7800fan Posted April 25, 2016 Share Posted April 25, 2016 What would be a good way for portable C64? The SX is a huge and heavy beast and it was never designed to run off battery so that's out. PSP can run but no keyboard accessory was released and too many games needed keyboard to do anything so it's not practical. I was wondering about Pi, how well does it emulate C64? Maybe a portable model with lipo batteries and using SX keyboard rather than more common USB keyboard as some keys don't line up right on non Commodore keyboards. I am aware of that Indie-No-Go funding for new C64 and new handheld SX, no actual working proto is shown and it uses flexible funding which mean the creator could still take money and run even if the goal is not met. Quote Link to comment Share on other sites More sharing options...
goldenegg Posted April 25, 2016 Share Posted April 25, 2016 If you want something with a keyboard, you can get a Pandora or wait for the upcoming Pyra. Quote Link to comment Share on other sites More sharing options...
TMR Posted April 25, 2016 Share Posted April 25, 2016 I was wondering about Pi, how well does it emulate C64? Maybe a portable model with lipo batteries and using SX keyboard rather than more common USB keyboard as some keys don't line up right on non Commodore keyboards. The older models of RasPi can run a build of VICE with some restrictions; if memory serves, they use FastSID rather than ReSID and i can't remember if it's a flat out 50FPS because i'm using an HDMI to VGA conversion on my original model B. i haven't tried the latest hardware (i think the RasPi Zero is more powerful than what i currently have!) but, if there's a build of the emulator, it should be better with all that extra CPU grunt. Quote Link to comment Share on other sites More sharing options...
carlsson Posted April 25, 2016 Share Posted April 25, 2016 Since actual SX-64 keyboards are a bit like hen's teeth to find outside of a SX-64, it sounds brave fitting one of those. Better use a regular C64 keyboard inside some sleek case and a fold-up display. Actually I believe this has been done a couple of times, including the various Ben Heck creations for inspiration. Quote Link to comment Share on other sites More sharing options...
Bill Loguidice Posted April 25, 2016 Share Posted April 25, 2016 I have two SX-64's and both have wonky keyboards (in fact, one doesn't work at all). If you did in fact re-purpose a working SX-64 keyboard into a portable solution I would hope the SX-64 goon squad comes and finds you. These are indeed rare beasts, especially working. I actually bought an adapter from Jim Brain (which I'll be reviewing on Armchair Arcade soon) that allows me to use the SX-64 keyboard cable and plug in a P/S keyboard. The problem of mapping is not an issue because you can just buy a set of Commodore 64 keyboard stickers and stick them on the appropriate keys on the keyboard. Of course I'd prefer a working SX-64 keyboard instead, but you can't have everything. 1 Quote Link to comment Share on other sites More sharing options...
Keatah Posted April 25, 2016 Share Posted April 25, 2016 I just load VICE emulator and paste a C64 logo on my laptop. 2 Quote Link to comment Share on other sites More sharing options...
+OLD CS1 Posted April 25, 2016 Share Posted April 25, 2016 I just load VICE emulator and paste a C64 logo on my laptop. Been thinking about installing VICE on my Kali netbook. Kali's pretty stable and VICE is light-weight. I could do penetration tests and play Last Ninja at the same time. Epic win! Quote Link to comment Share on other sites More sharing options...
+wongojack Posted April 25, 2016 Share Posted April 25, 2016 Yeah, a windows laptop already IS a portable C64 1 Quote Link to comment Share on other sites More sharing options...
carlsson Posted April 25, 2016 Share Posted April 25, 2016 OLD CS1: You could even play Stroker! (sorry for the bad pun) Quote Link to comment Share on other sites More sharing options...
Keatah Posted April 25, 2016 Share Posted April 25, 2016 The older models of RasPi can run a build of VICE with some restrictions; if memory serves, they use FastSID rather than ReSID and i can't remember if it's a flat out 50FPS because i'm using an HDMI to VGA conversion on my original model B. i haven't tried the latest hardware (i think the RasPi Zero is more powerful than what i currently have!) but, if there's a build of the emulator, it should be better with all that extra CPU grunt. Vice is either 50 or 60 FPS depending whether you select a PAL or NTSC machine. There may be other refreh rate settings but I have not drilled down through each option and therefore can't say. Nor can I tell you if Direct3d or Direct Draw can be made to indirectly force a different rate. PAL or NTSC. That pretty much covers all the bases. Quote Link to comment Share on other sites More sharing options...
TMR Posted April 26, 2016 Share Posted April 26, 2016 Vice is either 50 or 60 FPS depending whether you select a PAL or NTSC machine. Well, i was talking about what i personally had run on a RasPi, i've never used NTSC in that environment (i rarely use it when running VICE on Windows either) so couldn't comment on it. But i was as much referring to the emulator dropping frames as refresh speed, VICE can do that but it's hard to tell if it's enabled when pushing the output through a HDMI to VGA converter. Nor can I tell you if Direct3d or Direct Draw can be made to indirectly force a different rate. It probably can't on a Linux-based system...? But the RasPi outputs composite so presumably it's dishing out something a television can deal with, even if VICE isn't necessarily synchronising to it. Quote Link to comment Share on other sites More sharing options...
7800fan Posted April 26, 2016 Author Share Posted April 26, 2016 To those who are lined up by my house with pitchforks, barrels of tar, and bundles of feather rest assured the SX keyboard will not be harmed. I have one with a semi-working 64 SX (bad RAM controller) and if I was going to make portable C64, it would have worked with a plug to connect to the keyboard. I wanted C64 style keyboard because PC style keyboard is a bit different. Some graphics are in different keys such as quote marks (shift-2 on C64, next to enter key on PC) and I keep forgetting where RESTORE and CRTL is hiding. Plus I like F keys on the right side, most PC have them on top. And lastly, PC keyboard never feels right. Quote Link to comment Share on other sites More sharing options...
carlsson Posted April 26, 2016 Share Posted April 26, 2016 Apart from a lower profile, what makes a SX-64 keyboard more suitable than a regular C64 keyboard? Well, I suppose the SX keyboard has a built-in encasing, while you would need to manufacture your own if you use a C64 keyboard. Quote Link to comment Share on other sites More sharing options...
7800fan Posted April 26, 2016 Author Share Posted April 26, 2016 Shell and convenient connector, no loose wire and it's slightly smaller than C64 standard. Quote Link to comment Share on other sites More sharing options...
carlsson Posted April 26, 2016 Share Posted April 26, 2016 Well, cutting off the female header and soldering on a DB25 is doable, so is tidying up the cable with some cover if you want it to look better. The lack of a tight shell is a matter of course. Quote Link to comment Share on other sites More sharing options...
