marc.hull Posted May 15, 2016 Share Posted May 15, 2016 I have spent some time building and redesigning the Forti card so that I could #1 get it to play through the TI speakers with out affecting the console sound chip and adding an EPROM for a DSR. I am confident the hardware works as I can control the sound chips through easy bug and the power up routine on EPROM is doing what I expect it to do. The next step is to write some routines accessible from BASIC. I have scanned TN's pages and everything seems pretty straight forward. Just build a standard header with the info it needs and write the routines. I'm not getting much love though (except from the power up routine.) When I try to call the routines from BASIC (ie CALL FTON) I can see the LED on the card flash like the scanning routine is searching the card but then I get a not found error. I think my header is built correctly and before I go and pull my hair out looking through code that may be good I need to know if my underlying assumptions are correct. If I have a routine that is named FTON that is resident on the card ROM then in order to access it I can simply type CALL FTON ? It believe that this is correct as the LED for the card and therefor the ROM flickers when I do this but I have also seen cards that access subroutine by using the DELETE command (as in file access.) DELETE FTON only gives me a syntax error. So does anyone know which method (or both) are correct for accessing subprograms in >4000 ROM ? Does this behavior change from BASIC to XBASIC ? Is there something I am missing or do I need to revisit my header ? While on the DSR bandwagon I have another request. Writing a DSR on the TI is currently a pain in the ass. I have to assemble with a listing and hex edit a PC file to create an EPROM binary using the print out. SSAVE chokes on converting code to the >6000 space (with a SS cart) and I'd hate to see what would happen even with memory in the >4000 space. Is there an EA3 to EA5 converter that does not have to operate from memory (ie convert a disk based tagged code to a memory image without first loading the tagged code ?) 1 Quote Link to comment Share on other sites More sharing options...
Willsy Posted May 15, 2016 Share Posted May 15, 2016 I think the flashing of the LED on the card could be a red-herring. It's not flashing because your FTON routine is *executing*. It's flashing because the console is paging each CRU device in one at a time to look for a routine called FTON. As far as I know, your assumption about being able to use CALL to access a routine in the DSR is correct. I'm suspecting your DSR header. You could try paging in a known good DSR (e.g. the TI Disk Controller) and examining the memory in the DSR space to double check the format of the header(s). Quote Link to comment Share on other sites More sharing options...
marc.hull Posted May 15, 2016 Author Share Posted May 15, 2016 That's what I am suspecting as well. I'm just trying to verify I'm not barking up the wrong tree. Read the rest of the DSR specs and it looks like passing from BASIC is a real PITA. I'll have to spend some time. I'm definitely going to revisit the design to add some RAM. That should make programming a bit easier. 1 Quote Link to comment Share on other sites More sharing options...
