+orpheuswaking Posted September 11, 2016 Share Posted September 11, 2016 I attempted to flash several items to bank two on my SB v2 using Jiffi and the bank two option checked. It would load the game into memory but not actually flash the bank. After I turned off the jag and back on the old program was still in bank 2 (and it did not flash to bank 1) I used JCP directly and it worked fine. Any ideas? Quote Link to comment Share on other sites More sharing options...
+rdemming Posted February 19, 2017 Share Posted February 19, 2017 Same problem here. Jiffi is always flashing the first bank regardless of the "bank 2" check box setting. I suppose Jiffi is not correctly sending the -2 option to JCP.exe as the DOS box with JCP output does not show it is flashing back 2 while it does when starting JCP with the -2 option from the commandline. Its time for a Jiffi update too as the JCP included is an older version Robert 1 Quote Link to comment Share on other sites More sharing options...
