Lewis2907 Posted December 22, 2015 Share Posted December 22, 2015 Hello, I am trying to get player0 to fire the missile and hit player1. I can complete this if I modify the program by taking out my cutscenses and goto statements. If anyone is able to help me figure out where I went wrong it would be great as I plan to add more cutscenes and 4 more levels. Eventually I will learn how the title screen kernal works as well to create a better game. Also credits to the other programers code i used to build my game below. I took apart some others codes that I could understand and used it below. My ulitmate goal is to make a few games and have them loaded on to a cartage and play on my 2600 I kept from my childhood. Gamestart rem setup cut scenes set tv pal set romsize 32kSC const pfres=32 set kernel_options playercolors player1colors pfcolors set optimization speed set smartbranching on set optimization noinlinedata set optimization inlinerand rem --------------------------------------------- rem setup title screen and cut scences rem --------------------------------------------- rem ----------Title Screen----------------------- _Titlescreen_Loop goto titlescreen returntitlescreen drawscreen if joy0fire then goto __Cutscene_Loop2 goto _Titlescreen_Loop rem ----------Cut Scenes------------------------- __Cutscene_Loop2 goto Cutscene1 returnCutscene1 t=t+1 if t=100 then goto __Cutscene_Loop3 drawscreen goto __Cutscene_Loop2 __Cutscene_Loop3 goto Cutscene2 returnCutscene2 t=t+1 if t=100 then goto __Cutscene_Loop4 drawscreen goto __Cutscene_Loop3 __Cutscene_Loop4 goto Cutscene3 returnCutscene3 s=s+1 if s=100 then goto __Cutscene_Loop5 drawscreen goto __Cutscene_Loop4 __Cutscene_Loop5 goto Cutscene4 returnCutscene4 r=r+1 if r=100 then goto jump2 drawscreen goto __Cutscene_Loop5 jump2 rem -------Start Level 1--------------------------------------- level1 rem scrolling background speed dim _Scroll_Control = a.b rem player one shiled strength const pfscore = 1 pfscore1 = 3 rem define the playing field boundaries const _Edge_Top = 9 const _Edge_Bottom = 88 const _Edge_Left = 1 const _Edge_Right = 152 rem missile missile0x = 64 missile0y = 64 missile1height = 4 NUSIZ0 = 00 rem load level 1 playing field goto playingfield1 returnplayingfield1 drawscreen rem go get player sprites goto hero1 returnhero1 drawscreen goto enemy1 returnenemy1 drawscreen rem make sprites equal players dim hero1=player0 dim enemy1=player1 rem player positions player0x = 55:player0y = 100 player1x = 90:player1y = 100 mainlevel1 draw_loop rem fire missile if missile0y > 240 then goto skip missile0y = missile0y-2: goto draw_loop skip if joy0fire then missile0y = player0y-2:missile0x=player0x+4 rem scrolling backgoround if !joy0left then goto __Skip_left _Scroll_Control = _Scroll_Control + 0.8 if _Scroll_Control > 1 then pfscroll right : _Scroll_Control = 0 __Skip_left if !joy0right then goto __Skip_right _Scroll_Control = _Scroll_Control + 0.8 if _Scroll_Control > 1 then pfscroll left : _Scroll_Control = 0 __Skip_right if !joy0down then goto __Skip_down _Scroll_Control = _Scroll_Control + 0.8 if _Scroll_Control > 1 then pfscroll down : _Scroll_Control = 0 __Skip_down if !joy0up then goto __Skip_up _Scroll_Control = _Scroll_Control + 0.8 if _Scroll_Control > 1 then pfscroll up : _Scroll_Control = 0 __Skip_up rem enemy movemement if player1y < player0y then player1y = player1y+1 if player1y > player0y then player1y = player1y-1 if player1x < player0x then player1x = player1x+1 if player1x > player0x then player1x = player1x-1 player1x=player1x:player1y = player1y rem player movement if joy0up && player0y > _Edge_Top then player0y = player0y - 2: goto jump if joy0down && player0y < _Edge_Bottom then player0y = player0y + 2: goto jump if joy0left && player0x > _Edge_Left then player0x = player0x - 2: goto jump if joy0right && player0x < _Edge_Right then player0x = player0x + 2: goto jump rem player score if collision(missile0,player1) then score=score+1:player1x=rand/2:player1y=0:missile0y=255 if collision(player0,player1) then score=score-1:player1x=rand/2:player1y=0:missile0y=255:pfscore1 = pfscore1-1 rem if player shields go out go to gameover if !pfscore1=0 then goto gameover jump drawscreen goto mainlevel1 goto level1 rem ------------------------------------------------------------ rem Cut Scences, Sprites, Title Screen etc below --------------- rem ------------------------------------------------------------ titlescreen pfcolors: $16 $16 $16 $16 $16 $16 $16 $16 $16 $16 $16 $16 $16 $16 $16 $16 $16 $16 $16 $16 $16 $16 $16 $16 $16 $16 $16 $16 $16 $16 $16 end playfield: XXXX..XXX..X...X..XXX.....X..... X....X...X.X...X.X.......X.X.... XXXX.XXXXX.X...X.XXX....XXXXX... ...X.X...X..X.X..X.....X..X..X.. XXXX.X...X...X....XXX....X.X.... ................................ .XXX..XXX..XXXXX.XXXXX.X..X..... X....X...X.X...X...X...X..X..... XXX..XXXXX.XXXX....X...XXXX..... X....X...X.X...X...X...X..X..... .XXX.X...X.X...X...X...X..X..... ................................ ................................ ........XXXX....X...X........... ........X...X....X.X............ ........X..X......X............. ........X...X.....X............. ........XXXX......X............. ................................ ................................ XXXX...XXX..XXXX.XXXX.XXX.X..X.. X...X.X...X.X..X.X..X.X...X..X.. X...X.XXXXX.XXX..XXX..XXX.X..X.. X...X.X...X.X..X.X..X.X...X..X.. XXXX..X...X.X..X.X..X.XXX.XX.XX. ................................ .....X...XXX.X...X.XXX.XXXX..... .....X...X...X...X..X..X........ .....X...XX..X.X.X..X..XXXX..... .....X...X...X.X.X..X.....X..... .....XXX.XXX..X.X..XXX.XXXX..... ................................ end goto returntitlescreen Cutscene1 pfcolors: $16 $16 $16 $16 $16 $16 $16 $16 $16 $16 $16 $16 $16 $16 $16 $16 $16 $16 $16 $16 $16 $16 $16 $16 $16 $16 $16 $16 $16 $16 $16 $16 end playfield: ................................ .XXXX.X..X..XXX..XXX...XX..X...X .X....X..X.X...X.X..X.X..X.X...X .XXXX.XXXX.XXXXX.X..X.X..X.X.X.X ....X.X..X.X...X.X..X.X..X.X.X.X .XXXX.X..X.X...X.XXX...XX...X.X. ................................ ....XXX..XXXX..XXX...XXX.XXXX... ...X.X.X.X....X...X.X....X...... ...X.X.X.XXX..X.XX..X....XXXX... ...X...X.X....X...X.X.......X... ...X...X.XXXX.X...X..XXX.XXXX... ................................ ................................ .......XXXXXXXX................. ......XXXXXXXXXX................ .....XX......................... .....XX....XXX.................. .....XXXXXXXXXXX..........X..... ......XXXX................X..... .......XXXXXXX...........XX..... ..XXXX...XXXX..XXXXX....XX.X.... X...XXXX......XXX......XX.XX.... XXXXX...XXXXXX....XXX....XX..... XXX.XXXX......XXX..XXX..XX...... XX...X..XXXXXX..XX..XXXXX....... XXX..XXX.......XXX...XXX........ XXXX..XXXXXXXXXXXX.............. .XXXX..XXXX..XXXX............... .X.X.X..XX.XX.XX................ ..XXX....XX..XX................. ....X...XX.XX.XX................ end goto returnCutscene1 Cutscene2 pfcolors: $16 $16 $16 $16 $16 $16 $16 $16 $16 $16 $16 $16 $16 $16 $16 $16 $16 $16 $16 $16 $16 $16 $16 $16 $16 $16 $16 $16 $16 $16 $16 $16 end playfield: ................................ X..X.X.X...X........XXX..X...X.. X.X..X.X...X.......X...X.X...X.. XX...X.X...X.......XXXXX.X...X.. X.X..X.X...X.......X...X.X...X.. X..X.X.XXX.XXX.....X...X.XXX.XXX ................................ .XXX..XXXX....XXX.X..X.XXX..XXX. X...X.X........X..X..X.X...X.X.X X...X.XXX......X..XXXX.XX..X.X.X X...X.X........X..X..X.X...X...X .XXX..X........X..X..X.XXX.X...X ................................ ................................ .......XXXXXXXX................. ......XXXXXXXXXX................ .....XX......................... .....XX....XXX.................. .....XXXXXXXXXXX..........X..... ......XXXX................X..... .......XXXXXXX...........XX..... ..XXXX...XXXX..XXXXX....XX.X.... X...XXXX......XXX......XX.XX.... XXXXX...XXXXXX....XXX....XX..... XXX.XXXX......XXX..XXX..XX...... XX...X..XXXXXX..XX..XXXXX....... XXX..XXX.......XXX...XXX........ XXXX..XXXXXXXXXXXX.............. .XXXX..XXXX..XXXX............... .X.X.X..XX.XX.XX................ ..XXX....XX..XX................. ....X...XX.XX.XX................ end goto returnCutscene2 Cutscene3 pfcolors: $16 $16 $16 $16 $16 $40 $16 $16 $16 $16 $16 $44 $44 $0E $0E $0E $0C $0C $84 $0C $0C $0C $0C $0C $0E $0E $0E $0E $0E $0C $84 $84 end playfield: .XXX..XX..XXX....XXX...XX...XXX. ..X..X..X.X..X...X..X.X..X.X.... ..X..X..X.XXX....X..X.X..X.X.XXX ..X..X..X.X......X..X.X..X.X...X ..X...XX..X......XXX...XX...XXX. ................................ ........X...X.X..X.X...X........ ........X...X.X..X..X.X......... ........X.X.X.XXXX...X.......... .........X.X..X..X...X.......... ................................ .............X.X................ .............XXXXXX............. .............XXXX.XX............ .............XX.XXXX............ ..............XX.XX............. ..............X.XX.............. .............X.XXX.XXXXXXX...... ............XXXXXXXXX.X......... ...............X.X.............. ..............X.X.X............. ..............XX.X.X............ .............XX.X.X.X........... ............XX.XX.XX.X.......... ............X.XX..XXXX.......... ...........XXXX..XX.XX.......... ...........XX.X.XX.XX........... ..........XX.XX.XXXX............ .........XX.XX.XX.XX............ .........X.XX..X..XX............ .........X..X...X..X............ ........X..X...X..X............. end goto returnCutscene3 Cutscene4 pfcolors: $16 $16 $16 $16 $16 $40 $16 $16 $16 $16 $16 $44 $44 $0E $0E $0E $0C $0C $84 $0C $0C $0C $0C $0C $0E $0E $0E $0E $0E $0C $84 $84 end playfield: ................................ ................................ ................................ ................................ ................................ ................................ ..XXX.XXX.XXX....XX..X..X..X.... ...X...X..XX....X..X.XX.X..X.... ...X...X....X...X..X.X.XX....... ..XXX..X..XXX....XX..X..X..X.... ................................ .............X.X................ .............XXXXXX............. .............XXXX.XX............ .............XX.XXXX............ ..............XX.XX............. ..............X.XX.............. .............X.XXX.XXXXXXX...... ............XXXXXXXXX.X......... ...............X.X.............. ..............X.X.X............. ..............XX.X.X............ .............XX.X.X.X........... ............XX.XX.XX.X.......... ............X.XX..XXXX.......... ...........XXXX..XX.XX.......... ...........XX.X.XX.XX........... ..........XX.XX.XXXX............ .........XX.XX.XX.XX............ .........X.XX..X..XX............ .........X..X...X..X............ ........X..X...X..X............. end goto returnCutscene4 playingfield1 pfcolors: $16 $16 $16 $16 $16 $16 $16 $16 $16 $16 $16 $16 $16 $16 $16 $16 $16 $16 $16 $16 $16 $16 $16 $16 $16 $16 $16 $16 $16 $16 $16 $16 end playfield: ................................ ................................ ................................ ................................ ................................ .....XX.....XX.................. ...XX....XXXXXXX................ ...X...XXXXXXXX................. ....X.XXXXXXXXX................. .......XXXX..................... ........XXXX.................... .........X..........X.......XX.. ..................XX.....XXXXX.. .................X..X.XXXXXX.... .....XXXX.......XX.XXXXXXXXXXX.. ...XXXXXXXX....XXXXXXXXXXXXX.... ..XXXXXXX...XX....XXXXXXXXXXX... .XXXXXX...XXXXX..XX.XXXXXXXXXX.. .XXXXXXXX.XXXXXX...XXXXXXXXXXX.. .XXXXXXXXXXXX........XX..XXXXX.. ..XXXXXXXXXX.......XX.X.XXXXX... ...XXX.....X...XXXXXXX...XX.X... ......X.......XXXXXXXXXXXXXX.XX. .....XXXXXXX....XXXXXX...XXX.... .......XXXXXXXX...XXXXXX...XXXX. ........XXXXX.......XXXX........ .........XXXX.......XXXX........ .........XXX........XXX......... ........XX.........XX.....X.XX.. ..........X.............XXXXXXX. .........................XXXX... ................................ end goto returnplayingfield1 rem ------------level 1 sprites-------------- hero1 player0: %00101000 %00111000 %00010000 %10010010 %01111100 %00111000 %00010000 %00010000 end COLUP0 = #$05 goto returnhero1 enemy1 player1: %01000010 %00111100 %00100100 %01000010 %11011011 %01000010 %00100100 %00011000 end player1color: $40 $D0 $D0 $D0 $D0 $D0 $D0 $D0 end goto returnenemy1 rem -------------------------Gameover Screen-------------------------- gameover drawscreen playfield: ................................ ...XXXX..XXX...XXX...XXXX....... ..X.....X...X.X.X.X.X........... ..X..XX.XXXXX.X.X.X.XXX......... ..X...X.X...X.X.X.X.X........... ...XXX..X...X.X...X..XXXX....... ................................ ...XXX..X...X..XXXX.XXXXX....... ..X...X.X...X.X.....X...X....... ..X...X.X...X.XXX...XXXX........ ..X...X..X.X..X.....X...X....... ...XXX....X....XXXX.X...X....... ................................ ................................ ................................ ................................ ................................ ................................ ................................ ................................ ................................ ................................ ................................ ................................ ................................ ................................ ................................ ................................ ................................ ................................ ................................ ................................ end COLUBK = $0F COLUPF = $72 if joy0down then goto Gamestart goto gameover end Save Earth Complete - Clean Version..txt Quote Link to comment Share on other sites More sharing options...
Tinman Posted December 24, 2015 Share Posted December 24, 2015 Where does its get stuck with the cutscenes? And is there away to do gosubs or functions in place of the gotos? They make it really tough to follow the program logic. Quote Link to comment Share on other sites More sharing options...
Lewis2907 Posted December 25, 2015 Author Share Posted December 25, 2015 Thanks for the reply. I will try to look up gosubs and how to use them. I found a example with goto and I was able to incorporate it into my program. The game itself works but player0 flashes a lot and won't shoot the missile. I have the same part level 1 as stand alone and everything works. once i figure out the player0 and missile erros I plan to add another "if" statement when you shoot the enemy 5 times goto level 2. I have built 4 levels as stand alone. I am trying to compile them into cut scene, level 1, cut scene level 2 etc. Then I have another idead after I learn the basics of the titlescreen kernel. below is level 1 as a stand alone. Of course I used others source codes and modified them the best i could. rem ********************************** rem *<filename> * rem *<description> * rem *<author> * rem *<contact info> * rem *<license> * rem ********************************** gamestart set tv pal set romsize 32kSC set kernel const pfres=32 dim _Scroll_Control = a.b rem player one shiled strength const pfscore = 1 pfscore1 = 3 playfield: XXXX..XXX..X...X..XXX.....X..... X....X...X.X...X.X.......X.X.... XXXX.XXXXX.X...X.XXX....XXXXX... ...X.X...X..X.X..X.....X..X..X.. XXXX.X...X...X....XXX....X.X.... ................................ .XXX..XXX..XXXXX.XXXXX.X..X..... X....X...X.X...X...X...X..X..... XXX..XXXXX.XXXX....X...XXXX..... X....X...X.X...X...X...X..X..... .XXX.X...X.X...X...X...X..X..... ................................ ................................ ........XXXX....X...X........... ........X...X....X.X............ ........X..X......X............. ........X...X.....X............. ........XXXX......X............. ................................ ................................ XXXX...XXX..XXXX.XXXX.XXX.X..X.. X...X.X...X.X..X.X..X.X...X..X.. X...X.XXXXX.XXX..XXX..XXX.X..X.. X...X.X...X.X..X.X..X.X...X..X.. XXXX..X...X.X..X.X..X.XXX.XX.XX. ................................ .....X...XXX.X...X.XXX.XXXX..... .....X...X...X...X..X..X........ .....X...XX..X.X.X..X..XXXX..... .....X...X...X.X.X..X.....X..... .....XXX.XXX..X.X..XXX.XXXX..... ................................ end title COLUBK = #$0F COLUPF = #$72 drawscreen if joy0fire then goto skiptitle goto title skiptitle rem define the playing field boundaries const _Edge_Top = 9 const _Edge_Bottom = 88 const _Edge_Left = 1 const _Edge_Right = 152 rem missile missile0x = 64 missile0y = 64 missile1height = 4 NUSIZ0 = 00 playfield: ................................ ................................ ................................ ................................ ................................ ....XXX.....XX.................. ...XX....XXXXXXX................ ...X...XXXXXXXX................. ......XXXXXXXXX................. .......XXXXXXX.................. ........XXXX..................XX .........X..................XXXX ..................XXX.....XXXXXX .....X...........XXXXX...XXXXXXX ...XXXXXX........XX.XX...XXXXXXX ..XXXXXXXXX.......XXXXXXXXXXXXXX XXXXXXXXX...XX.......XXXXXXXXXXX XXXXXXX...XXXXX....X.XXXXXXXXXXX XXXXXXXXX.XXXXXX....XXXXXXXXXXXX XXXXXXXXXXXXX........XX..XXXXXXX .XXXXXXXXXXX........XX.X.XXXXXXX ..XXXX.....X....XXXXXXX...XX.XX. ......X..........XXXXXXX..XX.XX. .....XXXXXXX......XXXXXX...X.... .......XXXXXXXX.....XXXXXX....XX ........XXXXX.......XXXX.......X .........XXXX.......XXXX........ .........XXX........XXX......... ........XX...........X....X.XX.. ........X................XXXXXX. .........................XXXXXX. ..........................X.XX.. end player0x = 75:player0y = 80 player1x = 20:player1y = 100 main rem playfield background colors COLUBK = #$10 COLUPF = #$30 player0: %00101000 %00111000 %00010000 %10010010 %01111100 %00111000 %00010000 %00010000 end COLUP0 = #$05 set kernel_options player1colors player1: %01000010 %00111100 %00100100 %01000010 %11011011 %01000010 %00100100 %00011000 end player1color: $40 $D0 $D0 $D0 $D0 $D0 $D0 $D0 end rem fire missile if missile0y > 240 then goto skip missile0y = missile0y-2: goto draw_loop skip if joy0fire then missile0y = player0y-2:missile0x=player0x+4 draw_loop drawscreen rem scrolling backgoround if !joy0left then goto __Skip_left _Scroll_Control = _Scroll_Control + 0.8 if _Scroll_Control > 1 then pfscroll right : _Scroll_Control = 0 __Skip_left if !joy0right then goto __Skip_right _Scroll_Control = _Scroll_Control + 0.8 if _Scroll_Control > 1 then pfscroll left : _Scroll_Control = 0 __Skip_right if !joy0down then goto __Skip_down _Scroll_Control = _Scroll_Control + 0.8 if _Scroll_Control > 1 then pfscroll down : _Scroll_Control = 0 __Skip_down if !joy0up then goto __Skip_up _Scroll_Control = _Scroll_Control + 0.8 if _Scroll_Control > 1 then pfscroll up : _Scroll_Control = 0 __Skip_up rem enemy movemement if player1y < player0y then player1y = player1y+1 if player1y > player0y then player1y = player1y-1 if player1x < player0x then player1x = player1x+1 if player1x > player0x then player1x = player1x-1 player1x=player1x:player1y = player1y rem player movement if joy0up && player0y > _Edge_Top then player0y = player0y - 2: goto jump if joy0down && player0y < _Edge_Bottom then player0y = player0y + 2: goto jump if joy0left && player0x > _Edge_Left then player0x = player0x - 2: goto jump if joy0right && player0x < _Edge_Right then player0x = player0x + 2: goto jump rem player score if collision(missile0,player1) then score=score+1:player1x=rand/2:player1y=0:missile0y=255 if collision(player0,player1) then score=score-1:player1x=rand/2:player1y=0:missile0y=255:pfscore1 = pfscore1-1 rem if player shields go out go to gameover if !pfscore1=0 then goto gameover jump goto main gameover drawscreen playfield: ................................ ...XXXX..XXX...XXX...XXXX....... ..X.....X...X.X.X.X.X........... ..X..XX.XXXXX.X.X.X.XXX......... ..X...X.X...X.X.X.X.X........... ...XXX..X...X.X...X..XXXX....... ................................ ...XXX..X...X..XXXX.XXXXX....... ..X...X.X...X.X.....X...X....... ..X...X.X...X.XXX...XXXX........ ..X...X..X.X..X.....X...X....... ...XXX....X....XXXX.X...X....... ................................ ................................ ................................ ................................ ................................ ................................ ................................ ................................ ................................ ................................ ................................ ................................ ................................ ................................ ................................ ................................ ................................ ................................ ................................ ................................ end COLUBK = $0F COLUPF = $72 if joy0down then goto gamestart goto gameover end Quote Link to comment Share on other sites More sharing options...
Lewis2907 Posted December 26, 2015 Author Share Posted December 26, 2015 AA Team, I have it sort of working. My issue was that I lost the missiles using "set kernel_options player1colors no_blank_lines pfcolors" so i am using the "ball" in it's place. Player0 is now solid black with no color. I have tried COLUR0, player0color: to change the color but unable to. Also I am trying to incorporate sprites 2-9 to have more enemy and different shapes to fight or innocent bystanders like the car in level 2 driving through. I think if i can work out the above mentioned issues I should be able to add sound then the other stand alone levels I have built. My plan is to have 5 levels (fairly easy to beat) cut sences (eventually work my way up to using titlescreen kernel) and background music for each level with different sound effects. Then I will try to work on a more difficult game that I have in mind. ******Save Earth Complete - Clean Version..txt Quote Link to comment Share on other sites More sharing options...
+Random Terrain Posted December 26, 2015 Share Posted December 26, 2015 You might want to post future bB threads in the batari Basic forum: atariage.com/forums/forum/65-batari-basic/ Quote Link to comment Share on other sites More sharing options...
