ckoba Posted April 21, 2016 Share Posted April 21, 2016 So I have a lot of accumulated gear downstairs. Most of it tends to be cast-offs from various places I've worked (I had a wall of SGI workstations at one point, a Sun E250, and a bunch of sun4ms). Every two years or so, my wife tours my side of the basement with me and asks me what X device is used for. If I can't come up with a reasonable answer, it gets pitched in the trash. (She doesn't touch the VW parts -- she knows how hard it is to get even Brazil-made parts nowadays for a Type-III) She's probably going to do the same thing in the next few weeks ... so I've been going through the bits-and-bobs boxes and winnowing the useful stuff. I had a few different models of parallel->serial converters. Centronics on one end, DB25 on the other, and they worked. Since parallel printers are effectively unobtainable in the retail channel at this point, I decided to leverage the BBB-based tape player emulator I built (and documented) awhile back to build an all-singing, all-dancing print server. It takes parallel output, turns it into postscript, and passes it along (via rlpr -- a wonderful, yet much overlooked tool) to a regular print server. And it handles Epson escape codes via an old e2ps filter I had lying around. Is there interest in a white paper explaining how I threw this together, or is everyone printing via serial or extracting from .dsk now? 2 Quote Link to comment Share on other sites More sharing options...
+Ksarul Posted April 21, 2016 Share Posted April 21, 2016 This might actually be a very good thing to document--it would provide another avenue to connectivity, especially with that Epson filter in there, as a lot of TI software was formatted to use Epson codes when printing. . .so even a lot of the output files will have imbedded Epson coding. 1 Quote Link to comment Share on other sites More sharing options...
ckoba Posted April 21, 2016 Author Share Posted April 21, 2016 Okay, I'll have it up with a link to the software bits by the beginning of next week -- the software side is rough, and IMHO should be able to render to PCL via ghostscript as well (which seems to be a higher-quality emulation in the printers that I have here). Thanks for the feedback. Quote Link to comment Share on other sites More sharing options...
ckoba Posted April 23, 2016 Author Share Posted April 23, 2016 This has been done. The writeup is at https://www.disavowed.jp/index.php?/archives/28-Printing-from-a-TI-to-a-modern-printer.html 1 Quote Link to comment Share on other sites More sharing options...
