sodarun Posted January 2, 2016 Share Posted January 2, 2016 Anyone would know what is the best adapter for my Atari ST I will explain better in the following video Quote Link to comment Share on other sites More sharing options...
ParanoidLittleMan Posted January 2, 2016 Share Posted January 2, 2016 It seems like adapter is not set to proper color encoding - NTSC instead PAL. Or it just can not auto detect it properly. This was discussed here many times which adapters are OK for ST. Maybe is better to get monitor what can display Atari directly. 1 Quote Link to comment Share on other sites More sharing options...
leech Posted January 2, 2016 Share Posted January 2, 2016 I just went through this same thing; A) http://www.best-electronics-ca.com/monadapt.htmexplains a lot of it, and they make a cable that works great with some monitors. B) I bought a Dell 2001FP (someone on the wiki found that newer ones (newer than Sept 2005, if I recall) won't work, so you want an older one. Or There is a huge thread about the NEC MultiSync LCD 1970VX working great as well. (I'll probably end up picking one up soonish to see which is better). http://atariage.com/forums/topic/230561-lcd-monitor-that-supports-st-low-res-nec-multisync-lcd-1970vx/ Your ST looks worse than my 1040ST, which just has what appears to be vertical lines missing. Good luck, hopefully it's just a cable/monitor issue. Quote Link to comment Share on other sites More sharing options...
presario123x Posted January 9, 2016 Share Posted January 9, 2016 (edited) That image I see in your video is exactly how I see any PAL device connected to my NTSC-only TV This is what I use to display PAL on my NTSC TV: http://www.ebay.com/itm/Mini-RCA-AV-to-HDMI-Converter-Adapter-Composite-AV2HDMI-Converter-1080P-DVD-J-/151683142490?hash=item235105135a:g:9-sAAOSw3xJVVxb4 It works absolutely great, and it's dirt cheap. I use this little device for all my Atari/Commodore/Sega...etc systems to hook them up to my NTSC TV, and it works great with PAL signals. It's sharp and clear. Edited January 9, 2016 by presario123x 1 Quote Link to comment Share on other sites More sharing options...
