Nomad it's dead, help please
vetteguy112233
I've got power from the power port to and through the switch, but neither of the regulator outer pins have power. I'm not sure where to go from here.
Help?
I assume you're talking about the Voltage Regulator? I've never worked on a nomad, but if it's like the genesis, it will have 3 prongs on the regulator. One is ground, one is input voltage (10v approx.) and one is output voltage (5v approx.). If you're not getting 5, but get 10 = replace the regulator. If you're not getting 10 or 5, check the trace from there to power switch for continuity.
I assume you have a no response issue with the unit?
  • 2 weeks later...
Correct, it doesn't do anything. And yes I'm talking about the voltage regulator. The middle pin is ground and it ohms out just fine. The left leg should have 13v and the right should have 5v, but neither leg had any power, yet power is getting through the dc port and through the power switch.
Interesting. I wish I could help further, but without the unit in my hand, it's hard to say. I've never actually worked on one. Good luck though, maybe others will chime in.
