Grig Posted July 31, 2016 Share Posted July 31, 2016 Any fix for this or just a new board? the 130XE is pretty dusty and a bit discolored. Everything on screen looks "mirrored" or "shadowed". Thanks Quote Link to comment Share on other sites More sharing options...
phaeron Posted July 31, 2016 Share Posted July 31, 2016 Check your TV/monitor settings -- you probably have a Sharpness or Edge Enhancement setting turned too high and the display is oversharpening the video input. The tipoff is that the halos on the first screen are uniform and happen vertically as well as horizontally. Issues with the video signal would show mainly horizontal artifacts. Quote Link to comment Share on other sites More sharing options...
Rybags Posted August 1, 2016 Share Posted August 1, 2016 Before even doing that - what video output is being used? Forget RF, it's a waste of time. Composite is barely acceptable. Either make or buy a cable so you can use S-Video. Although the problem there is that modern TVs are phasing it out. Quote Link to comment Share on other sites More sharing options...
Grig Posted August 1, 2016 Author Share Posted August 1, 2016 composite but S video is an option Quote Link to comment Share on other sites More sharing options...
