RSS Bot Posted August 14, 2015 Share Posted August 14, 2015 Analog published a column dedicated to teaching assembly language programming. Boot Camp appeared as 42 articles spanning a wide range of topics with many tips, tricks and example code. If Boot Camp was compiled into a book, this might be the table of contents or at least I’m hoping that it helps the next time I’m looking for information or code examples. PDF of following table Chap Issue Author Subject 1 72 Hudson Number Systems, Assembly, 6502 chip 2 73 Hudson Addressing, Syntax, Free Memory LDA, STA, JMP 3 74 Hudson BRK, LDX, STX, ADC, CLD, SBC, Flag 4 16 Hudson CMP, CPX, CPY, BCS, BCC, BEQ, BNE 5 17 Hudson X and Y Indexing - Multi bit addition 6 18 Hudson INC, DEC Bit Manipulation AND, BIT, ORA, EOR 7 19 Hudson Simple Multiplication ASL, ROL, LSR 8 20 Hudson The Stack 9 21 Hudson Subroutines RSR, RTS10 22 Hudson Stack Management PHA, PLA, PHP, PLP, TSX, TXS11 23 Hudson Relocatable Code12 25 Hudson BASIC’s USR Call13 26 Hudson BASIC’s USR Call with variable argument14 27 Hudson USR A=USR(TIMER,WAIT)15 28 Hudson USR A=USR(FLIP,ADR(A$),LEN(A$))16 29 Hudson USR RAND=USR(1536,HI) RAND=USR(1536,LOW,HI)17 33 Hudson Central Input/Output System PT.118 34 Hudson CIO Part 2 - Reading and Putting records19 36 Ratcliff Comparison Branching20 37 Hudson CIO Part 3 – error handling21 38 Hudson CIO using subroutines22 40 Hudson CIO examples – Copy keyboard input to file Copy from device to device23 41 Wiegers Using OS to simulate GRAPHICS, POSSITION, PRINT SETCOLOR, COLOR, PLOT, and DRAWTO in ML24 42 Wiegers Part 225 43 Wiegers Floating Point Operations in Assembly Language26 44 Wiegers Mixed Graphic Mode Display Using OPTION, SELECT, and START keys27 46 Wiegers DLIs – Display List Interrupts28 48 Wiegers PMG Player/Missile Graphics29 49 Wiegers Reading Joystick, smoothing movement via VBI30 50 Wiegers VBI improvement, Player Collisions 31 51 Wiegers Character Sets32 52 Wiegers Character Set Animation33 54 Wiegers Macro introduction – SETCOLOR macro34 55 Wiegers SETCOLOR, POKE, POSITION, OPEN, CLOSE, GRAPHICS, PRINT, COLOR, PLOT, DRAWTO macros35 57 Wiegers CIO commands and XIO macro36 58 Wiegers macro INPUT, PAUSE, ADD, SUBTRACT, DPOKE, FOR, NEXT, MOVE(61)37 60 Wiegers The Programming Process and RAMdisk file copier38 61 Wiegers macro VBION, VBIOFF, DLION, DLIOFF, SETPCOLOR PWIDTH, PMGON, PMGOFF, PMGRES, HPLAYER, HMISSILE, MWIDTH, PLFIELD39 62 Wiegers Number and ASC conversion macros ASC2INT, INT2ASC, LDGZERO 40 64 Wiegers BCD and ASCII macros ASC2BCD, BCD2ASC41 66 Wiegers Adventure Game Vocabulary Search42 69 Wiegers Parser Program Attached File(s) Analog boot camp index.pdf (108.23KB)Number of downloads: 0 http://atariage.com/forums/blog/572/entry-12236-analogs-boot-camp-table-of-contents/ Link to comment Share on other sites More sharing options...
