+jedimatt42 Posted June 12, 2016 Share Posted June 12, 2016 I would like to know when the next OSHpark order for v2 boards is going to happen. I would like to go in with you and get a couple boards. Also I'd like to know if the parts list changed. I believe I downloaded it when it was posted last time. I am going to try my hand at building my own this time. But I would like the purple boards. :-) Darryl I'm guilty of making purple rev 1 boards, but I just made the minimum OSHPark batch of 3. I also exported the gerbers following some OSHPark instructions, but I see they actually take the KiCad pcb file directly as documented here: http://docs.oshpark.com/design-tools/kicad/ <- I didn't know that at the time. I don't have any plans to run any more pcboards. I only ran some for my own use. -M@ Quote Link to comment Share on other sites More sharing options...
+Ksarul Posted June 12, 2016 Share Posted June 12, 2016 I Ralph approves it, you could also make the board project at OshPark publicly visible, which would allow others to order the purple boards. Doing it that way is more expensive than buying from a larger board order, but the purple ones do look soooooo nice. . . 1 Quote Link to comment Share on other sites More sharing options...
ralphb Posted June 12, 2016 Author Share Posted June 12, 2016 you could also make the board project at OshPark publicly visible Sure, go ahead, but please update the project to use board revision 2! Quote Link to comment Share on other sites More sharing options...
+evg2000 Posted June 12, 2016 Share Posted June 12, 2016 I received my kit the other day, now I'm just waiting for some dip sockets before I do the install. Thanks for creating this Ralph. 1 Quote Link to comment Share on other sites More sharing options...
+jedimatt42 Posted June 12, 2016 Share Posted June 12, 2016 Sure, go ahead, but please update the project to use board revision 2! Done. permalink: https://oshpark.com/shared_projects/SJstICiA Listed as: endlos99-flashrom99-rev2-TI-99 This board was designed by Ralph Benzinger. The cartridge allows playing ROM images stored on an SD card on an unexpanded TI 99/4A, and so much more with an expanded TI. For complete details see the homepage -M@ 4 Quote Link to comment Share on other sites More sharing options...
+chicgamer Posted June 12, 2016 Share Posted June 12, 2016 Sorry to hear that. Your SD seems to work just fine. If that were the issue you'd get the Red Blinking of Death (or whatever your color of LED is). The first thing to do is try the Bank Test: banktest.bin Then we'll see from there. (My first guess is that you're using bad images -- see here for a collection of good ones.) Thanks, I'll try this out! The images I'm using are from the TI Gamebase from TI Game Shelf. I'm wondering if part of the reason I'm having issues is that I haven't expanded my TI-99's memory (yet—the parts will be shipped out next week). A few games have worked for me, but most haven't. Does it take 32K to run games like Pac-Man, Ms Pac-Man, Dig-Dug, and Donkey Kong? Quote Link to comment Share on other sites More sharing options...
dphirschler Posted June 12, 2016 Share Posted June 12, 2016 Who wants to go in with me to get a purple v2 board? I only want one... maybe two. Darryl 1 Quote Link to comment Share on other sites More sharing options...
+jedimatt42 Posted June 12, 2016 Share Posted June 12, 2016 Thanks, I'll try this out! The images I'm using are from the TI Gamebase from TI Game Shelf. I'm wondering if part of the reason I'm having issues is that I haven't expanded my TI-99's memory (yet—the parts will be shipped out next week). A few games have worked for me, but most haven't. Does it take 32K to run games like Pac-Man, Ms Pac-Man, Dig-Dug, and Donkey Kong? You want the images from here then: http://ftp.whtech.com/Cartridges/joined/ Most of those will run on an unexpanded system, just like the original cartridges from Atari and others. Unzip those files onto your sdcard, and you should have a large menu of mostly games.. -M@ 1 Quote Link to comment Share on other sites More sharing options...
+chicgamer Posted June 12, 2016 Share Posted June 12, 2016 Those worked! Thanks so much! 4 Quote Link to comment Share on other sites More sharing options...
+acadiel Posted June 13, 2016 Share Posted June 13, 2016 Those worked! Thanks so much! Yep, you run into two types of ROM images in this community. Legacy ones, which are inverted (8K segments start with highest 8K all the way down to the lowest 8K - i.e. DCBA), and the regular non inverted ones, which have become more a standard, because they're easier to work with (i.e. ABCD). The flash cart only works with non inverted ones. A few different ways to handle... download the non inverted ones that someone already flipped, run a non invert program (it's in this forum somewhere), or get a hex editor handy and start with the last 8K bank and start pasting to a new file, working backward. 1 Quote Link to comment Share on other sites More sharing options...
+arcadeshopper Posted June 13, 2016 Share Posted June 13, 2016 Who wants to go in with me to get a purple v2 board? I only want one... maybe two. Darryl send me your extras 1 Quote Link to comment Share on other sites More sharing options...
Omega-TI Posted June 13, 2016 Share Posted June 13, 2016 I have considered putting rubber feet on the bottom of mine as I figured they would give it more support for pressing the reset button as well lessen the load on the port. I'm just using the bottom-half of a standard TI case until Ksarul is ready to release his case based on the Romox case. It seems to work fine. 2 Quote Link to comment Share on other sites More sharing options...
dphirschler Posted June 14, 2016 Share Posted June 14, 2016 Is that gravity holding it in there? Darryl 1 Quote Link to comment Share on other sites More sharing options...
wyerd Posted June 15, 2016 Share Posted June 15, 2016 Just got round to solder in the parts I ordered from Mouser to the board - and it works!! The memory routine checked out okay, once I removed the firehose extension cable from the mix - the board doesn't like it. This piece of hardware is REVOLUTIONARY for the TI world! Thanks again Ralph. A closer look at the cart reveals my amateur soldering skills - I didn't check the alignment of the SD card adapter when I was soldering the pins. De-soldering it looks tricky as the pins are so close together. Any words of advice from the pros? Now, how do get TI Invaders, Parsec, Titanium & Road Hunter on the SD card? 3 Quote Link to comment Share on other sites More sharing options...
Omega-TI Posted June 15, 2016 Share Posted June 15, 2016 Just got round to solder in the parts I ordered from Mouser to the board - and it works!! CONGRATULATIONS! 1 Quote Link to comment Share on other sites More sharing options...
+arcadeshopper Posted June 15, 2016 Share Posted June 15, 2016 Just got round to solder in the parts I ordered from Mouser to the board - and it works!! The memory routine checked out okay, once I removed the firehose extension cable from the mix - the board doesn't like it. This piece of hardware is REVOLUTIONARY for the TI world! Thanks again Ralph. A closer look at the cart reveals my amateur soldering skills - I didn't check the alignment of the SD card adapter when I was soldering the pins. De-soldering it looks tricky as the pins are so close together. Any words of advice from the pros? Now, how do get TI Invaders, Parsec, Titanium & Road Hunter on the SD card? go to ftp.whtech.com/cartridges/joined and unzip those two files onto your sdcard.. boot wait for light then hit any key and pick the selection and you should get a list of everything Quote Link to comment Share on other sites More sharing options...
+jedimatt42 Posted June 15, 2016 Share Posted June 15, 2016 A closer look at the cart reveals my amateur soldering skills - I didn't check the alignment of the SD card adapter when I was soldering the pins. De-soldering it looks tricky as the pins are so close together. Any words of advice from the pros? I finally built my 3rd yesterday using the full size SDCard SPI adapter, and it struck me as tough to get the SPI adapter to feel like it was level/parallel to the cartridge board. The solder tips from my pushbutton might not have been even. In the end I settled for fairly square against the headers and their spacer. Your board doesn't look bad from the photo. If you really want to desolder, you'd probably need to work with solder-braid. It works a bit like a sponge for solder. But all in all, if cases are made for these, I think they will have to include some variability in the window for the SDCard. Now, how do get TI Invaders, Parsec, Titanium & Road Hunter on the SD card? Road Hunter is too big for a 32k ROM image. -M@ 2 Quote Link to comment Share on other sites More sharing options...
Omega-TI Posted June 15, 2016 Share Posted June 15, 2016 go to ftp.whtech.com/cartridges/joined and unzip those two files onto your sdcard.. boot wait for light then hit any key and pick the selection and you should get a list of everything I don't think those files have been converted yet. From the looks of his menu, he's found those zip files already. Quote Link to comment Share on other sites More sharing options...
+arcadeshopper Posted June 15, 2016 Share Posted June 15, 2016 I don't think those files have been converted yet. From the looks of his menu, he's found those zip files already. 2 Quote Link to comment Share on other sites More sharing options...
wyerd Posted June 16, 2016 Share Posted June 16, 2016 I don't think those files have been converted yet. From the looks of his menu, he's found those zip files already. So much to play around with, I don't know where to start 2 Quote Link to comment Share on other sites More sharing options...
+Schmitzi Posted June 16, 2016 Share Posted June 16, 2016 you could plug in the soldering iron Quote Link to comment Share on other sites More sharing options...
Omega-TI Posted June 16, 2016 Share Posted June 16, 2016 So much to play around with, I don't know where to start << HERE >> is an excellent place to start! 1 Quote Link to comment Share on other sites More sharing options...
wyerd Posted June 16, 2016 Share Posted June 16, 2016 Now, how do get TI Invaders, Parsec, Titanium & Road Hunter on the SD card? Looks like Jedimatt42 has been a busy squirrel and converted Parsec. Thank you 1 Quote Link to comment Share on other sites More sharing options...
wyerd Posted June 16, 2016 Share Posted June 16, 2016 << HERE >> is an excellent place to start! That's what I mean, there's sooooooooooo much choice! 1 Quote Link to comment Share on other sites More sharing options...
Omega-TI Posted June 16, 2016 Share Posted June 16, 2016 That's what I mean, there's sooooooooooo much choice! Yep, by why choose? GET IT ALL! 1 Quote Link to comment Share on other sites More sharing options...
