Richard H. Posted May 22, 2016 Share Posted May 22, 2016 AtariVox works but needs to either be removed from it's shell This is my alternate Avox case which does fit the 7800. I can supply the .stl files if anyone wants to 3D print one. 1 Quote Link to comment Share on other sites More sharing options...
Trebor Posted May 22, 2016 Share Posted May 22, 2016 This is my alternate Avox case which does fit the 7800. Make sure that Vox is plugged into (Controller) Port 2 when being used. Quote Link to comment Share on other sites More sharing options...
Richard H. Posted May 22, 2016 Share Posted May 22, 2016 Well spotted Quote Link to comment Share on other sites More sharing options...
Lynxpro Posted May 24, 2016 Share Posted May 24, 2016 Can you use it with a Y Connector? Quote Link to comment Share on other sites More sharing options...
Everett1954 Posted May 24, 2016 Author Share Posted May 24, 2016 Hi, Just got two Genesis to 7800 adapters from grips03 (see earlier post) and they are great!! Using the Genesis game pad instead of the the CX-24 controllers makes playing both 7800 and 2600 games so much more enjoyable. I highly recommend them. Does the Atarivox work with the Retrobits brand genesis extension cable? I thought I read something about it. Richard H., With all your great flash cartridge products for Vectrex and more, have you given any thought to doing one for the 7800? Thanks 1 Quote Link to comment Share on other sites More sharing options...
Albert Posted May 24, 2016 Share Posted May 24, 2016 Does the Atarivox work with the Retrobits brand genesis extension cable? I thought I read something about it. No, they do not, the male connector is too tight for the AtariVox to fit into. I bought some original SEGA Genesis extension cables from eBay and those work great. ..Al 1 Quote Link to comment Share on other sites More sharing options...
Trebor Posted May 24, 2016 Share Posted May 24, 2016 No, they do not, the male connector is too tight for the AtariVox to fit into. I bought some original SEGA Genesis extension cables from eBay and those work great. ..Al Seconded. Original Sega Genesis extension cables are the way to go. They work great with CPUWIZ's MCP Dev cart as well as Edladdin's Genesis adapter too. Quote Link to comment Share on other sites More sharing options...
Jinks Posted May 25, 2016 Share Posted May 25, 2016 Mine were too tight so I melted my extension cable cornors to fit the avox. I used a soldering iron. Quote Link to comment Share on other sites More sharing options...
