+Schmitzi Posted June 12, 2016 Share Posted June 12, 2016 Nice config, PeBo ! I like the DOCs, very good to view Just a hint: You can use my CF-COPY-Batch to easily make backups from (and copy DSKs to) the CF-Volumes. Just unpack it to the folder where the DSK2CF.exe resides. It copies (using the CF2DSK.exe in the same folder) the Volumes down to the PC, watches inside (!) the converted DSK-files (on the PC only ) and gives nice names to them, depending on the TI-DISK-Name of the DSK/Volume, AND enumerates them, as a result like: 0001-Boot 0002-CF-Config 0003-Blank 0004-Modules01A a.s.o. So there are good and from the volume-number enumerated names in this "Backup" on the PC, and later you can ALSO use my Batch to copy them back to the CF-Card. All with just 1 or to inputs. And your order/volumenumbers are kept. There is a small docu inside the, near the top, just check that or ask me here. xXx 1 Quote Link to comment Share on other sites More sharing options...
+chicgamer Posted June 12, 2016 Share Posted June 12, 2016 Thank you both for your help! I haven't had a chance to try this again using your instructions/resources, but I hope to soon. I'll report back after. 1 Quote Link to comment Share on other sites More sharing options...
+chicgamer Posted June 24, 2016 Share Posted June 24, 2016 (edited) So, I finally got this working, and I'm a little embarrassed to say that I didn't realize that the commands needed to be in all caps. After I turned the alpha lock on, no more problems. Quick question—is there a command I can type in basic to check how much memory I have available? I should have 32K with the CF7+, right? Edited June 24, 2016 by chicgamer 1 Quote Link to comment Share on other sites More sharing options...
+Schmitzi Posted June 24, 2016 Share Posted June 24, 2016 In eXtended-Basic just type SIZE 1 Quote Link to comment Share on other sites More sharing options...
+chicgamer Posted June 24, 2016 Share Posted June 24, 2016 Thank you! Quote Link to comment Share on other sites More sharing options...
