kl99 Posted February 17, 2020 Share Posted February 17, 2020 it got already shipped to your place? which CPU chip is inside? is the mainboard fully populated or are chips missing? Quote Link to comment Share on other sites More sharing options...
+Schmitzi Posted February 19, 2020 Share Posted February 19, 2020 (edited) ja genau, gib mal Butter bei die Fische (3 days gone, go on) Edited February 19, 2020 by Schmitzi Quote Link to comment Share on other sites More sharing options...
+Ksarul Posted February 19, 2020 Share Posted February 19, 2020 Yes it is here. I plan to try and get some good internal pictures this weekend. . . 3 Quote Link to comment Share on other sites More sharing options...
fabrice montupet Posted February 19, 2020 Author Share Posted February 19, 2020 Yes! This week-end, I'll comfortably seated, a drink in a hand, and I'll appreciate this moment. I am waiting it since more than two decades! Thank you! 7 Quote Link to comment Share on other sites More sharing options...
+Ksarul Posted March 2, 2020 Share Posted March 2, 2020 (edited) I had a chance to disassemble the Dimension 4 and make some pictures. It is different from the parts I have, but the difference is not as great as I initially suspected. Like mine, the motherboard has very few components on it--including the video modulator. There is a switch on the left side of the console to select between channels 3 and 4. Like mine, the CPU and most of the logic is on a daughter board. I thought mine placed this board above the motherboard, but looking at this one, I may have been wrong (or this is just another difference). This daughter board is placed below the motherboard. The cartridge port connectors are the same in both versions I have. The attachment is quite different to the ones we use in production consoles though. The power supply is different too--it uses a 10-pin connector to attach to the motherboard. The exit from the console is just a cable from the power supply, so I suspect this was not how it would have looked when in production, as there was a space there for the external power supply connector we use now. This leads to another difference between the two part sets. The Dimension 4 has a speaker jack for sound. My parts set has a small board that replaces the internal power supply with one of the volume slide switches and connects to an internal speaker. All power comes into the console in the form of the required DC voltages. The parts themselves are also instructive. The chips in the Dimension 4 look to be made on or before the 44th week of 1978, whereas the parts in my loose parts set have chips made as late as the 52nd week of 1978, so these two board sets were probably made about 8 weeks apart, near the end of 1978. For those of you looking for pictures, download the attached ZIP file. Have much fun with these, Fabrice! Dimension 4.zip Edited March 2, 2020 by Ksarul 14 4 Quote Link to comment Share on other sites More sharing options...
humeur Posted March 3, 2020 Share Posted March 3, 2020 Merci Jim pour ces photos c'est super sympas. Jean louis 3 Quote Link to comment Share on other sites More sharing options...
fabrice montupet Posted March 8, 2020 Author Share Posted March 8, 2020 (edited) Thank you so much Jim! I come back from a few days business trip and I just discovered your Dimension 4 pictures! So Great!! Since this evening, I will study them. I'm so happy ? Edited March 8, 2020 by fabrice montupet 2 Quote Link to comment Share on other sites More sharing options...
Ed in SoDak Posted March 8, 2020 Share Posted March 8, 2020 Thanks for investigating and preserving this! Typical TI-overbuilt, even for a prototype. 16 gauge ground jumpers? And a Golden 9900. True eye candy. -Ed 1 Quote Link to comment Share on other sites More sharing options...
+Ksarul Posted March 8, 2020 Share Posted March 8, 2020 6 hours ago, fabrice montupet said: I come back from a few days business trip and I just discovered your Dimension 4 pictures! So Great!! Since this evening, I will study them. I'm so happy ? I am happy to have been able to give you this happiness, Fabrice! It was a very careful disassembly, as I wasn t sure where all of the screws and solder points were hidden. Luckily, it was just a few screws and a bunch of pins that slid through the boards to establish contact--no solder removal required. 2 Quote Link to comment Share on other sites More sharing options...
johannesmutlu Posted September 18 Share Posted September 18 Well i downloaded these images and it’s pretty interesting,but do you also have pictures of the original ti99/4 in it’s original case being shot or filmed from all corners,would be great to see those images. Quote Link to comment Share on other sites More sharing options...
Reciprocating Bill Posted September 20 Share Posted September 20 (edited) Interesting to see this thread resurrected - not only with the Dimension 4 photos (amazing!) but also the Foundation CP/M scans globeron posted on the first page. The Foundation literature is weirdly barefaced about its unfairness, at least regarding their use of benchmarks to contrast the 9900 and the Z80a. The second benchmark, a block move of 1000 bytes from one location to another, exemplifies this. The Z80a accomplishes this in a fast 5.25 ms, using a single dedicated block move instruction. That’s a cool feature, but one cherry picked to give the Z80a maximum advantage over the 9900. Foundation calculates the 9900 will require a miserable 29+ ms to accomplish the same block move. But that's with everything arranged in the worst possible light. Here are some numbers I obtained. They speak for themselves. 99/4a with 16-bit RAM in console: 500 16-bit MOVs: 8.5 ms. 1000 MOVBs: 15.5 ms. Stock 99/4a (emulated with Classic99), registers in scratchpad: 500 16-bit MOVs: 12.7 ms. 1000 MOVBs: 23.5 ms Stock 99/4a (emulated with Classic99) registers in 8-bit RAM: 500 16-bit MOVs: 16.5 ms (essentially 1/2 as fast as 16-bit RAM) 1000 MOVBs: 31.5 ms. Related, kinda: The January 1983 BYTE article reports the Z80 executing 10 iterations of the Sieve in assembly in 6.8 seconds. My 16-bit 99/4a does the same 6.4 seconds, a stock console in ~10 seconds (registers in scratchpad). The fastest Z80 running interpreted BASIC under CP/M executed 10 iterations of the Sieve in 1476 seconds. (In a later review the TRS Model II did so in 1440 seconds.) My 16-bit console running Cortex BASIC entirely out of 16-bit RAM executes the Sieve in 1313 seconds. Running out of the FinalGrom (with some of the interpreter therefore executing from 8-bit RAM) it executes in 1781 seconds. (I don't have numbers for a stock console). The fastest Z80 Forth execution of the Sieve is reported at 75.9 seconds, while FIG Forth executes in 84 seconds. Wycove Forth 3 (descended from FIG Forth) executes the Sieve in 92 seconds given 16-bit RAM. It would probably clock at about 130 seconds on a stock console. Edited September 20 by Reciprocating Bill 2 Quote Link to comment Share on other sites More sharing options...
