sanny Posted June 15, 2016 Share Posted June 15, 2016 Hi, AFAIK, the extended memory on the 130XE supports Antic and CPU accessing different banks simultaneously. Some other memory expansions don't support that. Is there a test program to test for that? regards, chris Quote Link to comment Share on other sites More sharing options...
+CharlieChaplin Posted June 16, 2016 Share Posted June 16, 2016 Some examples: http://a8.fandal.cz/detail.php?files_id=7091 http://a8.fandal.cz/detail.php?files_id=6725 http://a8.fandal.cz/detail.php?files_id=1140 These versions do require 128k RAM and sep. Antic access... (there are patched versions available that work without sep. Antic access) Quote Link to comment Share on other sites More sharing options...
Sikor Posted June 16, 2016 Share Posted June 16, 2016 Sysinfio from Drac030: http://drac030.krap.pl/en-si-info.php 2 Quote Link to comment Share on other sites More sharing options...
sanny Posted June 17, 2016 Author Share Posted June 17, 2016 Thanks. I'll give these programs a try. Quote Link to comment Share on other sites More sharing options...
+skr Posted June 17, 2016 Share Posted June 17, 2016 I recommend the SysCheck hardware from tfhh. If you are an ABBUC member, you can find it in the shop. Additionally to extensive hardware diagnostics it provides you a built in memory extension and flashable multiOS. Quote Link to comment Share on other sites More sharing options...
