Matej Posted July 30, 2016 Share Posted July 30, 2016 (edited) I want to buy 2x Eiffel small version for my Mega ST4s... I have older but I am using them in my 520STM... Anyone who will make small series of Eiffel small V3??? With keyboard cable for MegaST... Edited July 30, 2016 by Matej 1 Quote Link to comment Share on other sites More sharing options...
+MacRorie Posted August 16, 2016 Share Posted August 16, 2016 Would like to join in on this thread. I was also looking at one of these. If there is a design somewhere for the PCB, I can *probably* take it from there. I saw a schematic for the electronics, I might be able to make that work. But more information would make it easier. Okay, found the schematic. Now need to figure out what the values of the components are. Based on the photos, this *should* be replicable. Depends on the availability of the PIC chip used. No promises, but I think I can make this. Quote Link to comment Share on other sites More sharing options...
guus.assmann Posted August 16, 2016 Share Posted August 16, 2016 Hello Guys, Please find attached the complete information I have on the Eiffel inferface. It includes schematics and PCB designs. I've build at least one of the two PCB's. I cannot remember why I have two designs. Usually, the newest is the one I made. What I did, was make a copy of all relevant PDF's on a transparant film. Then glue the sheets together, with a piece of PCB in between as a guidance for the Photo-sensitive PCB. The design was made with Ultiboard. Now know as Multisim. BR/ Guus PCBS.zip Quote Link to comment Share on other sites More sharing options...
+MacRorie Posted August 17, 2016 Share Posted August 17, 2016 Hello Guys, Please find attached the complete information I have on the Eiffel inferface. It includes schematics and PCB designs. I've build at least one of the two PCB's. I cannot remember why I have two designs. Usually, the newest is the one I made. What I did, was make a copy of all relevant PDF's on a transparant film. Then glue the sheets together, with a piece of PCB in between as a guidance for the Photo-sensitive PCB. The design was made with Ultiboard. Now know as Multisim. BR/ Guus Thanks for this! It goes a long way to explaining a couple of things that were difficult to see in the original schematic. I have a couple of questions: 1. What program did you do your schematic in? I could re-do it in another program, but it would be easier to load up the original. 2. It looks like there is a daughterboard configuration for the LCD screen? You could have two lines coming off of the mainboard that connected to the 74LS174 (that controls the LCD)? 3. Is the Coldfire option necessary to build? Seems to me it is not. 4. It looks like you have a different connector for the PS/2 components. Is that true? Thanks again. Quote Link to comment Share on other sites More sharing options...
guus.assmann Posted August 17, 2016 Share Posted August 17, 2016 Hello MacRorie, 1) The schematics were done in Ulticap. This program is now part of Multisim. The .SCH file is the design. 2) The LCD is connected to the J1 connector. Yes it could have been smaller with an extra board. But I choose not to. 3) Coldfire is not needed. But at the time it looked intresting. I've not used it. Needs another processor as well. 4) The PS/2 connector is reused from a PC-MB. It's a green and purple one on top of eachother. That saved some board space. BR/ Guus Quote Link to comment Share on other sites More sharing options...
+MacRorie Posted August 17, 2016 Share Posted August 17, 2016 Guus, Thanks for the reply. Sorry about the first question. I momentarily forgot how to read Do you have a source for the PIC? Looks like there 16F876 is no longer manufactured. I can find 16F876A-I on eBay. It looks functionally equivalent (at least that is what the migration datasheets state), but if you have an alternative, that would be awesome. Is the PIC18F242 a drop in replacement? Quote Link to comment Share on other sites More sharing options...
guus.assmann Posted August 18, 2016 Share Posted August 18, 2016 Hello MacRorie, This sometimes happens to me as well. We humans are easilly distracted. :-) All data that I have available is the Zip that I've posted. I have used the 16F876A-I and that works just fine. No idea if the 18F242 is a possible replacement. The source code is in the data as well. Just look at the directory "Sources\firmware: Eiffel.asm" One challenge or disadvantage. All comment is in French language. And that's not so easy if it's not your native langage. Make sure you put both the program and the EEprom data in the processor. (I forgot about the EEprom and then it won't work) BR/ Guus Quote Link to comment Share on other sites More sharing options...
Matej Posted August 18, 2016 Author Share Posted August 18, 2016 Some people in Czech and Poland are still doing Eiffels... Quote Link to comment Share on other sites More sharing options...
+MacRorie Posted August 18, 2016 Share Posted August 18, 2016 Hello MacRorie,This sometimes happens to me as well. We humans are easilly distracted. :-)All data that I have available is the Zip that I've posted.I have used the 16F876A-I and that works just fine.No idea if the 18F242 is a possible replacement.The source code is in the data as well. Just look at the directory "Sources\firmware: Eiffel.asm"One challenge or disadvantage. All comment is in French language. And that's not so easy if it's not your native langage.Make sure you put both the program and the EEprom data in the processor. (I forgot about the EEprom and then it won't work)BR/Guus Okay, well, I have ordered parts. The semester is starting up, so time will be precious as I start teaching again, but I think this should be doable soon. Thanks for the head's up on the program and eeprom data. I will keep that in mind. Thanks for the help! Quote Link to comment Share on other sites More sharing options...
vattari Posted December 1, 2017 Share Posted December 1, 2017 Some people in Czech and Poland are still doing Eiffels... I know this is over a year old, but would you know if these people are still producing the Eiffel adapter? Sent from my iPhone using Tapatalk Quote Link to comment Share on other sites More sharing options...
