digress Posted September 29, 2016 Share Posted September 29, 2016 Quote Link to comment Share on other sites More sharing options...
Great Hierophant Posted September 30, 2016 Share Posted September 30, 2016 It is a ribbon cable with a 62-pin card edge connector on one end and a 62-pin pin connector on the other end. It is probably custom made, which can be done easily with a vice. My advice is to keep the cable really short. 1 Quote Link to comment Share on other sites More sharing options...
soviet Posted December 2, 2016 Share Posted December 2, 2016 I have done something similar was unable to find the isa 8 bit connectors but find an alternative way to do it. You need this: http://www.ebay.com/itm/50cm-64-Pin-64-Way-F-F-Connector-IDC-Flat-Rainbow-Color-Ribbon-Cable-/122078882810?hash=item1c6c77ebfa:g:eMsAAOSwZJBX~zP5 An isa connector from a old motherboard and also one of this. http://www.ebay.com/itm/10x-IDC-64-Pin-Male-Header-Connector-Vertical-with-Ejection-Latch-/192010004539?hash=item2cb4b0283b:g:iysAAOxyyeNSL0jn Then you solder the idc header to the isa slot pins and you are done. 2 pins are going to get out just left them unsoldered. Quote Link to comment Share on other sites More sharing options...
