scotty Posted June 29, 2016 Share Posted June 29, 2016 Anyone have a tutorial (video or text on setting up U1MB in Altirra? I want to get one, but I want to play around with it first. Tried a couple times to set it up, but could not get it going. Been working a LOT of hours lately, so time has been limited. Thanks in advance. Quote Link to comment Share on other sites More sharing options...
+DrVenkman Posted June 29, 2016 Share Posted June 29, 2016 I have one setup to play with but I'm at work. I can write up how to do it later but someone else will probably get to it before I can. In the meantime the basics are to add it in the Devices menu (I think it's called) but you also have to point Altirra to a full firmware image for it. That's where it gets tricky. Hopefully Jon will see this thread and provide a link but if not, I'll try to help later tonight. Quote Link to comment Share on other sites More sharing options...
voy Posted June 29, 2016 Share Posted June 29, 2016 scotty, you can can download ROM image from here: http://ftp.pigwa.net/stuff/projects/Ultimate1MB/ROM%20images/ Quote Link to comment Share on other sites More sharing options...
flashjazzcat Posted June 29, 2016 Share Posted June 29, 2016 System -> Firmware -> Firmware Images..., then "Add", navigate to the ROM voy posted, set firmware type as Ultimate 1MB. Then System -> Memory Config -> Ultimate 1MB. Machine should boot direct to BIOS setup. 1 Quote Link to comment Share on other sites More sharing options...
