FCG88 Posted October 8, 2016 Share Posted October 8, 2016 Hello, First of all, sorry for my English. I will try to explain my problems. I have 2 GameGears. GameGear 1: This GameGear just had a black screen, contrast wheel did not work either. So I replaced all the capacitors.. Unfortunately this does not work, so I looked at the contrast wheel. I heat the soldering points. This worked a little The contrast wheel is working again and I can see a faint image on the GameGear which slowly fades away.. What must I do more to see a good image again on the GameGear? GameGear 2: This GameGear goes right out when you turn it on.. So I replaced all the capacitors.. Unfortunately this does not work, I also replace the power board. The problem is still the same.. Hope u guys can help me out? Quote Link to comment Share on other sites More sharing options...
