Janzl Posted April 25, 2016 Share Posted April 25, 2016 I have tried to run the Scramble roms by johnnywc from this topic (http://atariage.com/forums/topic/245610-scramble-2600/) but they won't work on my Harmonycart. I thought the Harmony could run games upto 32k or am I wrong? If anyone has had the same problems and has solved it I would sure like to hear a tip or two Thanx! Quote Link to comment Share on other sites More sharing options...
+save2600 Posted April 25, 2016 Share Posted April 25, 2016 Works just fine on my Harmony and I've got an early production model. You keeping up with the firmware updates? Quote Link to comment Share on other sites More sharing options...
Janzl Posted April 25, 2016 Author Share Posted April 25, 2016 Is 1.05 the latest version for PAL? I see there is a 1.06 for NTSC. Quote Link to comment Share on other sites More sharing options...
+save2600 Posted April 25, 2016 Share Posted April 25, 2016 Yep, as per: http://atariage.com/forums/topic/156500-latest-harmony-cart-software/page-1 ...others in PAL land have tested the game also, but not sure if they're using emulation or Harmony I guess, so not sure if that's the real problem or not. Wonder if *maybe* it's your system then? Some motherboard revisions (Heavy Sixer and certain 7800 systems mostly) have trouble with certain games. Or defective Harmony? Have you tried the ROM on an emulator to rule out a corrupt file transfer? Or could just try re-downloading it I guess. SD card in healthy shape? I've heard of problems with FAT getting corrupt after some manipulation after a while. Have to reformat the card and re-transfer things over every great once in a while. Quote Link to comment Share on other sites More sharing options...
iesposta Posted May 5, 2016 Share Posted May 5, 2016 I have tried to run the Scramble roms by johnnywc from this topic (http://atariage.com/forums/topic/245610-scramble-2600/) but they won't work on my Harmonycart. I thought the Harmony could run games upto 32k or am I wrong? If anyone has had the same problems and has solved it I would sure like to hear a tip or two Thanx! Did you get this to run? Scramble is a DPC+ program. There is a bug "if the DPC+ program is compiled with an older DPCplus.arm it crashes the Harmony Encore". Instead of making sure everyone is using the newest DPCplus.arm file, the new firmware 1.06 has a "work around" so programs compiled with both old and new versions of DPCplus.arm work. This is a problem if you are not NTSC as I don't see a version 1.06 for PAL. I can hack an unofficial Scramble version that contains the newer DPC+ code. I'll add it here shortly. EDIT: This has the header hacked. This is the NTSC one in the thread your post pointed to. Do you have a PAL version of Scramble? I searched the thread and nothing mentioned PAL. Quote Link to comment Share on other sites More sharing options...
iesposta Posted May 6, 2016 Share Posted May 6, 2016 Oops! I just ran a file difference on the latest Scramble from the official thread and my hacked one here (which I removed). They are exactly the same. My changes did not get saved. This one IS changed and checked, and has a different DPCplus.arm header than the Scramble in the official thread. This is still only NTSC coded. scramble_20160106_AltDPC.bin This build is just to test if the DPC+ header change will allow it to run from Harmony when the official build did not run. The original "latest" build is also attached below. scramble_20160106.bin The official thread says he plans to incorporate a few final good feedback suggestions, so this version is not the FINAL Scramble build. Quote Link to comment Share on other sites More sharing options...
+johnnywc Posted June 9, 2016 Share Posted June 9, 2016 I just ran across this thread; looks like there may be some issue running Scramble on the Harmony? Has anybody had a chance to test the AltDPC build provided by ieposta (thanks!) to see if it makes a difference? Thanks! Quote Link to comment Share on other sites More sharing options...
iesposta Posted June 9, 2016 Share Posted June 9, 2016 I just ran across this thread; looks like there may be some issue running Scramble on the Harmony? Has anybody had a chance to test the AltDPC build provided by ieposta (thanks!) to see if it makes a difference? Thanks! It would only be Harmony Encore in PAL on charter 6-Switch Ataris. Harmony Encore with the newest firmware will run everything, problem is that Harmony Encore PAL firmware version is not out. Too bad the orig poster did not give an update, as I really wanted to see if it was the DPC+ header! Quote Link to comment Share on other sites More sharing options...
Janzl Posted October 27, 2016 Author Share Posted October 27, 2016 (edited) I am so ashamed ieposta... I completely forgot to tell you that the update worked. I thought I did, but today I received a PM from you asking me if I had tried the update. I'll pm you my home adress so you can come visit and kick me I am using the old Harmony, not the Encore. I haven't had any problems with it since you posted the update. Looking forward to the release. Its a great game and the boxart is looking awesome. Edited October 27, 2016 by Janzl 1 Quote Link to comment Share on other sites More sharing options...
+johnnywc Posted November 10, 2016 Share Posted November 10, 2016 I am so ashamed ieposta... I completely forgot to tell you that the update worked. I thought I did, but today I received a PM from you asking me if I had tried the update. I'll pm you my home adress so you can come visit and kick me I am using the old Harmony, not the Encore. I haven't had any problems with it since you posted the update. Looking forward to the release. Its a great game and the boxart is looking awesome. That's good to hear that it worked! Mike (ieposta) provided me with the fix and it will be included in the official release at the end of the month! Quote Link to comment Share on other sites More sharing options...
Andromeda Stardust Posted November 10, 2016 Share Posted November 10, 2016 I have the v1.05 firmware on my pre-Encore Harmony (purchased 2012) and Scramble runs flawless on my 4-switcher. Quote Link to comment Share on other sites More sharing options...
KEWROCK Posted May 10, 2021 Share Posted May 10, 2021 Hi Guys. I have this Scramble ROM and the ROM for SuperCobra Arcade. SuperCobra Arcade fires the same way the vintage Parker Brother cartridge did. Bombs and bullets alternating from one button, the only button the CX40 would have. But I'm using a Logitech wireless controller with extra buttons. On Scamble, two buttons are needed to fire bombs and bullets. How would this work using a Harmony or Concerto cart and a cx40 with only one button? Quote Link to comment Share on other sites More sharing options...
alex_79 Posted May 10, 2021 Share Posted May 10, 2021 Scramble auto detects if a Genesis controller is connected and, if so, it uses two independent buttons (B and C). Else it reverts to single button mode like in the Parker Brothers cart. 1 Quote Link to comment Share on other sites More sharing options...
