Caterpiggle Posted March 1, 2016 Share Posted March 1, 2016 Hello to all, I would like to know if I may replace 220 volts internal power supply on 1551 from 1541 disk drive 110 volts internal power supply. Will it work on 1551 disk drive if replace for 110 volts ? Please let me know if it will work ? Quote Link to comment Share on other sites More sharing options...
carlsson Posted March 1, 2016 Share Posted March 1, 2016 Yes, it is supposed to be painless. However some people worry about the value of the 1551 after you swapped power supply. Done nicely, you might be able to revert it in case you're going to sell it for $$$ later on. See this recent thread on Lemon64: http://www.lemon64.com/forum/viewtopic.php?t=59436 Quote Link to comment Share on other sites More sharing options...
RobertB Posted March 2, 2016 Share Posted March 2, 2016 I would like to know if I may replace 220 volts internal power supply on 1551 from 1541 disk drive 110 volts internal power supply. Will it work on 1551 disk drive if replace for 110 volts ? Yes, I had the 1551 which I brought back from England modded to take the North American p.s., and it works perfectly. Truly, Robert Bernardo Fresno Commodore User Group http://www.dickestel.com/fcug.htm Quote Link to comment Share on other sites More sharing options...
Caterpiggle Posted March 2, 2016 Author Share Posted March 2, 2016 Is possible for you to take a picture inside 1551 with PS 110 volts ? I undy, it also need to change from 250 volts fuse to 130 (?) volts fuse ? Same 3 or 4 plugs inside on both 1551&1541 ? Thank you ... Quote Link to comment Share on other sites More sharing options...
