+OLD CS1 Posted January 26, 2016 Share Posted January 26, 2016 Someone here knows how to do that. I remember reading it, but I cannot find you. Please raise your hand! I want to put together a little audio demo but I need two wavs converted into something I can feed the speech synthesizer while playing music. (I guess I also need to go check out the development sticky.) Quote Link to comment Share on other sites More sharing options...
Tursi Posted January 26, 2016 Share Posted January 26, 2016 You want to hit up Willsy Quote Link to comment Share on other sites More sharing options...
+OLD CS1 Posted January 26, 2016 Author Share Posted January 26, 2016 You want to hit up Willsy Tah... oh, Mr. WILLLLLLSYYYYYYYYYY. (Anyone else remember Dennis the Menace?) Quote Link to comment Share on other sites More sharing options...
sometimes99er Posted January 26, 2016 Share Posted January 26, 2016 2 Quote Link to comment Share on other sites More sharing options...
+Ksarul Posted January 26, 2016 Share Posted January 26, 2016 I think Mr. Wilson had gone clinically insane by the time Dennis grew up. . . 1 Quote Link to comment Share on other sites More sharing options...
Asmusr Posted January 26, 2016 Share Posted January 26, 2016 When I try to run QBOX it gives the warning "No coding table in project" and I can't get any further. The qv5220.cod file is present in c:\QBOX. This is in Windows XP. Edit: Never mind, just had to copy QBOXPRO.INI into c:\windows. QBOX.zip 1 Quote Link to comment Share on other sites More sharing options...
Willsy Posted January 26, 2016 Share Posted January 26, 2016 I can look at it at the weekend if you want. Speech is (for me) by far the most interesting feature of the 4A. 1 Quote Link to comment Share on other sites More sharing options...
+OLD CS1 Posted January 27, 2016 Author Share Posted January 27, 2016 Actually, I figured out how to get QBox running on my Windows 7 machine using XP Mode, so I am giving it a go, myself. Thank you, though. If you do not mind, I will check in if I have any problems. (Like Rasmus, I found I had to copy qbox.ini to C:\Windows in the XP Mode guest.) For anyone who wants to use XP Mode, I found one niggling little problem: you cannot see the host machine's drives, and mapped drives (like Z: to \\tsclient\d) does not show up in QBox. I wonder if it has anything to do with the 16-bit interface. To move files back-and-forth from XP Mode guest to host I had to publish Explorer.exe by, in the guest, using regedit.exe to remove the exclusion from the Virtual PC application publishing, restart, then copy the Windows Explorer shortcut to the %allusersprofile%\Start Menu\Programs directory. Now I can open Windows Explorer in an XP Mode virtual application which can see the host's drives. Quote Link to comment Share on other sites More sharing options...
+OLD CS1 Posted January 27, 2016 Author Share Posted January 27, 2016 Actually, one quick question: is there code anywhere to make the speech interrupt-driven? Quote Link to comment Share on other sites More sharing options...
