kynrek Posted September 2, 2015 Share Posted September 2, 2015 If i use the headphone jack on my sega model 1 while playing 32x games am I "missing out" on sound generated from the 32x (if it even does generate sound)? I have read that the av output from the model 1 only outputs mono. Quote Link to comment Share on other sites More sharing options...
+FujiSkunk Posted September 2, 2015 Share Posted September 2, 2015 The 32X does generate some audio, yes, mostly improved digital samples. Using only the headphone jack will make you miss that extra audio. Ideally for the full 32X audio experience you should use a Genesis 2. Quote Link to comment Share on other sites More sharing options...
Greg2600 Posted September 2, 2015 Share Posted September 2, 2015 Not sure if you're noticeably "missing" audio, but stereo is a lot better than mono. I use this cable to get the stereo mix from the jack into the Stereo AV Out from 32X (works with my RGB SCART cable too). http://www.ebay.com/itm/Sega-Genesis-1-Megadrive-stereo-32X-PATCH-CABLE-link-adaptor-US-seller-/161588264141?hash=item259f693ccd 2 Quote Link to comment Share on other sites More sharing options...
kynrek Posted September 2, 2015 Author Share Posted September 2, 2015 Greg2600, thanks! I am planning on using scart too. Do i still need that cable if i use a sega cd model 2 with the 32x and model 1 genesis? Do I hook the speakers up to the 32x output or the stereo phono jacks on the sega cd? Quote Link to comment Share on other sites More sharing options...
+FujiSkunk Posted September 2, 2015 Share Posted September 2, 2015 I should've known somebody would have wired a cable to get stereo from the headphone jack to the 32X. I'll have to pick one of those up too. Quote Link to comment Share on other sites More sharing options...
kynrek Posted September 3, 2015 Author Share Posted September 3, 2015 Sorry I posted this thread twice by accident. Quote Link to comment Share on other sites More sharing options...
Rick Dangerous Posted September 11, 2015 Share Posted September 11, 2015 Sega was like the early Apple. There is a cable/adaptor for that!! (and I highly recommend purchasing it. Quote Link to comment Share on other sites More sharing options...
Tenorman Posted October 9, 2015 Share Posted October 9, 2015 The page below does a good job discussing all the different ways to get audio out of the different Genesis/Sega CD/32X combinations: http://retrorgb.com/segacd.html If i use the headphone jack on my sega model 1 while playing 32x games am I "missing out" on sound generated from the 32x (if it even does generate sound)? I have read that the av output from the model 1 only outputs mono. Nope, you're fine. The 32X does generate some audio, yes, mostly improved digital samples. Using only the headphone jack will make you miss that extra audio. Ideally for the full 32X audio experience you should use a Genesis 2. This isn't true, the 32X's sound is passed through the Genesis. You will be able to hear everything by using the headphone jack. Not sure if you're noticeably "missing" audio, but stereo is a lot better than mono. I use this cable to get the stereo mix from the jack into the Stereo AV Out from 32X (works with my RGB SCART cable too). http://www.ebay.com/itm/Sega-Genesis-1-Megadrive-stereo-32X-PATCH-CABLE-link-adaptor-US-seller-/161588264141?hash=item259f693ccd What cables like this do is simply pass the stereo audio coming out of the headphone jack back through the 32X so that you can use normal stereo Genesis 2 AV cables. You can still just take the audio from the headphone jack if you would like. Quote Link to comment Share on other sites More sharing options...
+FujiSkunk Posted October 10, 2015 Share Posted October 10, 2015 This isn't true, the 32X's sound is passed through the Genesis. You will be able to hear everything by using the headphone jack. Ah, cool. I thought the audio would mix the same way the graphics do before being output from the 32X. Quote Link to comment Share on other sites More sharing options...
