David Baldwin Posted March 2, 2016 Share Posted March 2, 2016 Hi I have a Macintosh Plus with System 7.1 installed and Microsoft Soft Works 3. Can I use my Lantronix Modem with MS works comms program I brought a serial cable to use with the mac plus. The comms icon is unable to open at the moment will the comms program work with the Lantronix Device, has anyone got it to work. David B Quote Link to comment Share on other sites More sharing options...
rpiguy9907 Posted March 3, 2016 Share Posted March 3, 2016 (edited) If you don't get an answer here, try the Macintosh 68K Liberation Army forums. They are a great community for these kinds of questions. Edited March 3, 2016 by rpiguy9907 Quote Link to comment Share on other sites More sharing options...
David Baldwin Posted March 3, 2016 Author Share Posted March 3, 2016 thanks ill see if i get comments here first. Quote Link to comment Share on other sites More sharing options...
Muzz73 Posted March 3, 2016 Share Posted March 3, 2016 Off topic here, but have you upgraded it to 4MB RAM? Handy for System 7.1, especially for caching and a RAM disk... Quote Link to comment Share on other sites More sharing options...
Osgeld Posted March 4, 2016 Share Posted March 4, 2016 (edited) Should work as long as you have a terminal program and appropriate cabling And I had a lantronix uds10 on my se Edited March 4, 2016 by Osgeld Quote Link to comment Share on other sites More sharing options...
David Baldwin Posted March 4, 2016 Author Share Posted March 4, 2016 Yes it has 4 MB of ram in it. I did try it with my Lantronix the comms program in old ms works did not work it faild to open. Im looking out for more Comms programs for the Plus to use. Quote Link to comment Share on other sites More sharing options...
Osgeld Posted March 4, 2016 Share Posted March 4, 2016 Zterm and I forget if I needed a null modem cable or not its been a while Quote Link to comment Share on other sites More sharing options...
David Baldwin Posted March 4, 2016 Author Share Posted March 4, 2016 Zterm is the one to use yes. Quote Link to comment Share on other sites More sharing options...
Osgeld Posted March 5, 2016 Share Posted March 5, 2016 (edited) if it needs a null modem cable (aka crossover) and your running a 1:1 straight though cable (ie the RX and TX pins are not crossed over) orce vice versa it doesnt matter which terminal program you use as its talking into a deaf ear check the documentation on the specific device but yes get zterm, for the mac its the perfect basic but yet full featured terminal program you can get and runs on just about anything up to OSX and beyond Edited March 5, 2016 by Osgeld Quote Link to comment Share on other sites More sharing options...
David Baldwin Posted March 5, 2016 Author Share Posted March 5, 2016 i have a serial port cable for the mac plus mini dim 8 to 25 pin i do have a null modem cable to shell i put that between the lantronix modem and serial cable to the mac. Quote Link to comment Share on other sites More sharing options...
David Baldwin Posted March 5, 2016 Author Share Posted March 5, 2016 is there anything to setup up in the systems in system 7.1 for the modem port to work or shell i just put the mac away again put a 486 in its place Quote Link to comment Share on other sites More sharing options...
Osgeld Posted March 5, 2016 Share Posted March 5, 2016 nope there is nothing in 7.1 to setup a serial port, load coms and off you go at this point I say check your cable, and try running it form a modern machine with RS232 serial to make sure the problem is not the device Quote Link to comment Share on other sites More sharing options...
Muzz73 Posted March 11, 2016 Share Posted March 11, 2016 (edited) You also might need to check the handshaking settings... the 8-pin mini DIN that they started using on the Mac Plus is a non-hardware handshaking serial port, so sometimes a non-hardware handshaking cable might be required for higher speeds. I seem to remember a buddy's girlfriend having an issue with that back in the day. Can anyone confirm this? I haven't had to deal with that issue in over 20 years! Edited March 11, 2016 by Muzz73 Quote Link to comment Share on other sites More sharing options...
David Baldwin Posted March 12, 2016 Author Share Posted March 12, 2016 The Mac plus is put away again ill get it out when i get a copy of Zterm for it. Quote Link to comment Share on other sites More sharing options...
