ZackAttack Posted November 3, 2016 Share Posted November 3, 2016 We can draw the playfield behind the 96 pixels, but only a symmetrical one as the kernel's too busy mid-screen updating the players & colors to also update the playfield registers for the right side. Perhaps it could be done with a repeating PF instead of mirrored. Also, I'd recommend changing the way the players are staggered. Instead of this: 01 01 01 01 01 01 Do this: 0 0 0 1 1 1 0 0 0 1 1 1 That spreads the writes over 8 more pixels and puts a gap in the middle since the first instance of 1 can be set ahead of time. With the repeating PF you can have PF0-PF2 pre filled for the left side and some wiggle room when updating the right side. Quote Link to comment Share on other sites More sharing options...
+SpiceWare Posted November 3, 2016 Author Share Posted November 3, 2016 That won't work. Each update to TIA takes 3 cycles, so 6 cycles to update shape and color. In 6 cycles TIA will output 18 pixels. With 8 pixels between each instance of 0 (and 1) there's no way to update shape and color. Symmetrical doesn't mean the playfield is mirrored, it just means the playfield data on the left side is also used on the right. An asymmetrical playfield updates the registers mid-screen so both sides are different. It's possible to have an asymmetrical mirrored playfield - that's how Stay Frosty was done. Quote Link to comment Share on other sites More sharing options...
ZackAttack Posted November 3, 2016 Share Posted November 3, 2016 I assumed symmetric implied mirrored for this specific application because a repeating symmetric PF would be impossible to align with only the center 96 pixels. I also assumed the BUS driver supported the read modify write form of bus stuffing which gets you two adjacent write cycles at the end of the 5 cycle instruction. Without that you run out of time. The video you posted looks better than I expected. The tile sized movement actually looks pretty good. Definitely some good RPG potential here. Quote Link to comment Share on other sites More sharing options...
+SpiceWare Posted November 3, 2016 Author Share Posted November 3, 2016 I assumed symmetric implied mirrored for this specific application because a repeating symmetric PF would be impossible to align with only the center 96 pixels. I think Chris' original code used mirrored. It originally turning video on/off during the scanline so I was going to try repeated as the left instance of PF0 and the right instance of PF2(maybe) would be hidden, so I'd only have to squeeze in an update for PF1 on the right: But another test using a 128 pixel display over an asymmetrical playfield: caused us to reconsider using the playfield as we didn't care for the transparency that results from using 30 Hz flicker. I also assumed the BUS driver supported the read modify write form of bus stuffing which gets you two adjacent write cycles at the end of the 5 cycle instruction. We did some tests using Quad Stuffing: Here is something rather cool - I managed to get bus stuffing working with the ROR instruction, which allows 2 TIA writes in 5 cycles. It is rather more complex than stuffing the STY instruction, which requires a single bus stuffing operation on the data bus. Stuffing the ROR instruction requires 4 bus stuffing operations - 2 for the address bus and 2 for the data bus (so I'm calling it quad stuffing). The following table illustrates what is going on: Operation Address Bus Data Bus Cycle 1 Read ROR PC ROR Cycle 2 Read $FF PC + 1 $FF Cycle 3 Read value at $FF $FF value at $FF Cycle 4 Write original value to $FF $FF (stuff) value at $FF (stuff) Cycle 5 Write RORd value to $FF $FF (stuff) RORd value (stuff) To make this work, it is necessary to store $FF at location $FF, and set the carry flag, i.e: lda #$FF sta $FF sec ... ror $FF But the timing required for PAL and NTSC consoles is different - what worked on Chris' PAL system didn't work on mine. We decided to back burner it and concentrate on what was working. The video you posted looks better than I expected. The tile sized movement actually looks pretty good. Definitely some good RPG potential here. I'm hoping somebody runs with it once we finish the driver and make everything available, as after that I plan to finish Draconian, Frantic and Timmy! 2 Quote Link to comment Share on other sites More sharing options...
+SpiceWare Posted November 6, 2016 Author Share Posted November 6, 2016 There's been a revision to the Bus Driver so I've migrated the RPG demo over to the new version. The cave system's a little larger than before. rpg_20161106_NTSC.bin rpg_20161106_PAL.bin Quote Link to comment Share on other sites More sharing options...
+SpiceWare Posted November 16, 2016 Author Share Posted November 16, 2016 NOTE: This was originally posted in this topic. There's many ways to implement BUS Stuffing, these answers are specific to the driver we're currently developing for the Harmony/Melody. The 6507 is instructed to STY $FF in an infinite loop.While it's possible to use STY $FF then stuff the address and the data, timing is difficult for 2+ bus stuffing events per instruction so we only stuff the data. As such, we still have to write the kernel in 6507 code. For the current build of Draconian the upper part of this display (above the green line): Is created using this kernel: ldx #0 ... stx STUFFMODE ; 4 13 - turn on bus stuffing ldy #$FF ; 2 15 sty VDELP0 ; 3 18 sty VDELBL ; 3 21 jmp VBentry ; 3 24 RealNormalKernel: ; - 20 43 ; 43 is latest to get here sty Size ; 3 24 46 not used, read to keep stream in sync R46color: ; - 46 ; 46 is latest to get here sty Color ; 3 28 49 not used, read to keep stream in sync R49: ; - 49 ; 49 is latest to get here sty HMP0 ; 3 31 52 - no HMCLR needed as we are setting them all sty HMP1 ; 3 34 55 sty HMM0 ; 3 37 58 sty HMM1 ; 3 40 61 sty HMBL ; 3 43 64 VBentry: ; - 64 R64: ; - 64 ; 64 is latest to get here sty GRP0 ; 3 46 67 - VDELP0 on, so this is for next scanline sty ENABL ; 3 49 70 - VDELBL on, so this is for next scanline sty NextKernel ; 3 52 73 R73: ; - 73 ; 73 is latest to get here sta WSYNC ; 3 55 76/0 R76: ; - 76/0 ; at this point GRP0, ENABL and all HMxx values are loaded sta HMOVE ; 3 3 sty GRP1 ; 3 6 - also updates GRP0 and ENABL due to VDELxx sty ENAM0 ; 3 9 sty ENAM1 ; 3 12 jmp (NextKernel) ; 5 17 ... align 256 ; 17 NormalKernel: jmp RealNormalKernel ; 3 20 ExitKernel: jmp RealExitKernel ; 3 20 Resp0Strobe23: jmp RealResp0Strobe23 ; 3 20 Resp0Strobe28: jmp RealResp0Strobe28 ; 3 20 Resp0Strobe33: jmp RealResp0Strobe33 ; 3 20 ... RealResp0Strobe38: ; - 20 dec Sleep5 ; 5 25 RealResp0Strobe33: ; - 20 dec Sleep5 ; 5 25 30 RealResp0Strobe28: ; - 20 dec Sleep5 ; 5 25 30 35 RealResp0Strobe23: ; - 20 sta RESP0 ; 3 23 28 33 38 sty NUSIZ0 ; 3 26 31 36 41 sty COLUP0 ; 3 29 34 39 44 jmp R49 ; 3 32 37 42 47 ... The JumpDatastream (used by sty NextKernel) is currently filled with 0 so every jmp (NextKernel) instruction will go to NormalKernel. The very last value in JumpDatastream is 3, so the final jmp (NextKernel) goes to ExitKernel which is when the green line is drawn. Eventually JumpDatastream will be filled with other values, such as 9 which would cause it to go to Resp0Strobe28 so player0 can be repositioned and reused. There will eventually be Resp1, Resm0, Resm1 and Resbl routines to reposition the other 4 moveable objects. At the same time, C code is running on an ARM core that is updating registers in memory based on how you've programmed your game.Before the kernel runs your custom C code has to prep a bunch of data and store it in datastreams. For the above, these are the datastreams: ;---------------------------------------- ; Set this to adjust scanlines used for gameplay game area. ; The +5 is for 5 scanlines to reposition all objects, ; this will be consistantly 5 scanlines vs using PosObject which ; uses an additional scanline for each object that is on the ; right side of the screen ;---------------------------------------- DATASTREAM_SIZE = 160 + 5 JumpDataStream: ds DATASTREAM_SIZE-1 ExitJumpDataStream: ds 1 align 2 ; ARM accesses via unsigned short int (WORD) GRP0_HMP0_DataStream: ds DATASTREAM_SIZE*2 ds 2 ; Kernel done, turns off player0 align 2 ; ARM accesses via unsigned short int (WORD) GRP1_HMP1_DataStream: ds DATASTREAM_SIZE*2 ds 2 ; Kernel done, turns off player1 ENAM0_HMM0_DataSream: ; 0.5 increment. Upper nybble HMM0, bit 1 ENAM0 ds DATASTREAM_SIZE ds 1 ; Kernel done, turns off missile 0 ENAM1_HMM1_DataSream: ; 0.5 increment. Upper nybble HMM1, bit 1 ENAM1 ds DATASTREAM_SIZE ds 1 ; Kernel done, turns off missile 0 ENABL_HMBL_DataStream: ; 0.5 increment. Upper nybble HMM1, bit 1 ENAM1 ds DATASTREAM_SIZE ds 1 ; Kernel done, turns off missile 0 Color_DataStream: ; new color of object being repositioned ds DATASTREAM_SIZE Size_DataStream: ; new size of object being repositioned ds DATASTREAM_SIZE The streams are laid out in the 6507 code in Display Data RAM. The 6507 code has a bunch of ECHO statements: echo "// datastreams" echo "#define DATASTREAM_SIZE ",[DATASTREAM_SIZE]d echo "#define JUMP_DATASTREAM ",[JumpDataStream]d ... That output this: #define DATASTREAM_SIZE 165 #define JUMP_DATASTREAM 8 ... That's copied over to the C code where it uses those defines to make pointers like this: unsigned short int * const gPlayer0Datastream =(unsigned short int *)(DD_BASE + PLAYER0_DATASTREAM); unsigned short int * const gPlayer1Datastream =(unsigned short int *)(DD_BASE + PLAYER1_DATASTREAM); unsigned char * const gMissile0Datastream =(unsigned char *)(DD_BASE + MISSILE0_DATASTREAM); unsigned char * const gMissile1Datastream =(unsigned char *)(DD_BASE + MISSILE1_DATASTREAM); unsigned char * const gBallDatastream =(unsigned char *)(DD_BASE + BALL_DATASTREAM); unsigned char * const gColorDatastream =(unsigned char *)(DD_BASE + COLOR_DATASTREAM); unsigned char * const gSizeDatastream =(unsigned char *)(DD_BASE + SIZE_DATASTREAM); unsigned char * const gScoreDatastream =(unsigned char *)(DD_BASE + SCORE_DATASTREAM); unsigned char * const gPlayfieldDatastream =(unsigned char *)(DD_BASE + PLAYFIELD_DATASTREAM); The C code can update the datastream by setting values like gPlayer0Datastream[0] = 1, gPlayer0Datastream[10]=5, and so on. The routine that updates the datastream to create the above display is this: void SetTestValues() { int i; // first 5 are the reposition scanlines, not used for gameplay for(i=0;i<5;i++) { gPlayer0Datastream[i] = 0xff; gPlayer1Datastream[i] = 0xff; gMissile0Datastream[i] = 0x0f; gMissile1Datastream[i] = 0x0f; gBallDatastream[i] = 0x0f; } // gameplay area is 160 scanlines for(i=5;i<DATASTREAM_SIZE;i++) { gPlayer0Datastream[i] = i-5; gPlayer1Datastream[i] = i-5; gMissile0Datastream[i] = (i-5) & 0x0f; gMissile1Datastream[i] = (i-5) & 0x0f; gBallDatastream[i] = (i-5) & 0x0f; } } The last thing your custom C code does is configure the BUS Stuffing Driver so it knows which of the 16 datatream is used for which TIA register(s). Yes, a single stream can be used by more than 1 register, it can also be used by RAM addresses. This is the C code which does that: void SetDatastreams() { // ; 0 = 6507 <--> ARM // ; 1 = GRP0 & HMP0 // ; 2 = GRP1 & HMP1 // ; 3 = ENAM0 & HMM0 // ; 4 = ENAM1 & HMM1 // ; 5 = ENABL & HMBL // ; 6 = COLUPx for player being repositioned // ; 7 = NUSIZx for player or missile being repositioned // ; 8 = NextKernel datastream // do a test to see if setPointer() is optimized away QPTR[1] = PLAYER0_DATASTREAM << 20; // GRP0 & HMP0 QPTR[2] = PLAYER1_DATASTREAM << 20; // GRP1 & HMP1 QPTR[3] = MISSILE0_DATASTREAM << 20; // ENAM0 & HMM0 QPTR[4] = MISSILE1_DATASTREAM << 20; // ENAM1 & HMM1 QPTR[5] = BALL_DATASTREAM << 20; // ENABL & HMBL QPTR[6] = COLOR_DATASTREAM << 20; // COLUP0, COLUP1 & COLUPF QPTR[7] = SIZE_DATASTREAM << 20; // NUSIZ0 & NUSIZ1 QPTR[8] = JUMP_DATASTREAM << 20; // ZP RAM NextKernel QPTR[9] = SCORE_DATASTREAM << 20; // Score/Radar/Lives/Formation display // do a test to see if setMapping() is optimized away QMAP[QUEUE_GRP0] = 0x11111111; QMAP[QUEUE_HMP0] = 0x11111111; QMAP[QUEUE_GRP1] = 0x22222222; QMAP[QUEUE_HMP1] = 0x22222222; QMAP[QUEUE_ENAM0] = 0x33333333; QMAP[QUEUE_HMM0] = 0x33333333; QMAP[QUEUE_ENAM1] = 0x44444444; QMAP[QUEUE_HMM1] = 0x44444444; QMAP[QUEUE_ENABL] = 0x55555555; QMAP[QUEUE_HMBL] = 0x55555555; QMAP[QUEUE_COLUP0] = 0x66666666; QMAP[QUEUE_COLUP1] = 0x66666666; QMAP[QUEUE_COLUPF] = 0x66666666; QMAP[COLOR & 0x3f] = 0x66666666; // ZP RAM 0x82 QMAP[QUEUE_NUSIZ0] = 0x77777777; QMAP[QUEUE_NUSIZ1] = 0x77777777; QMAP[SIZE & 0x3f] = 0x77777777; // ZP RAM 0x83 QMAP[NEXT_KERNEL & 0x3f] = 0x88888888; // ZP RAM 0x80 QMAP[QUEUE_PF0] = 0x99999999; QMAP[QUEUE_PF1] = 0x99999999; QMAP[QUEUE_PF2] = 0x99999999; // do a test to see if setIncrement() is optimized away QINC[0] = 0x100; // 1.0 QINC[1] = 0x100; // 1.0 GRP0 & HMP0 QINC[2] = 0x100; // 1.0 GRP1 & HMP1 QINC[3] = 0x80; // 0.5 ENAM0 & HMM0 QINC[4] = 0x80; // 0.5 ENAM1 & HMM1 QINC[5] = 0x80; // 0.5 ENABL & HMBL QINC[6] = 0x100; // 1.0 COLUP0, COLUP1 & COLUPF QINC[7] = 0x100; // 1.0 NUSIZ0 & NUSIZ1 QINC[8] = 0x100; // 1.0 NextKernel QINC[9] = 0x100; // 1.0 Score/Radar/Lives/Formation } The addresses are limited to $00-$24 for TIA and $80-$A4 for RAM. When BUS Stuffing is turned on, the BUS Driver monitors for the STY zero page instructions. When it sees one it uses the values in QMAP to figure out which datastream to pull the data from. That data is then stuffed onto the bus at the appropriate time. Finally the datastream is advanced by the increment amount. The ARM is timed to copy the registers (bus stuff) to the data bus when it intercepts the STY command. It does this continually so the game never rolls or bounces.It only intercepts the STY command when BUS Stuffing is turned on. Once your kernel is done you turn it off: ldx #$FF stx STUFFMODE ; non-zero turns off bus stuffing Then, like normal, the 6507 code takes care generating the sync signal at the appropriate time so the picture doesn't roll or bounce. The 6507 stores the Y register depending on what data was on the bus. Updating TIA and playfield and sprite information.The BUS Driver overrides the $FF value contained in the Y register when the 6507 goes to update the playfield (STY PF0, STY PF1, STY PF2) or sprite information (STY GRP0, STY COLUP0, STY NUSIZ0, etc). In this arrangement, the 6507 is really just a bus driver and the ARM does all the logic and memory manipulation. That's how you can program your game in C!The 6507 coordinates when and what to update. The ARM is the bus driver during the kernel. During overscan and vertical blank the 6507 will use the ARM as a co-processor for the game logic and memory manipulation, the ARM is not a bus driver during that time. This is just like your computer's CPU can offload calculations to your GPU. If your GPU is faster than your CPU at running certain routines then it makes sense to offload those routines to the GPU. The Harmony cartridge implementation differs in that it stores a compiled binary in flash. It watches the address lines and then fetches data from a flash location and outputs that on the data bus. Sort of like a normal cartridge but with the benefits of not having to program an EPROM.That's correct for the "ROM" emulation. In this implementation, how do you get input information from the Atari RIOT? You can write data to the Atari, but how do you read joysticks and paddles?The 6507 can write to the datastreams. In Draconian I have this datastream: ARMsub: ds 1 ; Which ARM subroutine to run: ; 0 = Initialize() ; 1 = OverScan() ; 2 = VerticalBlank() ; 3 = SetDatastreams() ARMswcha: ds 1 ; controller input to ARM ARMswchb: ds 1 ; console switches to ARM ARMinpt4: ds 1 ; left player firebutton ARMinpt5: ds 1 ; right player firebutton ARMvbtime: ds 1 ; time remaining in Vertical Blank ARMostime: ds 1 ; time remaining in Overscan ARMframe: ds 1 ; return value from call to OverScan which is used like this for the joystick, console switches, etc: ; prep for call to OverScan() ldx #>ARMsub ; 2 40 stx DS0PTR ldx #<ARMsub ; 2 30 stx DS0PTR ; 4 34 ldx #RUN_OS ; run = OverScan(); stx DS0WRITE ; 3 ; pass the PIA and TIA registers to the ARM code ldx SWCHA ; 4 stx DS0WRITE ; 4 ldx SWCHB ; 4 stx DS0WRITE ; 4 ldx INPT4 ; 3 stx DS0WRITE ; 4 ldx INPT5 stx DS0WRITE ldx VBtime stx DS0WRITE ldx OStime stx DS0WRITE ldx #$FF stx CALLFN ; tells the ARM code to run OverScan() lda DS0DATA sta Frame 3 Quote Link to comment Share on other sites More sharing options...
+SpiceWare Posted December 31, 2016 Author Share Posted December 31, 2016 The 7800's notorious for compatibility issues and my 7800 wouldn't run the Bus Stuffing demos. batari provided input on what he had to do with DPC+ to get it to work with 7800s like mine. Chris used that information and updated the Bus Driver. I built new versions of the RPG demo, which my 7800 can now run: rpg_20161231_NTSC.bin rpg_20161231_PAL.bin 4 Quote Link to comment Share on other sites More sharing options...
ZackAttack Posted December 31, 2016 Share Posted December 31, 2016 batari provided input on what he had to do with DPC+ to get it to work with 7800s like mine. Chris used that information and updated the Bus Driver.Is that information in the forum somewhere? Can it be? Quote Link to comment Share on other sites More sharing options...
+SpiceWare Posted December 31, 2016 Author Share Posted December 31, 2016 Is that information in the forum somewhere? Can it be? batari said it had to do with the evil 7800's pulling A12 low for part of a cycle, and if the ARM sees that it erroneously thinks the address changed. This bit of code in the bus driver: /* Wait for address change */ Transmit: ldrh r2, [r0, #+0x16] WaitAddressChange: ldrh r1, [r0, #+0x16] cmp r2, r1 beq WaitAddressChange was changed to this in order to ignore A12: /* Wait for address change */ Transmit: ldrh r2, [r0, #+0x16] mov r2, r2, asl #21 WaitAddressChange: ldrh r1, [r0, #+0x16] cmp r2, r1, asl #21 beq WaitAddressChange 1 Quote Link to comment Share on other sites More sharing options...
+SpiceWare Posted December 31, 2016 Author Share Posted December 31, 2016 The 18 color demos have been updated, they now work on my 7800. This took a lot longer than I expected due to the numerous changes we've made to the Bus Stuffing driver since August. parrot_20161231_NTSC.bin parrot_20161231_PAL.bin test_20161231.bin Quote Link to comment Share on other sites More sharing options...
ZackAttack Posted January 1, 2017 Share Posted January 1, 2017 Interesting, I didn't know that 7800s do that. That A12 behavior isn't limited to the 7800 though. I have a 2600 Jr. that does the same thing. Of course the 6502 datasheet agrees with this behavior since the address bus is only guaranteed to be valid at specific portions of each cycle. Sure would be nice if some of the control bus had made its way to the cartridge... Have you changed your mind about supporting quad-stuffing yet? Regarding PAL vs NSTC, can't you just time how long it takes to execute some arbitrary routine and load the appropriate driver accordingly? Quote Link to comment Share on other sites More sharing options...
Andromeda Stardust Posted January 1, 2017 Share Posted January 1, 2017 The 7800's notorious for compatibility issues and my 7800 wouldn't run the Bus Stuffing demos. batari provided input on what he had to do with DPC+ to get it to work with 7800s like mine. Chris used that information and updated the Bus Driver. I built new versions of the RPG demo, which my 7800 can now run: IMG_8182.jpg rpg_20161231_NTSC.bin rpg_20161231_PAL.bin Sweet. I gotta try these out... Quote Link to comment Share on other sites More sharing options...
+SpiceWare Posted January 1, 2017 Author Share Posted January 1, 2017 Sure would be nice if some of the control bus had made its way to the cartridge... Very true Have you changed your mind about supporting quad-stuffing yet? It's still on the back burner while we flesh out what we have working. Not much progress of late due to the holidays - Chris' driver update that fixed my 7800 was done back on the December 11th, and only now have I had the time to try it out. Quote Link to comment Share on other sites More sharing options...
+SpiceWare Posted January 1, 2017 Author Share Posted January 1, 2017 A few changes to the 128 Chronocolor demo: new Bus Driver in place so it now works on my 7800 now starts with 262 scanlines, so it should [initially] work on all displays without rolling If you hold down the firebutton the scanline count will change slower As before: Left Difficulty=A for PAL, B=NTSCNOTE: This is only checked during the init process, so you'll have to power-cycle the console to change between NTSC and PAL. change scanline count using joystick up/down 128chronocolour_20170101.bin Quote Link to comment Share on other sites More sharing options...
Thomas Jentzsch Posted January 1, 2017 Share Posted January 1, 2017 Doesn't show any colors on PAL (after both difficulty settings and with joystick corrections tried) Quote Link to comment Share on other sites More sharing options...
+SpiceWare Posted January 1, 2017 Author Share Posted January 1, 2017 Not sure what to think there, I'm definitely getting different color palettes based on the left difficulty switch: Quote Link to comment Share on other sites More sharing options...
Thomas Jentzsch Posted January 1, 2017 Share Posted January 1, 2017 I suppose we have odd scanline counts here. Quote Link to comment Share on other sites More sharing options...
+SpiceWare Posted January 1, 2017 Author Share Posted January 1, 2017 It's possible that VBs running a little longer than before as it creates the RGB picture on the fly and the picture now starts out 22 scanlines taller than before. Here's a quick test with an extra scanline output after VB ends: 128chronocolour_20170101b.bin If that fixes the problem then decreasing the screen size will cause the scanline count to become odd at some point, so I'll have to come up with a better solution. Quote Link to comment Share on other sites More sharing options...
Thomas Jentzsch Posted January 1, 2017 Share Posted January 1, 2017 Nope, no color here too. Quote Link to comment Share on other sites More sharing options...
+SpiceWare Posted January 1, 2017 Author Share Posted January 1, 2017 Hmm... Did the prior version work on your TV? Quote Link to comment Share on other sites More sharing options...
Thomas Jentzsch Posted January 1, 2017 Share Posted January 1, 2017 Never tried before. Answer: Nope. Quote Link to comment Share on other sites More sharing options...
+SpiceWare Posted January 2, 2017 Author Share Posted January 2, 2017 Changes for the 128 pixel demo: updated Bus Driver, now runs on my 7800. I'm hoping this fixes the extra vertical lines alex_79 was seeing updated kernel to support 2 HMP0 values instead of only $B0 migrated the auto-detect of HMP0 value needed for alex_79's systems removed the chronocolour demo added display of time remaining for Vertical Blank and Overscan to the 32 character demo. VB was out of time! optimized the reverse field routines to fix VB overrun Right Difficulty controls color of player0.128bus_20170102.bin 2 Quote Link to comment Share on other sites More sharing options...
alex_79 Posted January 9, 2017 Share Posted January 9, 2017 I finally tested the updated demos posted in the last couple of weeks on my 7800 and my Light Sixer.Unfortunately my 7800 still shows extra vertical lines. Apparently bus-stuffing doesn't work correctly on my machine and bit 7 on the data bus seems to always be set.rpg_20161231_PAL: 7800: 2600: -------------------------------------------------------parrot_20161231_PAL: 7800: 2600: --------------------------------------------------------test_20161231: 7800: 2600: --------------------------------------------------------128chronocolour_20170101: 7800: 2600: --------------------------------------------------------128chronocolour_20170101b: 7800: 2600 --------------------------------------------------------128bus_20170102:7800: 2600: Quote Link to comment Share on other sites More sharing options...
+SpiceWare Posted January 9, 2017 Author Share Posted January 9, 2017 Bummer, don't know what else could be going on. I'll drop a note to batari to see if he has any ideas. The auto-detect for the different HMM0 value appears to be working. Does the text demo still do the color change if you have the right difficulty set to B? I'm hoping the reverse field optimizations cleared that up. Quote Link to comment Share on other sites More sharing options...
alex_79 Posted January 9, 2017 Share Posted January 9, 2017 Does the text demo still do the color change if you have the right difficulty set to B? I'm hoping the reverse field optimizations cleared that up. Nope, it's fine with difficulty switch in both positions. (Old version showed the glitch with both settings) 1 Quote Link to comment Share on other sites More sharing options...
