spacecadet Posted August 19, 2016 Share Posted August 19, 2016 So maybe some of you have seen this thread. I'm getting kinda desperate - I have several computers set up in my basement that I can't use because I have no monitor. Thought I was on track to win an auction for a Magnavox equivalent today, but it went a lot higher than I wanted to spend at the last minute. What I need is a monitor that will do digital RGB, analog RGB, composite, plus I guess S-video (the C64 output). I was told in that thread that the Commodore 1084 is probably the best option, or the Philips cm8833-ii or Magnavox Monitor 40 (CM8505 seems to be the actual model #). I'm not too concerned about cosmetic condition, as long as it works reliably. Alternatively, I'd consider just a cheap CGA monitor, and then use a TV for the older 8 bit stuff. When I search for "CGA monitor" on Ebay, everything that comes up is in the hundreds of dollars, which seems ridiculous. I will pay to ship, or if you're in the NY area, I would pick up. I'd probably be willing to drive up to 100 miles or so. Thanks... Quote Link to comment Share on other sites More sharing options...
Osgeld Posted August 20, 2016 Share Posted August 20, 2016 I dont have a monitor but over the 4th of july I had a week off and cobbled together a CGA to NTSC adapter. its not perfect and its black n white only but it may be of some use to you until you get a monitor http://atariage.com/forums/topic/254485-recording-cga-monochrome-graphics-to-youtube/?p=3546595 Quote Link to comment Share on other sites More sharing options...
