theatarifan Posted March 27, 2016 Share Posted March 27, 2016 Now i got video but no sound n video static im using av cable white n yellow? Quote Link to comment Share on other sites More sharing options...
F4LL3N Posted March 27, 2016 Share Posted March 27, 2016 You should have a red cable too - do you get any sound through either speaker? Quote Link to comment Share on other sites More sharing options...
theatarifan Posted March 27, 2016 Share Posted March 27, 2016 Weird when i do put in red cable there is no video but when i take out the red cable its static with no sound? Quote Link to comment Share on other sites More sharing options...
F4LL3N Posted March 27, 2016 Share Posted March 27, 2016 Very odd, do you get sound through the red cable without the yellow (video) cable in? Is it an official Atari Jaguar composite video cable? Quote Link to comment Share on other sites More sharing options...
theatarifan Posted March 27, 2016 Share Posted March 27, 2016 (edited) No sound and im not sure of if its officially it looks officially? Edited March 27, 2016 by theatarifan Quote Link to comment Share on other sites More sharing options...
Serblander Posted March 29, 2016 Share Posted March 29, 2016 Great news indeed except now you will need to change your user name! Quote Link to comment Share on other sites More sharing options...
F4LL3N Posted May 3, 2016 Share Posted May 3, 2016 Hey all, sorry to re-hash an old(ish) post. I decided to take the jaguar apart to see if there was anything obvious that might be a problem. Noticed everything is onboard, no real ribbon cables or connectors of any description. I've attached some pictures - does anything look odd to anyone? Just to add - all capacitors look OK, no bulges. Quote Link to comment Share on other sites More sharing options...
Shamus Posted May 4, 2016 Share Posted May 4, 2016 Not sure if this will help you or not, but I had some traces on my Jaguar's PCB literally rot out (due to humidity? have no idea really why). I had to solder in some jumper wires to make it work again. So you might want to look at the traces to make sure that they're all good and solid, assuming that all of the other components look good. Quote Link to comment Share on other sites More sharing options...
F4LL3N Posted May 4, 2016 Share Posted May 4, 2016 Thanks for that. In which area did you experience the problem and Ill start there. I've never done any soldering on consoles so its a bit of a nervy area for me! There are 3 bits of solder that look like hooks on it too (as per the pictures). Are they normal? Quote Link to comment Share on other sites More sharing options...
Zerosquare Posted May 4, 2016 Share Posted May 4, 2016 There are 3 bits of solder that look like hooks on it too (as per the pictures). Are they normal? Yeah. They're contacts to the metal case. Quote Link to comment Share on other sites More sharing options...
F4LL3N Posted May 4, 2016 Share Posted May 4, 2016 Yeah. They're contacts to the metal case. Thanks. They just seem really out of place! Quote Link to comment Share on other sites More sharing options...
Shamus Posted May 5, 2016 Share Posted May 5, 2016 (edited) It was on the side of the board with the cart connector, on the right side near the cart connector. Here's what it looked like: Of course, if you do have that problem, it will probably be on some other part of the board. Edited May 5, 2016 by Shamus Quote Link to comment Share on other sites More sharing options...
walter_J64bit Posted May 5, 2016 Share Posted May 5, 2016 D'oh! Quote Link to comment Share on other sites More sharing options...
F4LL3N Posted May 5, 2016 Share Posted May 5, 2016 It was on the side of the board with the cart connector, on the right side near the cart connector. Here's what it looked like: Of course, if you do have that problem, it will probably be on some other part of the board. Thanks for that. I'll have a look later and try and get some pictures to post up Quote Link to comment Share on other sites More sharing options...
F4LL3N Posted May 12, 2016 Share Posted May 12, 2016 Hi all, Little updated for you. Ive had a look at the traces around the AV connectors, they look a bit suspect. The RF connectors are harder to work out. I've ordered an RF lead to try that and see if we get anything on the screen if so I'll post my findings. All the best Quote Link to comment Share on other sites More sharing options...
F4LL3N Posted May 17, 2016 Share Posted May 17, 2016 OK so the RF lead has turned up and I have discovered something rather odd. The RF input on the back of the Jaguar is too small to plug in the RF lead. I tried another Jaguar (fully working) and the input is the right size so no problems plugging it in. Any ideas?? They look pretty identical at the back, but the input is too small. Quote Link to comment Share on other sites More sharing options...
Lechuck333 Posted May 18, 2016 Share Posted May 18, 2016 (edited) Add me to this list. Atari powers on with a game, but no audio or video. Not even a red screen. Nothing. I've tried through RF and RGB Scart to a PVM and the XRGB Mini. I've used multiple power adapters (one fro retrodcpowered.com and a Genesis model 1 adapter). Powers on and the LED isn't dim. Also nothing visibly has blown on the board. No idea where to go from here now. Edited May 18, 2016 by Lechuck333 Quote Link to comment Share on other sites More sharing options...
m2carb Posted July 20, 2018 Share Posted July 20, 2018 I just picked up a Jaguar that was listed as, may not work, can't test , etc from EBay. Unit powers up, but no audio or video output, cleaned the connector for the cartridge, verified power supply, cable RF and AV composite cable, nothing, All of hte cables, and cartridges work in my other Jaguar. Any ideas? Quote Link to comment Share on other sites More sharing options...
Gummy Bear Posted July 20, 2018 Share Posted July 20, 2018 "Untested" on ebay translates to "doesn't work" 3 Quote Link to comment Share on other sites More sharing options...
