2Ni Posted June 4, 2016 Share Posted June 4, 2016 Hi ! Is there any easy and safe way to change the internal drive number of the SX-64 ? The idea is to use a SD2IEC as drive number 8... Quote Link to comment Share on other sites More sharing options...
+OLD CS1 Posted June 4, 2016 Share Posted June 4, 2016 Hi ! Is there any easy and safe way to change the internal drive number of the SX-64 ? The idea is to use a SD2IEC as drive number 8... There are two pads on the board, similar to the external 1541. Alternately, you can use the old software method of changing device numbers. 1 Quote Link to comment Share on other sites More sharing options...
2Ni Posted June 5, 2016 Author Share Posted June 5, 2016 Thank you for the answer. I found a prg file named "SX-64 Internal + External Drive Renumber", but I read somewhere that SX-64 drive number could not be changed by software : so it would be wrong ?Is there any risk using such a program ? Quote Link to comment Share on other sites More sharing options...
+OLD CS1 Posted June 5, 2016 Share Posted June 5, 2016 Thank you for the answer. I found a prg file named "SX-64 Internal + External Drive Renumber", but I read somewhere that SX-64 drive number could not be changed by software : so it would be wrong ? Is there any risk using such a program ? It uses the same firmware as the 1541 so your answers in order are yes the information is wrong, and no there is no risk (at least of damage, just remember what number you assigned it.) 1 Quote Link to comment Share on other sites More sharing options...
7800fan Posted June 6, 2016 Share Posted June 6, 2016 The drive ID is only temporary, it will be reset to 8 when you reset the drive or power cycle the system. A permanent solution exists but unless you're planning to add something inside like SD2IEC or Ultimate 1541 and wanting to set those to 8, there's no reason to permanently change the internal drive. If the drive isn't working and you want to disable it, you can unplug the IEC cable (white cable) between drive board and CPU board. This will allow you to use external drive with ID 8 on the SX. This does however require removing about 12 screws and 3 case parts to get to the drive cable. 1 Quote Link to comment Share on other sites More sharing options...
2Ni Posted June 10, 2016 Author Share Posted June 10, 2016 Thank you for the info. My SX-64 internal drive is working so far (although capricious with some disks !), but i'd prefer using d64 files rather than making multiple 5.25 disks ; with SD2IEC with drive number 9 or higher, many games not in a single files would not load... Quote Link to comment Share on other sites More sharing options...
+OLD CS1 Posted June 10, 2016 Share Posted June 10, 2016 Then you will definitely want to either remove the drive from the system altogether (serial bus, power, or just physically remove the drive and its board,) or permanently set the device number with the jumper pads. Quote Link to comment Share on other sites More sharing options...
RobertB Posted June 11, 2016 Share Posted June 11, 2016 There are two pads on the board, similar to the external 1541. Ray Carlsen has more details on this. Go to http://personalpages.tds.net/~rcarlsen/cbm/sx64/sx64.txt Near the end of the article, he tells how to disable the internal drive, how to change drive numbers on those pads, and how to install switch(es) so that you can select a drive number. Truly, Robert Bernardo Fresno Commodore User Group http://www.dickestel.com/fcug.htm July 30-31 Commodore Vegas Expo v12 - http://www.portcommodore.com/commvex Quote Link to comment Share on other sites More sharing options...
2Ni Posted June 12, 2016 Author Share Posted June 12, 2016 (edited) I don't know how to delete the post ! Edited June 12, 2016 by 2Ni Quote Link to comment Share on other sites More sharing options...
2Ni Posted June 12, 2016 Author Share Posted June 12, 2016 Then you will definitely want to either remove the drive from the system altogether (serial bus, power, or just physically remove the drive and its board,) or permanently set the device number with the jumper pads. Yes, but I'd like to keep the machine as close as possible from the original SX-64 (and I'm not very skilled with a screwdriver !), so shifting drive id by software the few times I want to use it is OK for me. Ray Carlsen has more details on this. Go to http://personalpages.tds.net/~rcarlsen/cbm/sx64/sx64.txt Near the end of the article, he tells how to disable the internal drive, how to change drive numbers on those pads, and how to install switch(es) so that you can select a drive number. Truly, Robert Bernardo Fresno Commodore User Group http://www.dickestel.com/fcug.htm July 30-31 Commodore Vegas Expo v12 - http://www.portcommodore.com/commvex Thanks. I found this useful document just when I was seeking informations about changing the drive id, but that was only the hardware method... Quote Link to comment Share on other sites More sharing options...
7800fan Posted June 13, 2016 Share Posted June 13, 2016 If you're not going to use the internal drive for a long time, you could ask someone local to open the system, unplug the power and IEC cable to the drive board, and close it up. It'll become a portable 64 without disk drive and still look stock. And easily reversible at later time. Just stick a note or something that says "Disk drive unplugged inside" to remind yourself. Quote Link to comment Share on other sites More sharing options...
2Ni Posted June 13, 2016 Author Share Posted June 13, 2016 The 1541 weighting as a dead donkey, I'm sure that the SX-64 would be easier to carry ; but I'm not going to travel far with it, and I like the machinegun sounds of the drive ! On that point (carrying a SX-64 - not firing machinegun), is it so bad to carry the SX-64 without the transit card ? Quote Link to comment Share on other sites More sharing options...
7800fan Posted June 15, 2016 Share Posted June 15, 2016 Could cause head to become warped if it's not parked in down position to keep it flat. 1 Quote Link to comment Share on other sites More sharing options...
2Ni Posted June 18, 2016 Author Share Posted June 18, 2016 Some BASIC command such as OPEN15,8,15 PRINT#15,"I0" CLOSE15 will also park the head ? Quote Link to comment Share on other sites More sharing options...
+OLD CS1 Posted June 18, 2016 Share Posted June 18, 2016 If by "park" you mean place it over track 18 (the middle of the disk,) then yes. I think what he means is keeping the door closed with the card inside as the card will push the head to its outer-most position and hold it there. 1 Quote Link to comment Share on other sites More sharing options...
2Ni Posted June 21, 2016 Author Share Posted June 21, 2016 Is it possible to do that with an old 5.25" floppy ? Quote Link to comment Share on other sites More sharing options...
+OLD CS1 Posted June 21, 2016 Share Posted June 21, 2016 Is it possible to do that with an old 5.25" floppy ? No. The card has a protrusion which pushes the head back. A floppy will still allow free movement of the head. (Source) 1 Quote Link to comment Share on other sites More sharing options...
carlsson Posted June 21, 2016 Share Posted June 21, 2016 Isn't it rather easy to manufacture a transit card, if you don't already own one? Quote Link to comment Share on other sites More sharing options...
2Ni Posted June 21, 2016 Author Share Posted June 21, 2016 Yes I think so ; I found pdf on zimmers.net : http://www.zimmers.net/anonftp/pub/cbm/schematics/drives/new/1541/Transit_card_251171-02_(300_dpi).pdf http://www.zimmers.net/anonftp/pub/cbm/schematics/drives/new/1541/Transit_card_251171-03_(300_dpi).pdf Quote Link to comment Share on other sites More sharing options...
iKarith Posted June 23, 2016 Share Posted June 23, 2016 My 1571 was sent with the transit card in backwards. It seems to have survived the trip, even if the original box it came in did not. (Whew!) 1 Quote Link to comment Share on other sites More sharing options...
