Modding the JVC TM-A13SU Monitor
Bryan
Here's the install pics. The chip is glued on its back. Pin 1 is the unconnected reset pin. 7 wires and 2 270ohm resistors are needed to complete the installation. The good news is no traces need to be cut.
The install points are:
Pin 2 - Read Buttons (W067)
The buttons are connected through a resistor network (actually, they're divided among 3 networks) so different voltages are produced depending on which button is pressed. This is how a single wire can read 3 buttons.
Pin 3 - LED (R806)
This line is connected to a 270ohm resistor that pulls the LED voltage down to where it doesn't illuminate.
Pin 4 - GND (C704)
Pin 5 - SDA (D292)
I2C Data pin. Also connected with a 270ohm which allows data into the TB1226 to be pulled to logic hi or low.
Pin 6 - COMB FILTER (IC202 - p3)
The JVC's microcontroller turns off the COMB filter module by pulling this line low. The output is open-collector so we can pull it low too without a problem.
Pin 7 - SCK (D291)
I2C Clock pin.
Pin 8 - VCC (IC701 p5)
I'm trying to get some pictures of how much better APAC looks in NTSC with blending on. I took these two pics, but the difference is actually even greater. I can now switch between modes.
I'm using bugbiter's APAC viewer.
  • 4 months later...
Does anyone happen to know where these 2 little magnets attach? They were loose and not attached to anything. I assume they're convergence magnets.
Weird, I haven't seen them in my monitors. Maybe a last-minute tweak? Can you see evidence of the adhesive (or a less-dusty spot) on the tube?
Hello, can you help me get this chip programmed? It's been a while since I've programmed chips. Which programmer are you using? I'm using the TL866 with the MiniPro software. I have the fuse bits for the chip set properly (http://www.engbedded.com/fusecalc/), but I think I'm looking for a bin file that isn't there. I'm not sure which file to upload to the code and data fields.
Edited by MitchSchaft
Wow, looks nice. I've been using this model for a few years. May be looking to replace it. Makes a high pitch sound that my wife and son can hear, but not I ☺
I have seen this before with bad capacitors. Which reminds me I need to replace the caps on an Electrohome monitor in my PacMan cab. Flyback transformer could be a culprit also. With the low cost of this JVC monitor though I wouldn't spend much to repair.
Edited by Brentarian
Ok, I got the chip programmed finally. The monitor works fine and the LED turns on when I hit the Phase button. It stays off the rest of the time. But, that's the only thing that happens. I don't get any flashing when I hold buttons down for 3 seconds. I don't notice anything happening to the screen either. I get proper voltages at each pin so I'm not sure what I messed up.
I went the long way with my install. Do you think the way I did it caused problems or maybe an issue with flashing the chip? I tried 3 different chips. I selected the hex file and the elf file from your .zip when I programmed it.
Somewhere I have a spare programmed chip. I'll see if I can find it. I wish I'd written down the fuse bytes rather than the options. Mostly, we need to make sure the internal oscillator is working and that the clock is not being divided.
I found the programmed chips in case you need one.
The next mod I'd like to work on is a power supply upgrade so bright areas of the screen don't cause any bending of the picture. This is a pretty common problem with CRT monitors, where the voltage sags when the guns are driven hard.
