Link6415 Posted December 24, 2015 Share Posted December 24, 2015 (edited) Any things I should know about using the device? I know nothing about it other than what it is and does. Edited December 24, 2015 by Link6415 Quote Link to comment Share on other sites More sharing options...
carlsson Posted December 24, 2015 Share Posted December 24, 2015 In case your browser has blocked access to search engines, here is a document to start with: http://www.everythingcommodore.com/download.php?view.1082 Quote Link to comment Share on other sites More sharing options...
Link6415 Posted December 24, 2015 Author Share Posted December 24, 2015 I was just looking for the best guide, and thought I'd ask. Thanks! Quote Link to comment Share on other sites More sharing options...
Link6415 Posted December 25, 2015 Author Share Posted December 25, 2015 Do I have to put .D64s or .prgs on the SD card? And how do you download .prg files anyway? Merry Christmas. Quote Link to comment Share on other sites More sharing options...
7800fan Posted December 25, 2015 Share Posted December 25, 2015 d64 since that is disk image Quote Link to comment Share on other sites More sharing options...
carlsson Posted December 25, 2015 Share Posted December 25, 2015 You can put both types of files on the SD card. The PRG files, you load directly from the card but for the D64 files you need to CD into (think "mount") before you can use them. The C64 very rarely has PRG files, pretty much only on Zimmers' FTP site. However T64 files pretty much are PRG files with an extra header, so any tool to convert between file formats, like cbmconvert will let you convert T64 to PRG without data loss. Quote Link to comment Share on other sites More sharing options...
Link6415 Posted December 25, 2015 Author Share Posted December 25, 2015 I got it. I used dirmaster to take the prgs off the .d64s and put them on the SD card. Quote Link to comment Share on other sites More sharing options...
carlsson Posted December 25, 2015 Share Posted December 25, 2015 Yes, that should work. Consider that for programs that consist of multiple files, you might be better off keeping them as D64 images. Quote Link to comment Share on other sites More sharing options...
Link6415 Posted January 5, 2016 Author Share Posted January 5, 2016 For the D64 files you need to CD into (think "mount") before you can use them. What exactly do you mean? I've been thinking about looking at my current project on actual hardware but it has multiple files and it looks like it will have to remain a .D64. Quote Link to comment Share on other sites More sharing options...
carlsson Posted January 5, 2016 Share Posted January 5, 2016 You put your D64 file(s) on the SD card, then you enter them with a command like this: OPEN 1,8,15:PRINT#1,"CD:IMAGE.D64":CLOSE 1 If you got a fastloader cartridge or other wedge, you can use @"CD:IMAGE.D64" instead of the BASIC commands. Once you want to go back one level, you issue the same command but type "CD:<-", i.e. the back arrow in upper left corner. Quote Link to comment Share on other sites More sharing options...
Link6415 Posted January 6, 2016 Author Share Posted January 6, 2016 Okay, I did @"CD:thewan.d64", and the C64 froze (I assumed it was loading the .d64). It was taking quite a bit of time and after a while, I turned it off so that I could go to bed. Now, I know the C64 is famous for its long load times, but I did have a fast load cart in. Does it normally take a long time or did I do something wrong? Quote Link to comment Share on other sites More sharing options...
carlsson Posted January 6, 2016 Share Posted January 6, 2016 It should be instantaneous, since it just changes the directory of the SD device. You still need to load programs inside the D64 as regular after changing directory. If the computer froze, something must be wrong. Please recap which cartridge and which SD device you're using, in case it would matter. Possibly you might have to get rid of the quotation marks, it depends on the wedge if it can skip those or not. Quote Link to comment Share on other sites More sharing options...
Link6415 Posted January 6, 2016 Author Share Posted January 6, 2016 Epyx Fast Load cart, uIEC/SD. Quote Link to comment Share on other sites More sharing options...
Link6415 Posted January 6, 2016 Author Share Posted January 6, 2016 (edited) Okay, got it! No quotes. Edited January 6, 2016 by Link6415 Quote Link to comment Share on other sites More sharing options...
carlsson Posted January 6, 2016 Share Posted January 6, 2016 Good to know. My Action Replay requires the quotes, mainly because it got a built in @C copying program that otherwise gets invoked. Quote Link to comment Share on other sites More sharing options...
