Geoff Oltmans Posted January 27, 2016 Share Posted January 27, 2016 Hey guys... I'm looking for a few willing testers for this version of Adamem/SDL. So far only the OS X version, but Raspberry Pi and Win32 versions will be coming soon. This adds: Support for two joysticks. All real ColecoVision controllers are supported with the use of the Ultimate PC Interface, including Driving controller, Roller Controller, and Super Action Controller. Any USB joysticks can be supported however, and each button remapped via adamem.joy file. Fix for lock up issue when running emulator for ~30 minutes Added 720p and 1080p video modes Fixes for GUI interface Some sound emulation improvements ROM images can be loaded and emulator started by clicking ROM image in finder (you must start game by doing a Game Reset) Installer package ...a few other things... Let me know if you have trouble. Adamem_1.9.dmg.zip 1 Quote Link to comment Share on other sites More sharing options...
LoTonah Posted January 27, 2016 Share Posted January 27, 2016 Yes! Setting up now (too late to work on it, though). Also will install on the MacBook tomorrow. Quote Link to comment Share on other sites More sharing options...
LoTonah Posted January 27, 2016 Share Posted January 27, 2016 Oops. As soon as I launch the installed program, my mouse goes crazy and is confined to an invisible section about 1 inch squared, just off the lower-right hand corner of the emulator window. Alt-Tab to another app, and the mouse is fine. Quote Link to comment Share on other sites More sharing options...
Geoff Oltmans Posted January 27, 2016 Author Share Posted January 27, 2016 Oops. As soon as I launch the installed program, my mouse goes crazy and is confined to an invisible section about 1 inch squared, just off the lower-right hand corner of the emulator window. Alt-Tab to another app, and the mouse is fine. I should explain that... that is by design currently. I had to do that in order to support the spinner/roller controller emulation. Ideally I'd prefer not to but for now it'll have to do until I (or someone else) can figure out another solution. It will do this until you pause the emulator or as you say, command-tab to another app. To pause the emulator, use command-. (period) and then you can get to the menus. Quote Link to comment Share on other sites More sharing options...
Geoff Oltmans Posted January 27, 2016 Author Share Posted January 27, 2016 Opening the preferences or open file window with the keyboard will also free the mouse... Command-, and Command-O respectively. Quote Link to comment Share on other sites More sharing options...
Geoff Oltmans Posted January 27, 2016 Author Share Posted January 27, 2016 (edited) Here's a copy of the documentation... The GUI is a work in progress. Some of the options do not take effect immediately, but saving the changes will write out a new config in {home]/Library/Application Support/Adamem for the next time you start the emulator. Any of the normal command line switches that are mentioned in the documentation will work with the OS X version as options in the config file, but you will have to hand-edit these for now (also note that the changes will be overwritten if you go back to the preferences menu and apply those changes). Same for the joystick mapping file, which is located in the same directory (if it exists). The format of this file is explained in the documentation and you can change it how you see fit. adamem.txt Edited January 27, 2016 by Geoff Oltmans Quote Link to comment Share on other sites More sharing options...
AnnaWu Posted January 27, 2016 Share Posted January 27, 2016 -idea <filename> - Select ide master hard drive image to use [hd_ide1.img]-ideb <filename> - Select ide slave hard drive image to use [hd_ide2.img] Sounds nice, Geoff Oltmans. Is it possible to upload a hard drive image as an example? Quote Link to comment Share on other sites More sharing options...
Geoff Oltmans Posted January 27, 2016 Author Share Posted January 27, 2016 Check this thread... I believe there are some posted here... http://atariage.com/forums/topic/202664-new-idecompact-flash-interface-for-adam/ Quote Link to comment Share on other sites More sharing options...
telengard Posted December 23, 2019 Share Posted December 23, 2019 Were the other platforms (other than Mac) ever released with these updates? Quote Link to comment Share on other sites More sharing options...
Geoff Oltmans Posted December 27, 2019 Author Share Posted December 27, 2019 On 12/23/2019 at 4:38 PM, telengard said: Were the other platforms (other than Mac) ever released with these updates? Not yet. I ran into issues with the Windows compiler and got sidetracked on other more interesting stuff at the time. Santa brought me a new Windows 10 laptop though, so I'm raring to give it another go. Finally, 2020 may be the first "official" release. 2 Quote Link to comment Share on other sites More sharing options...
LoTonah Posted December 28, 2019 Share Posted December 28, 2019 12 hours ago, Geoff Oltmans said: Not yet. I ran into issues with the Windows compiler and got sidetracked on other more interesting stuff at the time. Santa brought me a new Windows 10 laptop though, so I'm raring to give it another go. Finally, 2020 may be the first "official" release. It didn't bug me much at the time that it was Mac only, but when I finally took the rose-colored glasses off and saw what shite Mojave was, I am now 80% back in Windows land (still have one laptop and one iMac at the shop). I look forward to you getting the bugs worked out Quote Link to comment Share on other sites More sharing options...
