Manic1975 Posted October 11, 2015 Share Posted October 11, 2015 Guys is there a project to make a smaller PEB? Is there project to make PCB with 3 slots? It could have 32k memory expansion and floppy controler and rs232 or parallel connector for printer. Original PEB is big and heavy. I think it would be nice to have someting smaller and cheaper to buy then large PEB. Maybe we could build box for this smaller PEB at home and then put components together. I have CF7 and I know about nanoPEB, but I would like to have something like PEB. I didn't buy PEB because price and shipping is too high for me (I live in Croatia, Europe). On Floppy controler I could connect Lotharek's floppy emulator. It is interesting dream but is there any chance to make something like this? I know our hardware guys may have some ideas how to realize this. 1 Quote Link to comment Share on other sites More sharing options...
RickyDean Posted October 11, 2015 Share Posted October 11, 2015 I don't know of a project at going on now, though it is a good idea, something similar to the old Corcomp/Myarc series with a edge card ribbon cable instead of the flex interface and 32k Sram, and a FPGA based floppy/hard controller or CPLD like used on the CF7+/NanoPeb. These could be mounted in sockets on board the backplane and still have slots for cards like the Rave/Horizon ramdisks, triple tech card and so forth. hey a Zenoboard PEB, sounds great. 2 Quote Link to comment Share on other sites More sharing options...
Manic1975 Posted October 11, 2015 Author Share Posted October 11, 2015 I'am not sure how difficult is to build new smaller controler. But if we use floppy controler maybe we have to copy some known controller design. You guys said that you have new 32k memory expansion for PEB. Maybe we can use it in this project. Can you said what you can already use for this miniPEB. Please correct me if I'am wrong. Quote Link to comment Share on other sites More sharing options...
+Ksarul Posted October 11, 2015 Share Posted October 11, 2015 Actually, there are at least two designs out there for smaller PEBs and two more for putting a TI style backplane into a PC case. The smaller ones came from Australia, and are well documented on the WHT site (the CADET, which adds a lot of power in a small space), or the 4-slot PEB (documented in the TI BUG newsletters). On larger backplanes, you have the Microstuph board (I have one of these) or the Rave PE2 (I have one of these as well). Of all of them, it might be easiest to do something similar to the four-slot board, as that one includes the interfacing to connect it to the console. . .and it is actually on my project list for work at some point in time. That will be a while though, as I have several projects ahead of it in my queue. . . 2 Quote Link to comment Share on other sites More sharing options...
RickyDean Posted October 12, 2015 Share Posted October 12, 2015 Yeh, I have the Rave PE2 also and am planning to set it up with a Geneve and a TIM empowered TI. The old rave case is still serviceable, though somewhat rusty, but my plans are to install it in a modern mid tower using the Rave backplane. I am also planning on trying to create an adapter to use older 8 bit and 16 bit PC cards in it. This will be my main PEB, but I will be looking at other options as well. Quote Link to comment Share on other sites More sharing options...
Omega-TI Posted October 12, 2015 Share Posted October 12, 2015 Manic1975, that is a very cool idea! A PC power supply and a PCB backplane in smaller case. A PC power supply (like in this photo taken by Wyerd)... ... attached to a smaller 'backplane' made on a printed circuit board... What kind of case did you have in mind to stick this into? Quote Link to comment Share on other sites More sharing options...
Manic1975 Posted October 12, 2015 Author Share Posted October 12, 2015 I was thinking about some nice PC case or custom made plexi glass case. Custom made case can be designed any way I like. Quote Link to comment Share on other sites More sharing options...
Manic1975 Posted October 12, 2015 Author Share Posted October 12, 2015 Actually, there are at least two designs out there for smaller PEBs and two more for putting a TI style backplane into a PC case. The smaller ones came from Australia, and are well documented on the WHT site (the CADET, which adds a lot of power in a small space), or the 4-slot PEB (documented in the TI BUG newsletters). On larger backplanes, you have the Microstuph board (I have one of these) or the Rave PE2 (I have one of these as well). Of all of them, it might be easiest to do something similar to the four-slot board, as that one includes the interfacing to connect it to the console. . .and it is actually on my project list for work at some point in time. That will be a while though, as I have several projects ahead of it in my queue. . . I Know that you probably have several project in queue. But it would be nice to have possibility to build smaller PEB. Thank you for answer! Quote Link to comment Share on other sites More sharing options...
+OLD CS1 Posted October 12, 2015 Share Posted October 12, 2015 It occurs to me that the power supply does not have to be a large and separate unit as it exists now. In fact, given something like the PicoPSU or similar device, the power supply could easily exist on a card. 1 Quote Link to comment Share on other sites More sharing options...
Omega-TI Posted October 13, 2015 Share Posted October 13, 2015 It occurs to me that the power supply does not have to be a large and separate unit as it exists now. In fact, given something like the PicoPSU or similar device, the power supply could easily exist on a card. BRILLIANT! I never knew about this little power supply. You're right, the connector could be built right onto the back plane's circuit board, talk about a space and weight saver! A perfect little project for a DIY guy. I'm not sure what would be cheaper in the end, a P-Box or this arrangement with power supply, case and back plane. Neat concept. Quote Link to comment Share on other sites More sharing options...
RickyDean Posted October 13, 2015 Share Posted October 13, 2015 (edited) I don't think cheaper(though less is always good, as long as quality is good) is the question here, but feasibility and and portability. I would say yes it is very possible, and I have an old TI into a Kaypro II case project, that I had started years ago that would benefit from some of this new stuff. F18, with a small VGA flat screen mounted where the green screen used to be, 32k on board mod and ubergrom with two lothertec or gotek drives where the 360k floppies used to reside and one of my Rave 99 keyboard cards or one of the new ps/2 adapters. Yes! Edited October 13, 2015 by RickyDean Quote Link to comment Share on other sites More sharing options...
Omega-TI Posted October 13, 2015 Share Posted October 13, 2015 ^^^ Ohhh I'd like to see THAT! ^^^ Sounds neat. Quote Link to comment Share on other sites More sharing options...
+OLD CS1 Posted October 13, 2015 Share Posted October 13, 2015 Best I can do with people swarming around my desk. 2 Quote Link to comment Share on other sites More sharing options...
RickyDean Posted October 13, 2015 Share Posted October 13, 2015 sx99.jpg Best I can do with people swarming around my desk. Yep my KayPro case will be a little clunkier, but a nice place to put a smaller PEB type setup. right . 1 Quote Link to comment Share on other sites More sharing options...
Omega-TI Posted October 13, 2015 Share Posted October 13, 2015 Best I can do with people swarming around my desk. I love the photo... but the C64 keyboard needs a little photo-shopping! Quote Link to comment Share on other sites More sharing options...
ti99iuc Posted October 14, 2015 Share Posted October 14, 2015 sx99.jpg Best I can do with people swarming around my desk. Same Idea OLD CS1 i Did it in January 1 Quote Link to comment Share on other sites More sharing options...
+OLD CS1 Posted October 16, 2015 Share Posted October 16, 2015 Sunnuvabitch Neat! Hey, does anyone know what the pins the in card slots of the PEB are rated? Could one slot provide power to the rest of the unit without a melt-down? Quote Link to comment Share on other sites More sharing options...
RickyDean Posted October 16, 2015 Share Posted October 16, 2015 No I don't know if there could be a problem, but in Post http://atariage.com/forums/topic/242049-cramming-stuff-into-or-on-the-ti-console/?do=findComment&comment=3309408on Fri Aug, 28, 2015 8:24 AM I posted a picture of an interface cablw that I made that connected two PEB backplanes together via slots. I had used this setup in a giant tower case I had built to house a Geneve with a lot of Myarc and Horizon Ramdisks and for the time I used it I never had an issue (about 6 months, before packing everything up for shipment and storage in the late 90's) Quote Link to comment Share on other sites More sharing options...
