Shift838 Posted August 26, 2016 Share Posted August 26, 2016 Does anyone have a copy of the NanoPEB Version 2 manual? Quote Link to comment Share on other sites More sharing options...
bchamb88 Posted August 26, 2016 Share Posted August 26, 2016 Let me fire up a PC Desktop tomorrow and see if the PDF is on it. I'm sure I have a hard copy somewhere I can rescan. Quote Link to comment Share on other sites More sharing options...
Omega-TI Posted August 26, 2016 Share Posted August 26, 2016 There was a V2 manual? I didn't know that. The latest one I knew about was this one... nanoPEB-SIO_V1-rev1.0-04.Aug.2010-UserMan.pdf 1 Quote Link to comment Share on other sites More sharing options...
Sinphaltimus Posted August 26, 2016 Share Posted August 26, 2016 (edited) Does anyone have a copy of the NanoPEB Version 2 manual? Are you sure it exists? To spite the fact the webpage for nanopeb no longer available, the files directories still work and I don't see it in there. http://webpages.charter.net/nanopeb/downloads/nanoPEB/docs/ Edited August 26, 2016 by Sinphaltimus 1 Quote Link to comment Share on other sites More sharing options...
Shift838 Posted August 26, 2016 Author Share Posted August 26, 2016 i almost swore there was one. Now all of you have me thinking that the only modification that was really done from the manual was actually maybe just on the main site to show the differences for the RS232 open command: nanoPEB (Version 1) nanoPEB Version 1 uses the TMS9902 UART for traditional performance. It provides an RS-232 port named "RS232". Features: CPU RAM - 32K - Fully compatible with Extended BASIC and Editor/Assembler Emulates of three floppy drives - DSK1, DSK2 and DSK3 Comes with a Compact Flash - Compact Flash is preloaded with CFMGR. Virtual 400kb diskettes (called "volumes") Original 99/4a diskette was only 90kb! Serial Port "RS232" - uses standard DB-9 cables (needs null modem cable to connect to PC). Baud rate up to 9600. Built-in BASIC commands lets you format and mount volumes into the emulated disk drives. Sample OPEN command in BASIC: - OPEN #1:"RS232.BA=9600.DA=8.PA=N.EC" nanoPEB (Version 2) nanoPEB Version 2 uses the 16C550 UART for higher performance. It provides an RS-232 port named "COM1" which replaces the PIO port found in CF7+. Features: CPU RAM - 32K - Fully compatible with Extended BASIC and Editor/Assembler Emulates of three floppy drives - DSK1, DSK2 and DSK3 Comes with a Compact Flash - Compact Flash is preloaded with CFMGR. Virtual 400kb diskettes (called "volumes") Original 99/4a diskette was only 90kb! Serial Port "COM1"/"RS232" - uses standard DB-9 cables (needs null modem cable to connect to PC). Baud rate up to 115200! Built-in BASIC commands lets you format and mount volumes into the emulated disk drives. Sample OPEN command in BASIC: - OPEN #1:"RS232.BA=115200.DA=8.PA=N.EC" OPEN #1:"COM1.BA=115200.DA=8.PA=N.EC" New! Compatible version of Fred Kaal's CFHDXS1 1 Quote Link to comment Share on other sites More sharing options...
Shift838 Posted August 26, 2016 Author Share Posted August 26, 2016 Maybe there should be a spot on the FTP site to have all the current docs/programs in once spot for the NanoPEB and CF7+ ? If there is one there I did not find it. Quote Link to comment Share on other sites More sharing options...
Omega-TI Posted August 26, 2016 Share Posted August 26, 2016 Other than the most recent one I posted, there is the latest one I have on the CF7 and a couple of obsolete manuals. CF7_plus-rev3.0.pdf CompactFlashDrivefortheTI.pdf CF7A_plus_b.pdf 1 Quote Link to comment Share on other sites More sharing options...
Omega-TI Posted August 26, 2016 Share Posted August 26, 2016 Here is a minor unauthorized 'tweak' (update) of the manual to reflect V1 & v2 nanoPEB's. nanoPEB-SIO_V1&2 update.pdf 1 Quote Link to comment Share on other sites More sharing options...
