Shift838 Posted July 10, 2016 Share Posted July 10, 2016 Ok, I know these things can emulate up to 2 drives at once. I am ordering a REV F and a REV C. What are the correct dip switch settings to get these to emulate both DSK1 and DSK2 at the same time? Quote Link to comment Share on other sites More sharing options...
+Schmitzi Posted July 10, 2016 Share Posted July 10, 2016 Hi, I think you need one of this: A is 1st drive, B is 2nd drive. ID0 is DSK1, ID1 is DSK2, ..... (floppy-cable straight through) Do you have pics from the corpus delictis ? Quote Link to comment Share on other sites More sharing options...
+Schmitzi Posted July 10, 2016 Share Posted July 10, 2016 my settings/config-file via >Settings >SD-Menu: Quote Link to comment Share on other sites More sharing options...
Airshack Posted July 10, 2016 Share Posted July 10, 2016 (edited) Edited July 10, 2016 by Airshack Quote Link to comment Share on other sites More sharing options...
Airshack Posted July 10, 2016 Share Posted July 10, 2016 I've successfully used the Shugart jumper settings from page 2.3.1 You select between DSK1 (A) and DSK2 (B) by holding the middle button down until the function menu pops up. Within the function menu you can: change drives, flip the disk, and rename disk images. 1 Quote Link to comment Share on other sites More sharing options...
Airshack Posted July 10, 2016 Share Posted July 10, 2016 This is a shot of the back of the HxC Rev C with DSK1 and DSK2 enabled and functioning on the HxC. DSK1/A jumper on top two pins of leftmost column DSK2/B jumper on bottom two pins next column 1 Quote Link to comment Share on other sites More sharing options...
Airshack Posted July 11, 2016 Share Posted July 11, 2016 (edited) my settings/config-file via >Settings >SD-Menu: Settings-RMS.JPG Updated HxC software: Edited July 11, 2016 by Airshack 1 Quote Link to comment Share on other sites More sharing options...
