Gury Posted January 12, 2020 Share Posted January 12, 2020 Ditto! Using right tool we can do right things Quote Link to comment Share on other sites More sharing options...
Gury Posted January 16, 2020 Share Posted January 16, 2020 Ok, I figured it out. I went through Mad Pascal examples code which uses memory address above $a000. Of course, programs work well and you can use this area freely, but BASIC must be switched off manually for proper operation. I am talking about code read from resource files at program startup (images, text, music...). If you leave BASIC on (not pressing Option when starting real machine or emulator), garbage appears on the screen (collading with previous data on $a000 area). We know all of that, but anyway... The example is PacMad, you can try it and you will know what I am talking about. I can provide additional code in my program to automatically turn BASIC off and I can use this area freely, but the problem with reading resource files will remain. The whole point is that it is not that easy to do that on the first glance in high language (not assembler). It is easy to say "The program must take care of automatically switching BASIC off!". In practice things can become more complicated than that. Most other machines didn't have to cope with this problem at all. Quote Link to comment Share on other sites More sharing options...
tebe Posted January 17, 2020 Author Share Posted January 17, 2020 (edited) On 12/20/2015 at 10:53 PM, ilmenit said: I have fixed the C code to be less Pascal-like (using unsinged char for boolean, memset for fillchar, register for indexes etc.). With an older version of cc65 (2.13.3) and optimizations turned on: cl65 -l -o sieve.c.xex -t atari -Osir -Cl --add-source sieve.c I receive: C - 608 ticks vs Mads Pascal - 1474 ticks For 0...255 to compare with Action! it's 14 ticks. The code, xex and asm output attached. sieve-c.zip 6.18 kB · 242 downloads C - 608 ticks (optimizations turned on) C - 856 ticks (optimizations turned off) Mad Pascal - 670 ticks (variables on ZEROPAGE, $DEFINE FAST) Mad Pascal - 752 ticks (standard) bench_sieve.zip Edited January 17, 2020 by tebe 1 Quote Link to comment Share on other sites More sharing options...
ilmenit Posted January 17, 2020 Share Posted January 17, 2020 (edited) 2 hours ago, tebe said: C - 608 ticks (optimizations turned on) C - 856 ticks (optimizations turned off) Mad Pascal - 670 ticks (variables on ZEROPAGE, $DEFINE FAST) Mad Pascal - 752 ticks (standard) Compiled with the newest CC65 - 602 ticks. sieve-cc65 v2.18.7z Edited January 17, 2020 by ilmenit 1 Quote Link to comment Share on other sites More sharing options...
zbyti Posted February 25, 2020 Share Posted February 25, 2020 (edited) Here are my tests on atari800 PAL :] Sources mostly included Programming languages in the latest official version for February 20, 2020. CC65 YoshPlus: 41844 iterations in 100 ticks Mad Pascal YoshPlus: 35572 iterations in 100 ticks Action! YoshPlus: 33239 iterations in 100 ticks Quick 2.2 YoshPlus: 21320 iterations in 100 ticks Quick 1.6 YoshPlus: 16242 iterations in 100 ticks PL65 YoshPlus: 4708 iterations in 100 ticks FastBasic FBI YoshPlus: 2427 iterations in 100 ticks fig-Forth 1.1 YoshPlus: 715 iterations in 100 ticks CLSN Pascal YoshPlus: 487 iterations in 100 ticks CC65 Chessboard: 76 iterations in 150 ticks Mad Pascal Chessboard: 40 iterations in 150 ticks Action! Chessboard: 35 iterations in 150 ticks Quick 2.2 Chessboard: 27 iterations in 150 ticks Quick 1.6 Chessboard: 16 iterations in 150 ticks PL65 Chessboard: 12 iterations in 150 ticks MADS (opt) SIEVE: 440 ticks in 10 iterations CC65 (opt) SIEVE: 602 ticks in 10 iterations Mad Pascal (opt) SIEVE: 644 ticks in 10 iterations Mad Pascal SIEVE: 739 ticks in 10 iterations Action! SIEVE: 1003 ticks in 10 iterations Advan BASIC (opt) SIEVE: 1050 ticks in 10 iterations Quick 1.6 SIEVE: 2022 ticks in 10 iterations Quick 2.2 SIEVE: 2199 ticks in 10 iterations PL65 SIEVE: 3853 ticks in 10 iterations FastBasic FBI SIEVE: 6312 ticks in 10 iterations Advan BASIC SIEVE: 6800 ticks in 10 iterations fig-Forth 1.1 SIEVE: 8482 ticks in 10 iterations Turbo-BASIC XL [C] SIEVE: 16880 ticks in 10 iterations Turbo-BASIC XL SIEVE: 46060 ticks in 10 iterations BASIC SIEVE: 133960 ticks in 10 iterations A8-Benchmarks.zip Edited February 26, 2020 by zbyti correct package 3 Quote Link to comment Share on other sites More sharing options...
zbyti Posted February 26, 2020 Share Posted February 26, 2020 (edited) Proper (REAL) SIEVE Benchmark // Eratosthenes Sieve Benchmark uses crt; {$define FAST} const size = 8191; sqr_count = 91; var flags: array [0..size] of boolean; rtClock: byte absolute $14; {$ifdef FAST} n: word absolute $e0; k: word absolute $e2; count: word absolute $e6; {$else} n, k, count: word; {$endif} begin writeln('Mad Pascal'); writeln('Eratosthenes Sieve Benchmark'); rtClock := 0; fillchar(flags, sizeof(flags), true); for n := 2 to sqr_count do begin if flags[n] then begin k := n shl 1; while k <= size do begin flags[k] := false; Inc(k,n); end; end; end; writeln(rtClock, ' ticks'); count :=0; for n := 2 to size do begin if flags[n] then Inc(count); end; writeln(count, ' primes'); repeat until keypressed; end. RTCLOCK@20:byte const SQRT_COUNT = 91 top:0..8191 sieve:array(top) of 0..1 k,j,prime:top start,time:byte "Atalan computing primes..." for k sieve(k) = 1 RTCLOCK = 0 for i:2..SQRT_COUNT where sieve(i) = 1 j = i * 2 while j<=8191 sieve(j) = 0 j = j + i time = RTCLOCK "Time used: [time] ticks" "Press Q to quit, any other key for list" CH = none until CH <> none for k where sieve(k) = 1 until CH = Q "[k]" CH = none Edited February 26, 2020 by zbyti add Atalan proper sieve code Quote Link to comment Share on other sites More sharing options...
dmsc Posted February 26, 2020 Share Posted February 26, 2020 Hi! 33 minutes ago, zbyti said: Proper SIEVE Benchmark // Eratosthenes Sieve Benchmark uses crt; {$define FAST} const size = 8191; sqr_count = 91; var flags: array [0..size] of boolean; rtClock: byte absolute $14; {$ifdef FAST} n: word absolute $e0; k: word absolute $e2; count: word absolute $e6; {$else} n, k, count: word; {$endif} begin writeln('Mad Pascal'); writeln('Eratosthenes Sieve Benchmark'); rtClock := 0; fillchar(flags, sizeof(flags), true); for n := 2 to sqr_count do begin Here you changed the code, using "sqr_count" as the upper limit instead of the full size is misleading, as all other programs do the complete loop. So, you results sadly are not comparable. Have Fun! Quote Link to comment Share on other sites More sharing options...
zbyti Posted February 26, 2020 Share Posted February 26, 2020 (edited) @dmsc https://rosettacode.org/wiki/Sieve_of_Eratosthenes look at this implementations and compare with proper result https://jalu.ch/coding/primes/list.php Fake SIEVE contains even numbers as result but sadly it's popular benchmark on Internet. All FAKE SIEVE in my test implements the same algorithm, they all are comparable. I simply start implement proper algorithm and I start call it REAL. Edited February 26, 2020 by zbyti add info Quote Link to comment Share on other sites More sharing options...
zbyti Posted February 26, 2020 Share Posted February 26, 2020 (edited) FAKE SIEVE // Fake Eratosthenes Sieve Benchmark uses crt, sysutils; {$define FAST} const size = 8191; var flags: array [0..size] of boolean; iter: byte; starttime: cardinal; {$ifdef FAST} i: word absolute $e0; k: word absolute $e2; prime: word absolute $e4; count: word absolute $e6; {$else} i, k, prime, count: word; {$endif} begin starttime := GetTickCount; fillchar(flags, sizeof(flags), true); i:=0; count := 0; while i <= size do begin if flags[i] then begin prime := i shl 1 + 3; k := prime + i; while (k <= size) do begin flags[k] := false; inc(k, prime); end; inc(count); end; inc(i); end; writeln(count, ' primes'); writeln(GetTickCount - starttime, ' ticks'); count := 0; for i := 3 to size do begin if flags[i] then begin if (i mod 2) = 0 then begin inc(count) end; end; end; writeln(count, ' even numbers'); readkey; end. Edited February 26, 2020 by zbyti Quote Link to comment Share on other sites More sharing options...
zbyti Posted February 26, 2020 Share Posted February 26, 2020 Quote Link to comment Share on other sites More sharing options...
thorfdbg Posted February 26, 2020 Share Posted February 26, 2020 On 2/25/2020 at 11:17 AM, zbyti said: Here are my tests on atari800 PAL :] Sources mostly included Programming languages in the latest official version for February 20, 2020. CC65 YoshPlus: 41844 iterations in 100 ticks Mad Pascal YoshPlus: 35572 iterations in 100 ticks Action! YoshPlus: 33239 iterations in 100 ticks Quick 2.2 YoshPlus: 21320 iterations in 100 ticks Quick 1.6 YoshPlus: 16242 iterations in 100 ticks PL65 YoshPlus: 4708 iterations in 100 ticks FastBasic FBI YoshPlus: 2427 iterations in 100 ticks fig-Forth 1.1 YoshPlus: 715 iterations in 100 ticks CLSN Pascal YoshPlus: 487 iterations in 100 ticks CC65 Chessboard: 76 iterations in 150 ticks Mad Pascal Chessboard: 40 iterations in 150 ticks Action! Chessboard: 35 iterations in 150 ticks Quick 2.2 Chessboard: 27 iterations in 150 ticks Quick 1.6 Chessboard: 16 iterations in 150 ticks PL65 Chessboard: 12 iterations in 150 ticks MADS (opt) SIEVE: 440 ticks in 10 iterations CC65 (opt) SIEVE: 602 ticks in 10 iterations Mad Pascal (opt) SIEVE: 644 ticks in 10 iterations Mad Pascal SIEVE: 739 ticks in 10 iterations Action! SIEVE: 1003 ticks in 10 iterations Advan BASIC (opt) SIEVE: 1050 ticks in 10 iterations Quick 1.6 SIEVE: 2022 ticks in 10 iterations Quick 2.2 SIEVE: 2199 ticks in 10 iterations PL65 SIEVE: 3853 ticks in 10 iterations FastBasic FBI SIEVE: 6312 ticks in 10 iterations Advan BASIC SIEVE: 6800 ticks in 10 iterations fig-Forth 1.1 SIEVE: 8482 ticks in 10 iterations Turbo-BASIC XL [C] SIEVE: 16880 ticks in 10 iterations Turbo-BASIC XL SIEVE: 46060 ticks in 10 iterations BASIC SIEVE: 133960 ticks in 10 iterations A8-Banchmarks.zip 90.68 kB · 3 downloads Basic++: 1899 prime in 7849 jiffies. This is faster than I thought. It is not ideal in Turbobasic since this still does a line search, although abbreviated, for each for-loop. Basic++ pushes the address to the stack. 1 Quote Link to comment Share on other sites More sharing options...
thorfdbg Posted February 26, 2020 Share Posted February 26, 2020 2 minutes ago, thorfdbg said: Basic++: 1899 prime in 7849 jiffies. This is faster than I thought. It is not ideal in Turbobasic since this still does a line search, although abbreviated, for each for-loop. Basic++ pushes the address to the stack. With "cheating", i.e. math pack patch as in "host does the computation", down to 5291 jiffies. Of course, that is then not a fair benchmark, but it given an impression of where the overhead of the basic interpreter is. Quote Link to comment Share on other sites More sharing options...
zbyti Posted February 26, 2020 Share Posted February 26, 2020 (edited) @thorfdbg Nice try. I will test it :] I reuploaded A8-Benchmarks.zip. Edited February 26, 2020 by zbyti Quote Link to comment Share on other sites More sharing options...
zbyti Posted February 26, 2020 Share Posted February 26, 2020 (edited) Basic++ 1.7 REAL Sieve :] How can I speed it up? Does this have a compiler? Edited February 26, 2020 by zbyti Quote Link to comment Share on other sites More sharing options...
thorfdbg Posted February 26, 2020 Share Posted February 26, 2020 3 minutes ago, zbyti said: Basic++ REAL Sieve :] How can I speed it up? Does this have a compiler? You better use it with Os++ because the Os++ math pack is also considerably faster. As far as a compiler is concerned - well, any Atari Basic compiler would do. I would suggest to try it with the ABC compiler, which should create a suitable fast binary. Quote Link to comment Share on other sites More sharing options...
thorfdbg Posted February 26, 2020 Share Posted February 26, 2020 9 minutes ago, thorfdbg said: You better use it with Os++ because the Os++ math pack is also considerably faster. As far as a compiler is concerned - well, any Atari Basic compiler would do. I would suggest to try it with the ABC compiler, which should create a suitable fast binary. Result for the ABC compiled code: 1899 primes in 2009 jiffies. Quote Link to comment Share on other sites More sharing options...
zbyti Posted February 26, 2020 Share Posted February 26, 2020 (edited) Thanks for the TIP. I stopped using the algorithm that returns 1899 primes because it is incorrect. The correct number of prime numbers in 8191 is 1028. Edited February 26, 2020 by zbyti Quote Link to comment Share on other sites More sharing options...
drac030 Posted February 26, 2020 Share Posted February 26, 2020 May I join this game for a moment? U-BASIC + Marslett's FP (default): U-BASIC + Atari FP (option): U-BASIC + Phaeron's FP (option): 4 Quote Link to comment Share on other sites More sharing options...
zbyti Posted February 27, 2020 Share Posted February 27, 2020 (edited) @drac030 THX :] Real Sieve Native FastBasic 4.0 FBI ? "STARTING FASTBASIC..." STIME = TIME DIM FLAGS(8190) BYTE MSET ADR(FLAGS), 8190,0 FOR N=2 TO 91 IF NOT FLAGS(N) FOR K=N*N TO 8190 STEP N FLAGS(K)=1 NEXT K ENDIF NEXT N ETIME = TIME ? "JIFFIES: ";ETIME-STIME COUNT=0 FOR N=2 TO 8191 IF NOT FLAGS(N) COUNT=COUNT+1 ENDIF NEXT N ? "PRIMES: ";COUNT gets: 335 ticks ./fastbasic-int RESIEVE.FBI fbisieve.asm cl65 -t atari -C fastbasic.cfg fbisieve.asm -o fbisieve.xex fastbasic-fp.lib gets: 314 ticks Edited February 27, 2020 by zbyti typo 1 Quote Link to comment Share on other sites More sharing options...
thorfdbg Posted February 27, 2020 Share Posted February 27, 2020 6 hours ago, zbyti said: @drac030 THX :] Real Sieve Native FastBasic 4.0 FBI ? "STARTING FASTBASIC..." STIME = TIME DIM FLAGS(8190) BYTE MSET ADR(FLAGS), 8190,0 FOR N=2 TO 91 IF NOT FLAGS(N) FOR K=N*N TO 8190 STEP N FLAGS(K)=1 NEXT K ENDIF NEXT N ETIME = TIME ? "JIFFIES: ";ETIME-STIME COUNT=0 FOR N=2 TO 8191 IF NOT FLAGS(N) COUNT=COUNT+1 ENDIF NEXT N ? "PRIMES: ";COUNT gets: 335 ticks ./fastbasic-int RESIEVE.FBI fbisieve.asm cl65 -t atari -C fastbasic.cfg fbisieve.asm -o fbisieve.xex fastbasic-fp.lib gets: 314 ticks Basic++, with Os++ gives me 3874 jiffies, 1028 primes. You are likely using the original Os, with the original (slow) mathpack. Quote Link to comment Share on other sites More sharing options...
thorfdbg Posted February 27, 2020 Share Posted February 27, 2020 Just now, thorfdbg said: Basic++, with Os++ gives me 3874 jiffies, 1028 primes. You are likely using the original Os, with the original (slow) mathpack. With the mathpack patch, it is down to 2726 jiffies. 1 Quote Link to comment Share on other sites More sharing options...
thorfdbg Posted February 27, 2020 Share Posted February 27, 2020 1 minute ago, thorfdbg said: Basic++, with Os++ gives me 3874 jiffies, 1028 primes. You are likely using the original Os, with the original (slow) mathpack. Actually, this is version 1.08, but this should not make much of a difference. Quote Link to comment Share on other sites More sharing options...
zbyti Posted February 27, 2020 Share Posted February 27, 2020 @thorfdbgThank you! I will complete the table with your results soon. Quote Link to comment Share on other sites More sharing options...
zbyti Posted February 27, 2020 Share Posted February 27, 2020 Millfork YoshPlus: 41921 iterations in 100 ticks CC65 YoshPlus: 41844 iterations in 100 ticks Mad Pascal YoshPlus: 35572 iterations in 100 ticks Action! YoshPlus: 33239 iterations in 100 ticks Quick 2.2 YoshPlus: 21320 iterations in 100 ticks Quick 1.6 YoshPlus: 16242 iterations in 100 ticks PL65 YoshPlus: 4708 iterations in 100 ticks FastBasic FBI YoshPlus: 2427 iterations in 100 ticks fig-Forth 1.1 YoshPlus: 715 iterations in 100 ticks CLSN Pascal YoshPlus: 487 iterations in 100 ticks Millfork Chessboard: 79 iterations in 150 ticks CC65 Chessboard: 76 iterations in 150 ticks Mad Pascal Chessboard: 40 iterations in 150 ticks Action! Chessboard: 35 iterations in 150 ticks Quick 2.2 Chessboard: 27 iterations in 150 ticks Quick 1.6 Chessboard: 16 iterations in 150 ticks PL65 Chessboard: 12 iterations in 150 ticks A8 SIEVE Benchmark.ods Quote Link to comment Share on other sites More sharing options...
zbyti Posted February 27, 2020 Share Posted February 27, 2020 (edited) With @xxl tips, Atari BASIC counts faster. @xxl claims that he can implement the same algorithm even faster but I have no idea how he does it You can omit even numbers but then it won't be the same benchmark any more. 10 POKE 20,0:POKE 19,0:COUNT=0 20 DIM F$(8192):F$="F":F$(8192)=F$:F$(2)=F$:X=ADR(F$) 30 FOR N=2 TO 91 40 IF PEEK(N+X)=1 THEN 80 50 FOR K=N*N TO 8190 STEP N:POKE K+X,1 70 NEXT K 80 NEXT N 90 TIME=PEEK(20)+256*PEEK(19) 100 ? TIME;" TICKS" 200 FOR N=2 TO 8191 210 IF PEEK(N+X)=70 THEN COUNT=COUNT+1 220 NEXT N 230 ? COUNT;" PRIMES" Edited February 27, 2020 by zbyti omit even numbers info Quote Link to comment Share on other sites More sharing options...
