godsey1 Posted July 18, 2016 Share Posted July 18, 2016 Hi. I am wanting to get a price on getting my original Nintendo painted. The system and controllers. I don't have a scheme in mind but could come up with something pretty quick. I don't like seeing it getting yellow. Thanks, Tony Quote Link to comment Share on other sites More sharing options...
godsey1 Posted July 23, 2016 Author Share Posted July 23, 2016 I am going to try something myself. Does any one know if water slide decals would be good enough to put on top of a NES. I don't know if that or just a sticky paper with something printed on it would be best. Any ideas? Quote Link to comment Share on other sites More sharing options...
bah Posted July 25, 2016 Share Posted July 25, 2016 I am not the best person to comment here as I do not prefer painted systems. When I used to do model cars, water decals apply easily and would work on a smooth NES. They also tend to be fragile as in they scratch easy I have seen some good paint jobs but you need to spend most of your time on prep. Clean all surfaces good. I use about 10000 grit wet/dry sand paper and lightly sand all surfaces to promote adhesion. I then thouroughly wash and dry the parts to eliminate any sanding dust. From here on, don't touch the part as oils from you skin can destroy the paint adhesion. Now for a light coat of primer. Sanding again may be needed depending on how smooth the primer dried. Next I use an automotive grade of spray enamel. 1 light coat allowed to tack off for 10 minutes, followed by a heavier coat. The parts I an describing here are plastic car parts but the process would be the same for consoles. Quote Link to comment Share on other sites More sharing options...
bah Posted July 25, 2016 Share Posted July 25, 2016 Oh one thing that I used on car models. When you get a run or sag in the paint, let it dry. Spray the part with easy off oven cleaner to dissolve the paint and start over. At least this was a cool trick with testors model paint, maybe not so much with auto paint. Quote Link to comment Share on other sites More sharing options...
godsey1 Posted July 29, 2016 Author Share Posted July 29, 2016 Thanks for the tips. I did pretty much how you said to do it, but I didn't let it dry long enough and the paint started to crack when I applied the clear coat. Luckily it was just 4 of the small parts and not the top and bottom case halves. Now I have to find the parts to replace them, The case top and bottom turned out pretty good. Thanks again, Tony Quote Link to comment Share on other sites More sharing options...
bah Posted July 29, 2016 Share Posted July 29, 2016 Sorry to hear it cracked. At this point, if you are not happy with the small parts, you can wet sand the paint off and try again. A block of wood behind the sandpaper will help keep flat surfaces flat. Quote Link to comment Share on other sites More sharing options...
godsey1 Posted July 31, 2016 Author Share Posted July 31, 2016 I tried a paint striper on them, but it didn't work out good. The parts started to get soft, and is unusable. I have to get more of them to fix it. Quote Link to comment Share on other sites More sharing options...
godsey1 Posted August 3, 2016 Author Share Posted August 3, 2016 Anyone on here have the NES bezel for the hole where the controllers plug in, and /or the 2 black parts that attach on top of it? Thanks, Tony Quote Link to comment Share on other sites More sharing options...
