Diecrusher Posted April 4, 2016 Share Posted April 4, 2016 (edited) I recently acquired a HxC rev. F. I am having trouble getting it recognized as DSK3 when hooking it up the the TI FDC edge connector. In the PEB I already have a TEAC 55B 5.25" floppy configured as DSK1 and a 720K 3.5" floppy configured as DSK2 and they work just fine. I believe that I have the SD card setup correctly. The first file copied to the SD card was the config file and I've tried a couple of the pre-configured HxC TI disk images found here on AtariAge. The HxC seems to be able to select between these images but when trying to catalog the disk with Disk Manager 2 I get error 16. I've tried flipping the way the cable edge connector is connected to the FDC's external edge connector but the results are the same. There is no twist in the cable. I've numerous jumper settings set for 1 drive only. Termination trouble? Firmware issue? Any ideas appreciated! Edited April 4, 2016 by Diecrusher Quote Link to comment Share on other sites More sharing options...
+arcadeshopper Posted April 4, 2016 Share Posted April 4, 2016 do you have the drive selector on the hxc set to dsk2? it starts at 0 right? 0 1 2 = DSK3 if you have it on 3 it would be DSK4 pin1 is clearly defined on the board, and is the end with the key-slot on it on the ti controller external card edge Greg 1 Quote Link to comment Share on other sites More sharing options...
Diecrusher Posted April 4, 2016 Author Share Posted April 4, 2016 Thanks Greg! I rechecked the jumpers and it must have not been totally in the right position. I rechecked and all is good now. One additional question now. Is there anyway to get the Rasmus game compilation to autoboot from DSK3? I've tried OLD DSK3.LOAD and it just crashes back to the TI boot screen..... I am such a noob. 1 Quote Link to comment Share on other sites More sharing options...
+arcadeshopper Posted April 4, 2016 Share Posted April 4, 2016 Thanks Greg! I rechecked the jumpers and it must have not been totally in the right position. I rechecked and all is good now. One additional question now. Is there anyway to get the Rasmus game compilation to autoboot from DSK3? I've tried OLD DSK3.LOAD and it just crashes back to the TI boot screen..... I am such a noob. I'll have to look at the disk you are referring too. But likely the load program is coded in basic to use DSK1 you may be able to edit the program to use DSK3 instead probably just by replacing the number.. Another good way to go would be to load DM2K and just run the programs from there by cataloging dsk3 and selecting the first file for whatever game they are usually like flappyb flappyc flappyd so you'd pick the first one Greg Quote Link to comment Share on other sites More sharing options...
Asmusr Posted April 4, 2016 Share Posted April 4, 2016 If we're talking about this disk that uses BOOT then it's not enough to modify LOAD - you also need to change each item in the BOOT menu to use DSK3 (sorry, don't remember how to do that). Quote Link to comment Share on other sites More sharing options...
Omega-TI Posted April 5, 2016 Share Posted April 5, 2016 If we're talking about this disk that uses BOOT then it's not enough to modify LOAD - you also need to change each item in the BOOT menu to use DSK3 (sorry, don't remember how to do that). Here is the documentation... BOOT-Documentation.pdf Quote Link to comment Share on other sites More sharing options...
