Marius Posted February 20, 2016 Share Posted February 20, 2016 Hi All, In the past I have succesfully played with Atari800Mac and the Stelladaptor. Today I wanted to give it another try, and it does not work. The stelladaptor is detected in the emulator as "Gamepad" and I can test it. It indeed recognizes the joystickbutton when I do the "test" in preferences. but... in the controller window I can not set Joystick 1 to Gamepad 1 since that is and stays greyed out, not matter what setting I try. So inside the emulator, when the 'atari' is running, the joystick isn't seen, which makes sense, since I was not able to mount the joystick to gamepad 1. Since I have been using this in the past on Tiger (OS X 10.4.11) I'm pretty sure it is something with Mountain Lion 10.8.5 Anyone have a solution for this? Thanks Marius Quote Link to comment Share on other sites More sharing options...
Marius Posted February 20, 2016 Author Share Posted February 20, 2016 Ah... I did repair permissions, and now I can select Gamepad1 in the joysticks settings window. Now it works. Quote Link to comment Share on other sites More sharing options...
