morelenmir Posted July 29, 2015 Share Posted July 29, 2015 It seems the largest individual file that can be added to the SDX user area with "SDX Imager" is 8K. Some programmes that are larger than this are split between a small executable *.COM file and then several *.OVL files - FJC's excellent 'FDISK' is a good example. Is the process of creating these segmented files a generic one that can be applied to every executable or does the programme have to be written from scratch in such a way as to allow being physically broken up and then 'reassembled' at runtime? I ask because I would like to add the 'flash.com' for "The!Cart" images to the SDX rom which resides on the "Ultimate1MB". Unfortunately it comes in at 11kB and is therefore too large to insert in one piece. Quote Link to comment Share on other sites More sharing options...
drac030 Posted July 29, 2015 Share Posted July 29, 2015 An ordinary binary (of the $FFFF-type) can probably be broken into segments or such parts, then loaded/executed by a separate dedicated loader (or wrapper). In any case, such a loader should be prepared individually for the program, I doubt if the process can be fully automated. 2 Quote Link to comment Share on other sites More sharing options...
morelenmir Posted July 29, 2015 Author Share Posted July 29, 2015 An ordinary binary (of the $FFFF-type) can probably be broken into segments or such parts, then loaded/executed by a separate dedicated loader (or wrapper). In any case, such a loader should be prepared individually for the program, I doubt if the process can be fully automated. In my mind I can kind of see what would be required to do this, but I can also imagine how it would need to be done individually if that s the approach. But as you say there is no 'OVLMake' utility to do it for you. Incidentally, although it is only applicable to my own case it is worth mentioning that after speaking to the chap who makes 'The!Cart' it turns out the flasher is also resident on the cartridge itself at all times - so my idea was unnecessary anyway! Quote Link to comment Share on other sites More sharing options...
morelenmir Posted July 29, 2015 Author Share Posted July 29, 2015 An ordinary binary (of the $FFFF-type) can probably be broken into segments or such parts, then loaded/executed by a separate dedicated loader (or wrapper). In any case, such a loader should be prepared individually for the program, I doubt if the process can be fully automated. Incidentally - I have just downloaded and printed up the SDX 'Programming Guide'. It makes absolutely fascinating reading and opens many possibilities I was not previously aware of. Many, many thanks for putting it together. I recommend it to everyone who is interested in writing assembler for this environment, which these days forms pretty much the de facto D/OS of modern A8 machines. 1 Quote Link to comment Share on other sites More sharing options...
drac030 Posted July 30, 2015 Share Posted July 30, 2015 I am glad that you like it. I do realize that my English is far from being as stylistically and grammatically correct as it should be. So, if you have suggestions regarding improvements of style, I am all ears (via PM). Thanks in advance. Quote Link to comment Share on other sites More sharing options...
+David_P Posted July 31, 2015 Share Posted July 31, 2015 Draco, Your English is infinitely than the Polish of 99.99% of all North Americans; no reason to be apologetic. 1 Quote Link to comment Share on other sites More sharing options...
flashjazzcat Posted July 31, 2015 Share Posted July 31, 2015 Drac030's command of English is superior to that of many for whom English is the first language, for that matter. 3 Quote Link to comment Share on other sites More sharing options...
+DrVenkman Posted July 31, 2015 Share Posted July 31, 2015 (edited) Drac030's command of English is superior to that of many for whom English is the first language, for that matter. Bonus LIKE to FJC for proper usage of "for whom." EDIT: Also, cool that this was your 9,999th post! Edited July 31, 2015 by DrVenkman 3 Quote Link to comment Share on other sites More sharing options...
