different fix button 4 vectrex controller
Dennis88
Common problem at the vectrex controller: button 4 is not working.
3 things what can cause this problem:
dirty contacts rubber pad and circuitboard
Worn out rubber pad
cracked circuitboard
In my situation: the circuitboard cracked in the middle including the circuit.
the fix
- Gently remove the overlay sticker ( use a hairdryer and take your time )
- Remove the screws
- Open the controller and unscrew the circuitboard
- Clean contacts of rubber pad and circuit board with some alcohol
* now the tricky part! *
- Picture 2 is showing the crack and fix ( see the crack in the middle of the circuit circle )
- Heat up a soldering iron and gently wipe some solder on the tip of the iron ( not too much! )
- Heat up the circuit circle a little bit where it cracked and then wipe the solder over the crack.
- If done correctly the crack has been fixed, now we are going to fortify this spot
- Ad some glue over the crack ( front + back of circuit board but only on the board, not circuit! )
- after drying stick some tape at the back and fold a little over the board.
* Also you can place a tiny screw at the side of the board ( there is a small hole ) to give more strength
