+Vorticon Posted October 20, 2023 Share Posted October 20, 2023 So I reflashed my arduino with the latest HEXTIr.hex using avrdude, and now I am unable to open files nor save, although I can still OLD files on the SD card. I reverted back to my original file but the problem persisted. I checked the connection points on the shield and everything seems to be OK, but I'm suspecting my shield is acting up here. Any pointers on debugging? Quote Link to comment Share on other sites More sharing options...
brain Posted October 21, 2023 Share Posted October 21, 2023 I don't have many that are easy to try. There's debug statements in the code, but you'd need to recompile. A logic analyzer might help as well, but most folks don't have one. You might try grabbing older versions of the code and seeing if that does anything (if it's the shield, it won't, but it might not be the shield). I'm trying to free up some time to get this back on the bench and debug (I was planning to debug the set device command initially), but it might be a week or so, as there's lot in my list to get done first. Quote Link to comment Share on other sites More sharing options...
brain Posted October 21, 2023 Share Posted October 21, 2023 When I do get some time, I'll see if I can strip out all the code and just make a simple test app, that uses some LEDs to test things. 1 Quote Link to comment Share on other sites More sharing options...
+Vorticon Posted October 21, 2023 Share Posted October 21, 2023 Just a quick update. I poked around the SD shield again testing the continuity of connections as well as logic signals and could not find any issues. So I put the drive back together again and it worked fine this time around, except for the SE DEV command which gives an IO ERROR 1, meaning that the command was not recognized as valid. This is using the latest HEXTIr.hex build. All other commands seem to work as they should (MD, DEL, CD etc...), so I think the SE DEV command is either buggy or there an implementation error somewhere. If anyone here can double check this it would be great to make sure the issue is not on my end. Just run the following command: OPEN #255,"20.SE DEV=21". If you do not get an error then try CLOSE #255 and you should get an expected error there since device 20 is now 21. Quote Link to comment Share on other sites More sharing options...
brain Posted October 22, 2023 Share Posted October 22, 2023 I don't think open #255,"se dev=21" will work. THere's no device number in the open statement. Checking my manual, open needs to be : open #<channel>, "<device_number>.<open parms>" So, I think it's open #255,"20.se dev=21" And then the close will fail, because device 20 is gone, but you need to do it to clean up the BASIC pointers. Then, try to open #255,"20.b=9600" should succeed. If the se dev=21 works, then the next step really should be to do open #255,"21.st", which is supposed to permanently store the new device number. Quote Link to comment Share on other sites More sharing options...
+Vorticon Posted October 22, 2023 Share Posted October 22, 2023 Sorry that was a typo on my part. Yes indeed the device number needs to be in the OPEN statement as you stated and that is what I have been doing (I amended my post). Does not work... Are you sure about the command syntax? Quote Link to comment Share on other sites More sharing options...
+Vorticon Posted October 22, 2023 Share Posted October 22, 2023 So I started looking at the HEXOPS.cpp file and found the following definitions: static const action_t cmds[] MEM_CLASS = { {EXEC_CMD_DEV,"de"}, {EXEC_CMD_DEV,"dev"}, {EXEC_CMD_STORE,"st"}, {EXEC_CMD_STORE,"store"}, {EXEC_CMD_NONE,""} }; So DE and DEV are equivalent. Now looking at the code for the DEV command below, shouldn't the default to the first switch statement use the parse_cmd function instead of the parse_equate function to extract the requested command? I'm not really familiar with the C syntax, but it seems that the former function is used for the STORE command, which actually works, but not for the DEV command which does not... cmd = (execcmd_t)parse_cmd(cmds, &buf, &len); // if a cmd, i will point to location after cmd // and cmd will equal type requested if(cmd != EXEC_CMD_NONE) { //skip spaces trim (&buf, &len); } switch (cmd) { case EXEC_CMD_STORE: ee_set_config(); break; default: cmd = (execcmd_t)parse_equate(cmds, &buf, &len); switch(cmd) { case EXEC_CMD_DEV: if(dev != NULL) { rc = HEXSTAT_DATA_ERR; // value too large or not a number if(!parse_number(&buf, &len, 3, &value)) { if(value <= DEV_MAX) { rc = HEXSTAT_DATA_INVALID; // no such device for(i = 0; i < registry.num_devices; i++) { if( (registry.entry[i].dev_low <= (uint8_t)value) && (registry.entry[i].dev_high >= (uint8_t)value) ) { registry.entry[i].dev_cur = (uint8_t)value; *dev = (uint8_t)value; rc = HEXSTAT_SUCCESS; break; } } } } } else { rc = HEXSTAT_DATA_INVALID; } break; default: // error rc = HEXSTAT_OPTION_ERR; break; } break; } return rc; } Quote Link to comment Share on other sites More sharing options...
brain Posted October 22, 2023 Share Posted October 22, 2023 I used my comment as well, but I think my comment is wrong. Since st works, try just doing open #255,"20.de=21" I checked the source and there is no "set" or "se" in the entire source, so I must have decided to punt and just make the parms verbs themselves. My apologies. If your test works, I'll update the code. For anyone who cares: (main.cpp) The main parser reads the hex data, and determines the operation is open, and to the serial device. It checks the registry that every specific soft peripheral registers with (registry.cpp) to find an entry to device 20. It finds the serial.cpp library, so jumps to that. IN serial.cpp, there is ser_open(), which does the open. To ensure compatibility with HEXTIr's way to handling configuration when using the drive peripheral, where an open of some text would normally try to open a file with that name, the code (line 342) checks for channel 255. If found, it immediately starts parsing config, but otherwise, it drops down and tries to do an actual open of a serial part, but it also handles configs there as well. Both branches call ser_exec_cmds(). ser_exec_cmds() (line 279) tries to break apart the string into pieces, and then it sends each piece to ser_exec_cmd() (line 87) ser_exec_cmd tries to match the first few letters of the command to one of two lists, shown in lines 61-85. A cc40 list (b, .ba, d, .da, etc.) and a ti list of additional items (.tw,.nu, etc.). if the command is not in the first set, then it drops into the default case (line 251) and checks the second set. if that list doesn't work, it then calls hex_exec_cmd() in line 273 hexops.cpp contains the default config helper function, hex_exec_cmd() line 306. Just like in serial.cpp, there is a list of commands about the function, as @Vorticon shows. de and dev are both mapped to command DEV, while st, store are both mapped to STORE. When the command is parsed into EXEC_CMD_DEV or EXEC_CMD_STORE, the switch statement in lines 327-342 kicks in. If CMD_ST is found, do it. Otherwise, the code assumes its a "cmd=value" pair, and so tries to parse it. ONce parsed, it checks if the cmd was DEV, and if so, it updates the registry with the new device ID. 1 Quote Link to comment Share on other sites More sharing options...
+Vorticon Posted October 22, 2023 Share Posted October 22, 2023 Yeah that was the first command I tried until you asked me to use SE DEV instead. No dice unfortunately. Quote Link to comment Share on other sites More sharing options...
brain Posted October 23, 2023 Share Posted October 23, 2023 Dang, I forgot about that. You are most correct, apologies for that as well. Do you have a way to recompile the code? If so, you can alter the dev in the code for now, while I work on the issue. Eitehr st is failing silently, and the code never gets called, or the parse_equate is broken. Jim Quote Link to comment Share on other sites More sharing options...
+Vorticon Posted October 23, 2023 Share Posted October 23, 2023 5 hours ago, brain said: Dang, I forgot about that. You are most correct, apologies for that as well. Do you have a way to recompile the code? If so, you can alter the dev in the code for now, while I work on the issue. Eitehr st is failing silently, and the code never gets called, or the parse_equate is broken. Jim Sorry I don't have the tools to compile CPP. Hopefully it's a minor bug. Out of curiosity, why was device 20 chosen for the on board RS232 since it was expected to conflict with the external device? I'm assuming it was to maintain compatibility with existing applications that use the RS232 and expect it to be device 20. I wonder how many users here have had a need for that. Quote Link to comment Share on other sites More sharing options...
+Vorticon Posted November 4, 2023 Share Posted November 4, 2023 Any luck with this issue Jim? Quote Link to comment Share on other sites More sharing options...
+Vorticon Posted December 17, 2023 Share Posted December 17, 2023 All working now. CC40 receiving data from my scratch-built wireless weather station on my deck 1 floor up, processing it and logging it on the SD drive 🙂 7 Quote Link to comment Share on other sites More sharing options...
brain Posted December 17, 2023 Share Posted December 17, 2023 Yay! 1 Quote Link to comment Share on other sites More sharing options...
Appeelicious Posted December 30, 2023 Share Posted December 30, 2023 On 12/17/2023 at 10:10 AM, Vorticon said: All working now. CC40 receiving data from my scratch-built wireless weather station on my deck 1 floor up, processing it and logging it on the SD drive 🙂 Very cool set up. Is the HexTIr connected to serial or do you have an actual rs232 box under it? Quote Link to comment Share on other sites More sharing options...
+Vorticon Posted December 30, 2023 Share Posted December 30, 2023 It's connected to the hexbus RS232 peripheral. 2 Quote Link to comment Share on other sites More sharing options...
+dhe Posted January 1 Share Posted January 1 Does the hex-ti-r emulate an rs232? Next to a waffer tape, needed for storage, the rs232 for i/o with the outside is the second most needed peripheral. Quote Link to comment Share on other sites More sharing options...
+Vorticon Posted January 2 Share Posted January 2 24 minutes ago, dhe said: Does the hex-ti-r emulate an rs232? Next to a waffer tape, needed for storage, the rs232 for i/o with the outside is the second most needed peripheral. It does and is assigned device #20 which is the same as the hexbus rs232 peripheral. 1 Quote Link to comment Share on other sites More sharing options...
+dhe Posted January 2 Share Posted January 2 38 minutes ago, Vorticon said: It does and is assigned device #20 which is the same as the hexbus rs232 peripheral. So why did you go with a hexbus rs232, instead of running it through the hex-ti-r? Was it just ease of cabling? Quote Link to comment Share on other sites More sharing options...
+Vorticon Posted January 2 Share Posted January 2 1 hour ago, dhe said: So why did you go with a hexbus rs232, instead of running it through the hex-ti-r? Was it just ease of cabling? Pretty much I did not have the needed adapter and I have currently no other use for the RS232 peripheral so may as well put it to good use. It also has a parallel port so I may at some point print out data to a printer as well. 1 Quote Link to comment Share on other sites More sharing options...
mrvan Posted March 10 Share Posted March 10 Has the idea of an external display for the CC-40 been realized, other than the small number TI produced? I'm all in for one. I was thinking about the hexbus device's RS232 port and the possibility of connecting it via RS232-USB dongle to a Raspberry PI with connected monitor. I'm sure this wouldn't break any speed records but 9600 baud, assuming that's the max for this device, isn't terrible, at least for text. Many of us used VT terminals back in the day and many were operating at that speed, and also had ability to create text effects such as bold, reverse video and colors. Although this wouldn't be deeply integrated (ROM-based) without a lot of work, it'd be pretty easy to write a handful of BASIC methods to at least prove the idea. Other than the speed limitation, it also wouldn't be terribly difficult to emulate more advanced features with a Linux application with a linked graphics package such as SDL, and have that app connect via the USB/serial. I imagine with a bit more ingenuity an external keyboard could also be attached via the RPI. 1 Quote Link to comment Share on other sites More sharing options...
+Vorticon Posted March 10 Share Posted March 10 2 hours ago, mrvan said: Has the idea of an external display for the CC-40 been realized, other than the small number TI produced? I'm all in for one. I was thinking about the hexbus device's RS232 port and the possibility of connecting it via RS232-USB dongle to a Raspberry PI with connected monitor. I'm sure this wouldn't break any speed records but 9600 baud, assuming that's the max for this device, isn't terrible, at least for text. Many of us used VT terminals back in the day and many were operating at that speed, and also had ability to create text effects such as bold, reverse video and colors. Although this wouldn't be deeply integrated (ROM-based) without a lot of work, it'd be pretty easy to write a handful of BASIC methods to at least prove the idea. Other than the speed limitation, it also wouldn't be terribly difficult to emulate more advanced features with a Linux application with a linked graphics package such as SDL, and have that app connect via the USB/serial. I imagine with a bit more ingenuity an external keyboard could also be attached via the RPI. Great idea. I suppose an external keyboard and monitor could be attached for development purposes and subsequently disconnected for regular use. 1 Quote Link to comment Share on other sites More sharing options...
+FarmerPotato Posted March 10 Share Posted March 10 There's a thread about this somewhere here. It has the display device protocol in it--for the one that Texas Instruments had working. I found a cheap (<$20) VFD display. Futaba brand, I think. 40x4. Chars are 5x7 dots. Usual ASCII characters and 7 ? Slots for user-defined chars. Interface by I2C or SPI (just send it 8 bits for a char.) Thought that would be a nice upgrade. *VFD=Vacuum Fluorescent Display, what we had on VCRs before blue LEDs. (hate blue LEDs.) Speak n Spell type. Quote Link to comment Share on other sites More sharing options...
mrvan Posted March 11 Share Posted March 11 I've started taking a stab at connecting the HEXTIr via serial port to a RPI, but not getting very far. I always receive 830 bytes from the below programs, where every byte is hex 00, regardless of any baud rate, parity or stop bit permutation. It's possible I'm missing the syntax for the serial port open on line 100 to set baud rate, etc. but the only syntax I found was for the TI-99 and the CC-40 seems to require something different and I've not found any documentation or examples. If @brain or others could share their method for checking out the serial port that would be helpful and I'd gladly plagiarize. The BASIC program is 100 open #1,"20", display, output 105 for i=1 to 50 110 print "hello world!" 115 next i 120 close #1 The C program I used on the RPI, permuting through the baud, parity and stop bits, is // C library headers #include <stdio.h> #include <string.h> // Linux headers #include <fcntl.h> // Contains file controls like O_RDWR #include <errno.h> // Error integer and strerror() function #include <termios.h> // Contains POSIX terminal control definitions #include <unistd.h> // write(), read(), close() int main() { // Open the serial port. Change device path as needed (currently set to an standard FTDI USB-UART cable type device) int serial_port = open("/dev/ttyUSB0", O_RDWR); // Create new termios struct, we call it 'tty' for convention struct termios tty; // Read in existing settings, and handle any error if(tcgetattr(serial_port, &tty) != 0) { printf("Error %i from tcgetattr: %s\n", errno, strerror(errno)); return 1; } tty.c_cflag &= ~PARENB; // Clear parity bit, disabling parity (most common) tty.c_cflag &= ~CSTOPB; // Clear stop field, only one stop bit used in communication (most common) tty.c_cflag &= ~CSIZE; // Clear all bits that set the data size tty.c_cflag |= CS8; // 8 bits per byte (most common) tty.c_cflag &= ~CRTSCTS; // Disable RTS/CTS hardware flow control (most common) tty.c_cflag |= CREAD | CLOCAL; // Turn on READ & ignore ctrl lines (CLOCAL = 1) tty.c_lflag &= ~ICANON; tty.c_lflag &= ~ECHO; // Disable echo tty.c_lflag &= ~ECHOE; // Disable erasure tty.c_lflag &= ~ECHONL; // Disable new-line echo tty.c_lflag &= ~ISIG; // Disable interpretation of INTR, QUIT and SUSP tty.c_iflag &= ~(IXON | IXOFF | IXANY); // Turn off s/w flow ctrl tty.c_iflag &= ~(IGNBRK|BRKINT|PARMRK|ISTRIP|INLCR|IGNCR|ICRNL); // Disable any special handling of received bytes tty.c_oflag &= ~OPOST; // Prevent special interpretation of output bytes (e.g. newline chars) tty.c_oflag &= ~ONLCR; // Prevent conversion of newline to carriage return/line feed // tty.c_oflag &= ~OXTABS; // Prevent conversion of tabs to spaces (NOT PRESENT ON LINUX) // tty.c_oflag &= ~ONOEOT; // Prevent removal of C-d chars (0x004) in output (NOT PRESENT ON LINUX) tty.c_cc[VTIME] = 10; // Wait for up to 1s (10 deciseconds), returning as soon as any data is received. tty.c_cc[VMIN] = 0; // Set in/out baud rate to be 9600 cfsetispeed(&tty, B9600); cfsetospeed(&tty, B9600); // Save tty settings, also checking for error if (tcsetattr(serial_port, TCSANOW, &tty) != 0) { printf("Error %i from tcsetattr: %s\n", errno, strerror(errno)); return 1; } // Write to serial port unsigned char msg[] = { 'H', 'e', 'l', 'l', 'o', '\r' }; write(serial_port, msg, sizeof(msg)); // Allocate memory for read buffer, set size according to your needs char read_buf [256]; // Normally you wouldn't do this memset() call, but since we will just receive // ASCII data for this example, we'll set everything to 0 so we can // call printf() easily. memset(&read_buf, '\0', sizeof(read_buf)); // Read bytes. The behaviour of read() (e.g. does it block?, // how long does it block for?) depends on the configuration // settings above, specifically VMIN and VTIME int num_bytes; int i; while (1) { num_bytes = read(serial_port, &read_buf, sizeof(read_buf)); // n is the number of bytes read. n may be 0 if no bytes were received, and can also be -1 to signal an error. if (num_bytes < 0) { printf("Error reading: %s", strerror(errno)); return 1; } // Here we assume we received ASCII data, but you might be sending raw bytes (in that case, don't try and // print it to the screen like this!) // printf("Read %i bytes. Received message: %s", num_bytes, read_buf); if (num_bytes) { fprintf (stdout, "%d: ", num_bytes); for (i = 0; i < num_bytes; i++) { fprintf (stdout, "%d ", read_buf[i]); } fputs ("\n", stdout); fflush (stdout); } } close(serial_port); return 0; // success }; Quote Link to comment Share on other sites More sharing options...
brain Posted March 11 Share Posted March 11 The defaults in the code are: https://github.com/go4retro/HEXTIr/blob/51ea22df26cbc6beedb13e90dd0e530246948a9c/src/serial.cpp#L569-L584 _config.ser.bpsrate = 300; _config.ser.echo = TRUE; // TODO see exactly what this means. _config.ser.length = LENGTH_7; _config.ser.line = LINE_CRLF; _config.ser.nulls = 0; _config.ser.overrun = _cfg.overrun; _config.ser.parchk = FALSE; _config.ser.parity = PARITY_ODD; _config.ser.stopbits = STOP_0; _config.ser.xfer = XFER_REC; The XFER_REC should cause an issue, as defined by the HexBus-Specifications.pdf doc, page 242, but it looks like I did not implement it at all, so all XFER_* behave like XFER_CHAR, which is char in, char out... See if those settings help. If not, I'd hook it up to a terminal program and boot the system. It might be that your build has debugging, which is either 57600 or 115200/n/8/1, and it overrides serial. If so, my bad. I try to turn it off when a build is ready, but I might forget at times. If you need debugging, I can help, but it'll be a week, as I can't get to my lab this week. Jim Quote Link to comment Share on other sites More sharing options...
