K games to work on the Supercharger (Like Thomas' Pal2NTSC hacks).
I think I got through testing up to the letter "B" before getting distracted by other things. (Yeh, the letter "B" - Damn you ADD!)
It's a bit tedious...
Chris...
Yep, here it is:
Legend
Crashes or otherwise does not function correctly
Starts up but not thoroughly tested
Tested thoroughly
Modified to work on Supercharger
3-D Tic-Tac-Toe (1978) (Atari)
Action Force - Action Man (Parker Bros)
Adventure (1978) (Atari)
Adventures of Tron (Mattel)
Air Raid (PAL)
Air Raiders (Mattel) (1982) [!]
Airlock (Data Age)
Air-Sea Battle (1977) (Atari)
Alien (20th Century Fox)
Alien (CCE)
Alien Invaders Plus
Aligator People (20th Century Fox) (Prototype)
Amidar (Parker Bros)
Apples and Dolls (CCE)
Armor Ambush (Mattel) (1982) [!]
Assault (Bomb)
Astroblast (1982) (Mattel) [!]
Astroblast (1982) (Mattel) [a]
Astrowar (Starsoft)
Atari Video Cube (Atari)
Atlantis (Activision) [a]
Atlantis (CCE)
Atlantis (Imagic) [!]
Bachelor Party (Mystique)
Bachelorette Party (Playaround)
Backgammon (1978) (Atari)
Bank Heist (CCE)
Barnstorming (Activision) [!]
Barnstorming (CCE)
Basic Programming (1978) (Atari)
Basketball (1978) (Atari)
Beany Bopper (20th Century Fox)
Beany Bopper (CCE)
Beast Invaders (double shot hack)
Beat 'Em and Eat 'Em (Mystique) [!]
Bermuda Triangle (Data Age)
Berzerk (Atari)
Berzerk (CCE)
Better Space Invaders (1999) (Rob Kudla) [!]
Blackjack (1977) (Atari) [!]
Bobby is Going Home (CCE)(PAL)
Bogey Blaster (Telegames) [a]
Boom Bang (Cooper Black)
Bowling (1978) (Atari)
Boxing (Activision) [!]
Brain Games (Atari)
Chris, maybe we can collaborate. I did the same testing one
rainy sunday and got a bit further than you. I think I got
through the P's. I can send you my list when I get home
tonight.
There also seems to be one more category of Supercharger
games. They load but the vertical hold is messed up. I only have
a modern TV without a manual vertical hold adjustment.
I wonder if these games would otherwise work if displayed
on an old TV and manually adjusted?
> Alien Invaders Plus
Well, no surprise there. That's an Odyssey2 game!
Thomas
If you have a copy of "Worship the Woodgrain" (http://home.earthlink.net/~resqsoft/wtw.htm), it list all the games that are playable on an un-modified Supercharger. As you folks are finding out, it wasn't a trivial task. :)
It takes very little effort to modify a Supercharger. That would be the way to go IMHO.
-Lee
I heard about the compatibility list on the Worship the Woodgrain CD.
But I read in an older thread that it isn't very accurate. I don't know
first hand but I read that it basically lists all games that load on an
unmodified Supercharger but they weren't tested beyond that. Many
games will load but crash further into the game, yet they'd be listed
as compatible. Gorf, for example, plays the first two levels fine
but crashes at the third level. So you see, there's really no way
of telling which games will work unless you play them.
I guess I'll just brush up on my soldering skills and modify my
Supercharger. It's just that I have the less common Arcadia
branded model. Don't really want to wreck that one. Maybe I can
find a Starpath model cheap somewhere for this project.
  • 2 months later...
I have been using an unmodified supercharger with an mp3 player for a while now, I have gradually whittled down the list of compatible games, there might be 1 or 2 that may crash well into gameplay (if you find any let me know)
Currently the list is at 214, I have removed different named duplicates ie combat=tank plus
It would be easy to remove some of the lamer games to make a 2 disk set ala "Worship The Woodgrain Lite"
3-D Tic-Tac-Toe (1978) (Atari).mp3
Adventure (1978) (Atari).mp3
Adventures of Tron (1983) (Mattel).mp3
Air Raid (MenAvision).mp3
Air Raiders (1982) (Mattel) [!].mp3
Airlock (1982) (Data Age).mp3
Alien (1982) (20th Century Fox).mp3
Arcade Golf (1979) (Sears).mp3
Armor Ambush (1982) (Mattel) [!].mp3
Assault (Bomb).mp3
Astroblast (1982) (Mattel) [a1].mp3
Astrowar (Starsoft).mp3
Backgammon (1978) (Atari).mp3
Barnstorming (1982) (Activision) [!].mp3
Basketball (1978) (Atari).mp3
Bermuda Triangle (1982) (Data Age) [!].mp3
Berzerk (1982) (Atari).mp3
Bowling (1978) (Atari) [!].mp3
Boxing (1981) (Activision) [!].mp3
Brick Kick (RJPG).mp3
Cakewalk (CommaVid).mp3
Canyon Bomber (1978) (Atari).mp3
Carnival (1982) (Coleco).mp3
Challenge (Zellers).mp3
Challenge of NEXAR (1982) (Spectravideo).mp3
Championship Soccer (AKA Pele's Soccer).mp3
Chase the Chuckwagon (1983) (Spectravideo).mp3
Checkers (1980) (Activision).mp3
China Syndrome (1982) (Spectravideo).mp3
Circus Atari (1978) (Atari) (Paddles).mp3
Coconuts (1982) (Telesys).mp3
Col 'N (HomeVision).mp3
Combat (1977) (Atari) [!].mp3
Commando Raid (1982) (US Games).mp3
Communist Mutants From Space (1982) (Starpath).mp3
Communist Mutants From Space (Preview) (1982) (Starpath).mp3
Computer Chess (1983) (Atari) (Prototype).mp3
Concentration (1978) (Atari).mp3
Condor Attack (CCE).mp3
Cosmic Commuter (1984) (Activision) [!].mp3
Cosmic Corridor (Zimag).mp3
Cosmic Swarm (1982) (CommaVid) [a1].mp3
Cruise Missile (1982) (Froggo).mp3
Cubicolor (Rob Fulop).mp3
Death Trap (1983) (Avalon Hill).mp3
Defender (1981) (Atari).mp3
Demons to Diamonds (1982).mp3
Dodge 'em (1980) (Atari).mp3
Dolphin (1983) (Activision) [!].mp3
Dragonfire (1982) (Imagic).mp3
Dragonstomper (1 of 3) (1982) (Starpath).mp3
Dragonstomper (2 of 3) (1982) (Starpath).mp3
Dragonstomper (3 of 3) (1982) (Starpath).mp3
Dragonstomper (Preview) (1982) (Starpath).mp3
Dragster (1980) (Activision) [!].mp3
Dukes of Hazzard V2 (Atari) (Prototype) [!].mp3
Earth Dies Screaming (1983) (20th Century Fox).mp3
Eggomania (1982) (US Games).mp3
Eli's Ladder (Simage).mp3
Encounter at L5 (1982) (Data Age).mp3
Enduro (1983) (Activision).mp3
Entombed (1982) (US Games) [!].mp3
Escape from the Mindmaster (1 of 4) (1982) (Starpath).mp3
Escape from the Mindmaster (2 of 4) (1982) (Starpath).mp3
Escape from the Mindmaster (3 of 4) (1982) (Starpath).mp3
Escape from the Mindmaster (4 of 4) (1982) (Starpath).mp3
Escape from the Mindmaster (Preview) (1982) (Starpath).mp3
Fantastic Voyage (1982) (20th Century Fox) [!].mp3
Fast Eddie (1982) (20th Century Fox) [!].mp3
Fast Food (1982) (Telesys).mp3
Final Approach (1982) (Apollo).mp3
Fire Fighter (1982) (Imagic).mp3
Fireball (1982) (Starpath).mp3
Fireball (Preview) (1982) (Starpath).mp3
Fishing Derby (1980) (Activision) [!].mp3
Flag Capture (1978) (Atari).mp3
Football (1978) (Atari).mp3
Frankenstein's Monster (1983) (Data Age).mp3
Freeway (1981) (Activision) [!].mp3
Frogger (1982) (Parker Bros).mp3
Frogger (Official version by Sega) (1982) (Starpath).mp3
Frogs and Flies (1982) (Mattel) [!].mp3
Frostbite (1983) (Activision).mp3
Fun with Numbers (1977) (Atari).mp3
Gangster Alley (1982) (Spectravision).mp3
Gauntlet (1983) (Answer Software).mp3
Ghost Manor (1983) (Xonox).mp3
Glacier Patrol (Telegames).mp3
Glib (1983) (Selchow & Righter).mp3
Guardian (1982) (Apollo).mp3
Halloween (AKA Sexta Fiera 13) (Wizard Video) [!].mp3
Hangman (1978) (Atari).mp3
Home Run Baseball (1978).mp3
Human Cannonball (AKA Cannon Man) (1978) (Atari).mp3
I Want My Mommy (AKA Ursinho Esperto) (Zimag).mp3
Immies & Aggies (CCE).mp3
Indy 500 (1978) (Atari) [!].mp3
Inv (V21) (Hozer).mp3
IQ 180 (Homevision).mp3
Kaboom! (1981) (Activision) [!].mp3
Kamikaze Saucers.mp3
Karate (1982) (Froggo).mp3
Killer Satellites (1982) (Starpath) (Preview).mp3
Killer Satellites (1982) (Starpath).mp3
King Kong (1982) (Tigervision).mp3
Laser Blast (1981) (Activision) [!].mp3
Laser Gates (1983) (CCE).mp3
Lochjaw (1982) (Apollo).mp3
Lock 'N' Chase (1982) (Mattel) [!].mp3
Lost Luggage (1981) (Apollo) [a1].mp3
Malagai (1983) (Answer Software).mp3
Marine Wars (1983) (Konami) [!].mp3
Math Gran Prix (1982) (Atari).mp3
Maze (1978) (Sears).mp3
Mega Force (1982) (20th Century Fox).mp3
Missile Command (1981) (Atari) [!].mp3
Music Machine (1983) (Sparrow).mp3
Night Driver (1978) (Atari).mp3
Off Your Rocker (1983) (Amiga).mp3
Okie Dokie (Older) (PD).mp3
Othello (1978) [p1].mp3
Outlaw - GunSlinger (1978) (Atari).mp3
Oystron (V29).mp3
Party Mix (1 of 3) (1982) (Starpath).mp3
Party Mix (2 of 3) (1982) (Starpath).mp3
Party Mix (3 of 3) (1982) (Starpath).mp3
Party Mix (Preview) (1982) (Starpath).mp3
Pepsi Invaders (Atari) (Prototype).mp3
Phaser Patrol (1982) (Starpath).mp3
Picnic (1982) (US Games).mp3
Piece o' Cake (1982) (US Games).mp3
Pitfall! (1982) (Activision) [!].mp3
Planet Patrol (1982) (Spectravision).mp3
Plaque Attack (1983) (Activision) [!].mp3
Poker Plus (1978) (Sears).mp3
Polo (Atari) (Prototype) [!].mp3
Qb (XYPE) (2001).mp3
Quick Step! (1983) (Imagic).mp3
Rabbit Transit (1982) (Starpath).mp3
Rabbit Transit (Preview) (1982) (Starpath).mp3
RealSports Volleyball (1982) (Atari).mp3
Rescue Terra I (1982) (Venture Vision).mp3
Revenge of the Beefsteak Tomatoes (1983) (20th Century Fox) [!].mp3
Save Our Ship (Technovision).mp3
SCSIcide 130-cge2k1 (Joe Grand).mp3
SCSIcide 132-Final (Joe Grand).mp3
Sea Hawk (1987) (Froggo).mp3
Shark Attack (1982) (Apollo).mp3
Skeet Shoot (1981) (Apollo).mp3
Skeleton (2002) (Eric Ball).mp3
Skeleton Plus (2003) (Eric Ball).mp3
Skiing (1980) (Activision) [!].mp3
Sky Diver (1978) (Atari).mp3
Sky Jinks (1982) (Activision) [!].mp3
Slot Machine (1979) (Atari).mp3
Sneek 'n Peek (1982) (CCE).mp3
Solar Storm (1983) (Imagic).mp3
Space Attack (1982) (Mattel).mp3
Space Canyon (Panda).mp3
Space Cavern (1981) (Apollo) [!].mp3
Space Invaders (1978) (Atari).mp3
Space Jockey (1982) (US Games) [!].mp3
Space Treat Deluxe (2003) (Fabrizio Zavagli).mp3
Space War (1978) (Atari).mp3
Spacechase (1981) (Apollo) [!].mp3
Spider Maze (K-Tel Vision).mp3
Squeeze Box (1982) (US Games) [!].mp3
Squoosh (Apollo) (Prototype).mp3
Sssnake (1982) (Data Age).mp3
Stampede (1981) (Activision) [!].mp3
Star Ship - Outer Space (1977).mp3
Starmaster (1982) (Activision).mp3
Steeplechase (1980) (Sears).mp3
Strawberry Shortcake - Musical Match-Ups (1983) (Parker Bros).mp3
Street Racer - Speedway II (1978) (Atari).mp3
Stunt Cycle (Atari) (Prototype).mp3
Sub Scan (1983) (Sega).mp3
Submarine Commander (1982) (Sears).mp3
Suicide Mission (1982) (Starpath).mp3
Suicide Mission (Preview) (1982) (Starpath).mp3
Super Breakout (1978) (Atari).mp3
Super Ferrari (Quelle).mp3
Surround (1978) (Atari).mp3
Survival Island (1 of 3) (1983) (Starpath).mp3
Survival Island (2 of 3) (1983) (Starpath).mp3
Survival Island (3 of 3) (1983) (Starpath).mp3
Sweat! - The Decathalon Game (1 of 2) (1982) (Starpath) (Prototype).mp3
Sweat! - The Decathalon Game (2 of 2) (1982) (Starpath) (Prototype).mp3
Sword of Saros (1983) (Starpath).mp3
Tanks But No Tanks (Zimag).mp3
Task Force (1987) (Froggo).mp3
Tennis (1981) (Activision) [!].mp3
This Planet Sucks (Greg Troutman).mp3
Threshold (1982) (Tigervision).mp3
Turmoil (1982) (20th Century Fox).mp3
UFO Patrol.mp3
Vault Assault (2001) (Brian Prescott).mp3
Video Checkers (1978) (Atari).mp3
Video Chess (1978) (Atari).mp3
Video Simon (Mark De Smet).mp3
Wabbit (1982) (Apollo).mp3
Wall Ball (1983) (Avalon Hill).mp3
Wall Defender (Bomb).mp3
Warlords (1981) (Atari).mp3
Warplock (1982) (Data Age).mp3
Warring Worms (2002) (Billy Eno).mp3
Wizard [o1].mp3
Wizard of Wor (1982) (CBS Electronics).mp3
Word Zapper (1982) (US Games) [!].mp3
Worm War I (1982) (20th Century Fox).mp3
Yahtzee (Hozer Video Games).mp3
Yar's Revenge (1981) (Atari).mp3
Zoo Fun (HomeVision).mp3
Z-Tack (Bomb).mp3
Dave
Thanks Thomas, I guess if I had read your earlier post I would have
caught that one.
I remember reading a post, I think by you that you had hacked some
games(Choplifter) to work with unmodded supercharger, would I be
correct in assuming that these are PAL only?
Dave
I remember reading a post, I think by you that you had hacked some games(Choplifter) to work with unmodded supercharger, would I be correct in assuming that these are PAL only?
Hm, I can't remember that.
But I am sure it's way easier to modify a SC than to find, modify and test all non working games. :)
Dave
I got a question. How do you convert Bin files to Mp3 files? And would I need special software to do it or just what comes with windows (if you used that?)
Any help would be appreciated.
I used Bob Colberts Makewav http://members.cox.net/rcolbert/index.htm
to convert them to wav, make sure you use the options -ts -h2
-ts = type-supercharger
-h2 = 2 second header, I found this helps for use on mp3 players
I then converted the wavs to mp3, I used Lame but I'm sure most any
encoder will work fine, use at least 192 kbps
my mp3 player, an old ravemp 2100 will handle 255 tracks
I understand some other players can not handle that many, I'm sure
some of the newer ones can handle more
Good Luck
Dave
  • 1 year later...
to convert them to wav' date=' make sure you use the options -ts -h2
Good Luck
Dave[/quote']
This thread was referenced in another SC thread, so I'm asking here...
Whenever I try to make Mp3's out of WAV's, the SC doesn't load them. I've used 192Kb sampling, and all that happens is that I usually get the first two tones of the load and then "rewind tape."
Suggestions?
If your computer is nearby you can use this:http://members.cox.net/rcolbert/wplaybin.htm
Nope. Mac user. :D Besides, the computer and Atari's are all in different rooms (and indeed, on different floors, no less).
I disassembled them and searched for $FFF8 and the search came up negative. No sign of $FFF8. Yet the games still crash. There must be something else causing them to crash.
You didn't look closely enough. Look at this section...
LFFB2: LSR          ;2
      LSR          ;2
      LSR          ;2
      AND    #$07  ;2
      TAX          ;2
      CPX    #$04  ;2
      BPL    LFFE8  ;2
      LDA    LFFF1,X;4
      STA    AUDF0  ;3
      LDA    LFFF5,X;4 <- this instruction
      STA    AUDF1  ;3
...and here is that table being read...
LFFF5:
      .byte $14; |   X X  | $FFF5
      .byte $18; |   XX   | $FFF6
      .byte $14; |   X X  | $FFF7
      .byte $18; |   XX   | $FFF8
So what happens is that X is allowed to be 3 (it's only caught if X=4 or higher...see that CPX instruction)...and then that register is used to index a table at $FFF5. $FFF5+3 = $FFF8...the program tries reading that address and the Supercharger bankswitches the game (crashing it).
An easy way to fix it is to edit the first 4 bytes of the B&W info and have the program read from there instead...
LFFB2: LSR          ;2
      LSR          ;2
      LSR          ;2
      AND    #$07  ;2
      TAX          ;2
      CPX    #$04  ;2
      BPL    LFFE8  ;2
      LDA    LFFF1,X;4
      STA    AUDF0  ;3
      LDA    LFF36,X;4 <- this instruction
      STA    AUDF1  ;3
...and change this...
       .byte $0E; |    XXX | $FF36
      .byte $0E; |    XXX | $FF37
      .byte $0E; |    XXX | $FF38
      .byte $0E; |    XXX | $FF39
...to this...
LFF36: .byte $14; |   X X  | $FF36
      .byte $18; |   XX   | $FF37
      .byte $14; |   X X  | $FF38
      .byte $18; |   XX   | $FF39
EDIT: question on Page 2 regarding BOING! answered...an animation table runs over the SC hotspots.
LFFF4:
   .byte $9C; |X  XXX  | $FFF4
   .byte $A6; |X X  XX | $FFF5
   .byte $B0; |X XX	| $FFF6
   .byte $BA; |X XXX X | $FFF7
   .byte $C5; |XX   X X| $FFF8
   .byte $D0; |XX X	| $FFF9
   .byte $DA; |XX XX X | $FFFA
   .byte $00; |		| $FFFB
Edited by Nukey Shay
