TMS-9900 CP/M?
OLD CS1
2 hours ago, Vorticon said:
Not really. In the hay days of CP/M, each machine had it's own terminal settings which is why one needs to install most CP/M applications to match the machine running them.
WordStar runs fine under VT100, but there are issues when editing text with things like the first line disappearing or scrolling problems, which I am assuming are related to an incomplete emulation by TIPI.
An yes, that is the emulator I am using.
A specific 4A client would be totally awesome!
I wonder if anyone has tried using MyTerm for the TIPI for the Geneve.  It has ANSI emulation which I think is "as good as", though do not know if it is better than, the TIPI telnet client with the F18A.
Does Wordstar use more than 80 columns?  Maybe I am thinking of another editor.,
No Wordstar is strictly 80 columns.
4 hours ago, gferluga said:
I did indeed try this emulation and it works great. The advantage of RunCPM over this one though is that the former allows you to just drop CP/M executables and files into a drive folder directly without the need of special tools and it will run them just fine.
11 hours ago, jedimatt42 said:
Yep, vt100 compatibility with differentiating features must have be all the rage for a period in the terminal market.
It seems more like the Linux community started using "vt100" to mean "terminal emulator" and forgot it referred to a specific piece of hardware at some point. So the DEC VT220 color codes are now part of the Linux vt100 software platform.
On 5/17/2021 at 3:30 AM, Tursi said:
Hmm. DOSBox should run on it, but it'll use the video display. So we just need to add some code to copy the DOS window over to the TI - custom terminal! Probably want F18A so you can have 80 column text.
("just", I say... ;) )
just port vnc to the 4a w f18a :)
