patjomki Posted September 22, 2018 Share Posted September 22, 2018 (edited) Update: I just installed the latest mads 2.07 (compiled it with freepascal from the sources provided at: http://mads.atari8.info/) but the problem still remains. Altirra starts within wine but no breakpoints are recognized. Edited September 22, 2018 by patjomki Quote Link to comment Share on other sites More sharing options...
freetz Posted September 22, 2018 Author Share Posted September 22, 2018 It seems you haven't followed my instructions completely because the script that I provided circumvents the bug in MADS which omits the "Source:" line at the beginning of the .lst file. This in turn is a requirement for Altirra to correctly use breakpoints etc. This has been explained by Phaeron to me here: http://atariage.com/forums/topic/254747-;-trace-and-;-assert-not-working-with-altirramads-under-wine/ So unless you get the script working the way I explained in the first post (and in the other thread) and have "Source:" at the beginning of the .lst file, breakpoints etc. won't work. Quote Link to comment Share on other sites More sharing options...
patjomki Posted September 22, 2018 Share Posted September 22, 2018 Perhaps I should have copied the content of the .lst file from the filesystem instead of the Eclipse editor (where it is generated before altirra.sh is executed). So here is the new content generated with the latest version of mads I could get for Mac os x and this time from inside the file system. mads 2.0.7Source: /Users/patjomki/Documents/workspace/Example/example.lst 1 org $4000 2 3 start 4 FFFF> 4000-4007> A9 34 lda #52 5 4002 8D C8 02 sta 712 6 7 4005 endless 8 4005 4C 05 40 jmp endless 9 10 ; run start The problem remains though. Breakpoints are not executed. Quote Link to comment Share on other sites More sharing options...
patjomki Posted September 22, 2018 Share Posted September 22, 2018 Compared to my .lst file within windows I found out that there is a difference: mac version: mads 2.0.7Source: /Users/patjomki/Documents/workspace/Example/example.lst windows version: mads 1.9.9 Source: C:\jac\wudsn\Workspace\Example\example.asm So shouldn't the altirra.sh script generate the Source: line with .asm at the end instead of .lst? Quote Link to comment Share on other sites More sharing options...
patjomki Posted September 22, 2018 Share Posted September 22, 2018 (edited) Yes. That was the reason. In order to avoid that I had to change the .sh script a little bit. So here is the version of freetz' script that allows source level debugging: #/!bin/bash fullpath="${1//\"}" lstfile=${fullpath%.xex}.lst WineExec=/Applications/Wine.app/Contents/Resources/bin/wine AltirraExec=/Applications/Altirra.app/Contents/Resources/wineprefix/drive_c/winebottler/Altirra.exe sed "/mads /a\\ Source: $lstfile " $lstfile > $lstfile.temp sed "s/lst/asm/" $lstfile.temp > $lstfile rm $listfile.temp cd "$(dirname "$fullpath")" $WineExec $AltirraExec /singleinstance /run $(basename "$fullpath") & Enjoy! Edited September 22, 2018 by patjomki Quote Link to comment Share on other sites More sharing options...
freetz Posted September 22, 2018 Author Share Posted September 22, 2018 (edited) Interesting, while this contradicts what Phaeron wrote on the issue of breakpoints here where he specifically metions the .lst file in the Source line: http://atariage.com/forums/topic/254747-;-trace-and-;-assert-not-working-with-altirramads-under-wine/?p=3550868 ...the newer versions of MADS (I have 2.0.8 running here now) seem to have now been fixed and include the Source line with reference to the .asm file. Therefore the lines from 'sed "/mads /a\\' until 'rm $listfile.temp' are not only no longer necessary with current versions of MADS, but will also prevent the inclusion of the correct files as they will result in two Source: lines which then seem to break the desired functionality. I'm not sure if previous versions of MADS and/or Altirra (I'm still running Altirra 2.71 here in my wine environment) required the .lst files instead of the .asm file (because source level debuggin was working for me before), so I leave the original script as it is, but I have added instructions to remove the lines that are dealing with this issue when using MADS 2.0.8 and above. Edited September 22, 2018 by freetz Quote Link to comment Share on other sites More sharing options...
patjomki Posted September 22, 2018 Share Posted September 22, 2018 ...the newer versions of MADS (I have 2.0.8 running here now) seem to have now been fixed and include the Source line with reference to the .asm file. Where did you get that version? I could only get 2.07 from http://mads.atari8.info/ Quote Link to comment Share on other sites More sharing options...
freetz Posted September 22, 2018 Author Share Posted September 22, 2018 (edited) Almost at the same spot ... http://mads.atari8.info/mads.html ...and 2.11 can be found in a different thread here: http://atariage.com/forums/topic/114443-mad-assembler-mads/?p=3881963 Edited September 22, 2018 by freetz 1 Quote Link to comment Share on other sites More sharing options...
patjomki Posted September 22, 2018 Share Posted September 22, 2018 But where exactly? I don't see any binaries or sources there... Quote Link to comment Share on other sites More sharing options...
dmsc Posted September 22, 2018 Share Posted September 22, 2018 Hi! But where exactly? I don't see any binaries or sources there... here? http://atariage.com/forums/index.php?app=core&module=attach§ion=attach&attach_rel_module=post&attach_id=537373 The ZIP contains the source and windows exe. Quote Link to comment Share on other sites More sharing options...
freetz Posted September 23, 2018 Author Share Posted September 23, 2018 ...exactly ad linked ny me three posts above in the second link... Quote Link to comment Share on other sites More sharing options...
patjomki Posted September 23, 2018 Share Posted September 23, 2018 (edited) Thanks a lot. I even already found that version but was confused due to the reason that the files extension of the source file changed from .pas to .dpr. Anyway, I could compile it and the bug with the missing Source: statement in the .lst file is gone. One thing is a little bit confusing. Athough the version no. should be 2.11 according to the .zip file the printed version no in the .lst file is still mads 2.0.8? Edited September 23, 2018 by patjomki Quote Link to comment Share on other sites More sharing options...
Lastic Posted October 23, 2018 Share Posted October 23, 2018 So I thought about starting to learn assembler again. I'm using my Thinkpad with Fedora 27 , installed Eclipse, WUDSN , Wine 3.0.1 stable and downloaded Altirra 3.10 . Using Mads 207 ( well the 211 dated DPR version ) I can compile and run programs but once I enable the debugger , Wine starts to freeze after 5 seconds. Anybody got an idea or has a similar issue ? Quote Link to comment Share on other sites More sharing options...
Lastic Posted October 24, 2018 Share Posted October 24, 2018 So I thought about starting to learn assembler again. I'm using my Thinkpad with Fedora 27 , installed Eclipse, WUDSN , Wine 3.0.1 stable and downloaded Altirra 3.10 . Using Mads 207 ( well the 211 dated DPR version ) I can compile and run programs but once I enable the debugger , Wine starts to freeze after 5 seconds. Anybody got an idea or has a similar issue ? I've replicated my setup under OS X 10.11 also with Wine 2.0 , the 32 bit bottled version of Altirra 3.0 and Mads 2.08 (2/11) and I have the same issue once I enable the debugger. Quote Link to comment Share on other sites More sharing options...
patjomki Posted October 26, 2018 Share Posted October 26, 2018 Do you use the shellscript provided by freetz? Quote Link to comment Share on other sites More sharing options...
Lastic Posted October 27, 2018 Share Posted October 27, 2018 (edited) Do you use the shellscript provided by freetz? Yes, only difference is the path to my Wine binary and I removed the & so the Altirra process doesn't start in the background. #/!bin/bash fullpath="${1//\"}" lstfile=${fullpath%.xex}.lst WineExec=/Applications/Wine.app/Contents/Resources/bin/wine AltirraExec=/Applications/Altirra.app/Contents/Resources/wineprefix/drive_c/winebottler/Altirra.exe cd "$(dirname "$fullpath")" $WineExec $AltirraExec /singleinstance /run $(basename "$fullpath") I should also mention that I tried again on my Fedora install with the 32 bit wine libraries and binary but this also hangs once I enable the debugger. Could it be my version of Wine ? Edited October 27, 2018 by Lastic 1 Quote Link to comment Share on other sites More sharing options...
patjomki Posted October 28, 2018 Share Posted October 28, 2018 Perhaps. For me this combination works: Wine 3.03 (stable), Mac OS X 10.13.6 and Altirra 3.10. 1 Quote Link to comment Share on other sites More sharing options...
tebe Posted November 13, 2018 Share Posted November 13, 2018 GEANY http://www.geany.org Geany is a small and lightweight Integrated Development Environment. It was developed to provide a small and fast IDE, which has only a few dependencies from other packages. Geany is known to run under Linux, FreeBSD, NetBSD, OpenBSD, MacOS X, AIX v5.3, Solaris Express and Windows. More generally, it should run on every platform, which is supported by the GTK libraries. Only the Windows port of Geany is missing some features. geany_mads.zip 1 Quote Link to comment Share on other sites More sharing options...
flashjazzcat Posted November 13, 2018 Share Posted November 13, 2018 Very nice indeed. If Geany had outlining (like WUDSN), I'd probably jump since Geany is much faster than Eclipse. Quote Link to comment Share on other sites More sharing options...
bocianu Posted November 13, 2018 Share Posted November 13, 2018 Outlining works for Mad-Pascal in Geany I can try to make it work for MADS Quote Link to comment Share on other sites More sharing options...
flashjazzcat Posted November 13, 2018 Share Posted November 13, 2018 Outlining works for Mad-Pascal in Geany I can try to make it work for MADS That would be pretty awesome. I have only looked at Geany breifly so far, but were it able to outline like WUDSN, I would be looking pretty closely. I was really keen to use VS Code a while ago for MADS work, but I just could not live without MADS outlining. Thought about implementing it myself in VS Code, researched it, then gave up. No room left in my head for that stuff. Quote Link to comment Share on other sites More sharing options...
bocianu Posted November 13, 2018 Share Posted November 13, 2018 There is "kind of" outline feature called Symbols. For asm it lists and allows to navigate to all labels and defines: Quote Link to comment Share on other sites More sharing options...
flashjazzcat Posted November 13, 2018 Share Posted November 13, 2018 Yes: I immediately noticed that but it's difficult to pick out PROCs when every symbol in the file is in the list (with no hierarchy). Quote Link to comment Share on other sites More sharing options...
bocianu Posted November 14, 2018 Share Posted November 14, 2018 i've searched through plugins, but unfortunately did not found anything better :/ Quote Link to comment Share on other sites More sharing options...
flashjazzcat Posted November 14, 2018 Share Posted November 14, 2018 Yes: I searched for plugins too. Quote Link to comment Share on other sites More sharing options...
