cris_add Posted May 1, 2003 Share Posted May 1, 2003 I have a couple of PAL Atari 2600s and am in Australia; and, there seems to be a greater lack of compatible Atari Power supplies in this region, so... I was wondering if anyone has any information or experience on flexibility on the Atari 2600 Power Supply, output Voltage, and output current. I know the standard one is 9VDC at 500mA. I am also aware that the Atari 2600 power regulator drops this down to 5VDC. This also means you could "probably" (I am not really sure) use an input range from about 6VDC to 9VDC. I guess my big question is.. what is the flexibility on the output current? Does this always have to be 500mA? Is there anyone who has an Atari 2600 running on any other ouput current setting? From what I understand the US and Aus 2600 consoles have exactly the same interal power mechanism. So any experience (world wide) would be relevant. Any help appreciated... Thanks... Chris Link to comment Share on other sites More sharing options...
+5-11under Posted May 1, 2003 Share Posted May 1, 2003 The Atari draws about 300 mA. This can vary, depending on the cartridge, so 500 mA is a good minimum for current capacity in an adapter. Voltage for the 7805 should be above about 7.5 V. Anything above that voltage just generates more heat. So a 9 V, 500 mA supply should work fine. Keep in mind that the current and voltage ratings on some adapters are way out. Just try them out, making sure the polarity is correct (positive on the tip, I think). 5-11under Link to comment Share on other sites More sharing options...
Pixellated Ghost Posted May 2, 2003 Share Posted May 2, 2003 I think the RF modulator in the Atari uses the 9V directly but not totally sure. I have one of those universal adapters and below 7.5V the picture quality starts to degrade. Link to comment Share on other sites More sharing options...
cris_add Posted May 2, 2003 Author Share Posted May 2, 2003 Thanks for the replies, this is consistent with another comment I had recieved. In that 300mA is the minimum current and 7.5V is the minimum the regulator will want to deal with... Link to comment Share on other sites More sharing options...
Eduardo Posted May 2, 2003 Share Posted May 2, 2003 I've tested several power supply's ratings with my 2600 along the way and here are my observations: The Original specs: 9v 500ma <---- This is what you should use. now if you still insist (at your own risk) okay try this: VOLTS: Recommended anything between 9v and 12v (it might survive to voltage ratings as high as 16v but you don't really want to go as high for daily use) AMPS: 500ma to 1Amp. Don't go as low as 300ma, I've had troubles running games like Asteroids. You don't really need either a PS that pumps over 1 Amp. It doesn't hurt if you use a voltmeter to test the output of your P.S. before you plug it into your 2600. Link to comment Share on other sites More sharing options...
cris_add Posted May 3, 2003 Author Share Posted May 3, 2003 Another point I had forgot to mention... I have measured the only original atari power supply I have (it says 9VDC and 500mA on the label). However on the multimeter it reads 13.5V and about 600mA. The multimeter is quite good and I had tested this against several other newer power supplies - so I suspect that it is a reasonably accurate reading. Link to comment Share on other sites More sharing options...
Eduardo Posted May 4, 2003 Share Posted May 4, 2003 hehe, that's because you did test the P.S. output unloaded. To get an accurate output reading you need to put Load on the P.S. (that means you need to plug it to your Atari and turn it on, that's called Load) You'll notice the reading on your voltmeter will drop near the specs values 9v when the Atari is switched on. You might start thinking at this point "hey if I plug it in how can I test it" well you can, but you'll have to open your Atari and test it right from the connector leads inside. Link to comment Share on other sites More sharing options...
ATARI TROLL Posted May 4, 2003 Share Posted May 4, 2003 Never go over the recommended voltage. I almost fried an Atari doing that. Link to comment Share on other sites More sharing options...
Archived
This topic is now archived and is closed to further replies.
