ceratophyllum Posted April 3, 2016 Share Posted April 3, 2016 (edited) I'm using MESS 0.160 on amd64 linux. So I started Drivewire 4, threw a couple of DSK image files at it and then ran MESS from the command line and it says: mess coco2 Connecting to Drivewire server on 127.0.0.1:65504... Connected! I then selected hdbcc2.wav from here in the File Manager GUI and attached it as a cassette and then did CLOADM:EXEC HDB-DOS appeared to load without any problems. But all I get is: DIR ?IO ERROR Edited April 3, 2016 by ceratophyllum Quote Link to comment Share on other sites More sharing options...
ceratophyllum Posted April 4, 2016 Author Share Posted April 4, 2016 Figured out the problem: HDB-DOS version hell. version 1.1D and some 1.4 rom I found in a windows port of xroar did nothing at all or gave errors when I attempted to use them with Drivewire 4. Only hdbdw3bck.rom from Toolshed would work. The ones from Cloud9 did not work. md5sum of the above rom: ef750d93d24d7bc87a8ecd6e5a15a845 To get Drivewire 4 working in MESS, make sure the Becker port is enabled. (It was by default on my MESS, but check the GUI settings.) Quote Link to comment Share on other sites More sharing options...
