S1500 Posted October 8, 2015 Share Posted October 8, 2015 So I wanted to try a disk or 2 with JS99er. So far, no luck. In the log when I insert the disk, it says It's not in TIFILES or V9T9 format. Is there a conversion I can do to it? All the disks I tried so far, no luck. Quote Link to comment Share on other sites More sharing options...
Omega-TI Posted October 8, 2015 Share Posted October 8, 2015 Hmmm, well Ti99Dir will convert programs back & forth between formats. Try the attached disk image below, I tried it and it works. BTW did you know << THIS SITE >> is a mirror of WHTECH? Pinball.dsk Quote Link to comment Share on other sites More sharing options...
Asmusr Posted October 8, 2015 Share Posted October 8, 2015 So I wanted to try a disk or 2 with JS99er. So far, no luck. In the log when I insert the disk, it says It's not in TIFILES or V9T9 format. Is there a conversion I can do to it? All the disks I tried so far, no luck. If you post the disks I can check if there is a problem. Quote Link to comment Share on other sites More sharing options...
RickyDean Posted October 8, 2015 Share Posted October 8, 2015 Are the disk in PC99 format? That may be the problem Asmusr-M above can solve for you. 1 Quote Link to comment Share on other sites More sharing options...
Opry99er Posted October 9, 2015 Share Posted October 9, 2015 I cannot speak to js99er directly, but I have had issues in other emulators with disk images if the extension was not what it was expecting... Quote Link to comment Share on other sites More sharing options...
