Steve Mynott Posted November 5, 2016 Share Posted November 5, 2016 (edited) I was wondering how to do this. Probably something like http://www.atari8ethernet.com/(although very interesting and I wish them luck) isn't quite what I want but ideally just a serial type connection (maybe to a linux system on a wireless LAN) so I can telnet and run lynx for web browsing and kermit/xmodem for direct file transfer (ideally with VBXE 80 column support). A virtual R: might be nice. Is something like Lotharek's sio2pc usb best? I'd really like a wireless link but not sure if sio2bt is currently available? Any other suggestions? Of course seconds after posting I notice the RespeQt link which seems close to what I want .. but still not so sure about the actual connection options. Edited November 5, 2016 by Steve Mynott Quote Link to comment Share on other sites More sharing options...
vitoco Posted November 5, 2016 Share Posted November 5, 2016 SIO2BT has network support through it's related software. It uses SIO commands. Quote Link to comment Share on other sites More sharing options...
suspicious_milk Posted November 5, 2016 Share Posted November 5, 2016 I've used a Lantronix serial server, P:R:Connection combo ... kind of flaky Imo. Going to pick up a raspberry pi and check out RespeQT. As a bonus, the latest ARanym has a nice RPi build preconfigured with integrated Hatari to boot https://sites.google.com/site/emaappsarch/news/beekeyandbeepibeta9areavailable Can't wait to test this out Quote Link to comment Share on other sites More sharing options...
ricortes Posted November 6, 2016 Share Posted November 6, 2016 (edited) Never got to Atari with it, no time in the near future either. You may want to take a look at ESP8266. It isn't exactly ready for prime time with the Atari since it runs on 3.3V. It would as a minimum require a zener diode to drop the Atari 5V supply to 3.3V and one level translator chip like 74HTC244<?> or maybe a 4050. The ESP8266 is equivalent to a Hayes modem with an AT command set except for WiFi. With level translation it could possibly be used with RVerter drivers on the SIO buss. Flip levels with a 74HTC240 or 4049 and you could hang it off a joystick and use the MPP drivers. A link with some info. https://www.tindie.com/products/Bazinga/esp8266-esp-01-serial-port-wi-fi-module/?pt=full_prod_search Edited November 6, 2016 by ricortes Quote Link to comment Share on other sites More sharing options...
a8isa1 Posted November 9, 2016 Share Posted November 9, 2016 (edited) Never got to Atari with it, no time in the near future either. You may want to take a look at ESP8266. It isn't exactly ready for prime time with the Atari since it runs on 3.3V. It would as a minimum require a zener diode to drop the Atari 5V supply to 3.3V and one level translator chip like 74HTC244<?> or maybe a 4050. The ESP8266 is equivalent to a Hayes modem with an AT command set except for WiFi. With level translation it could possibly be used with RVerter drivers on the SIO buss. Flip levels with a 74HTC240 or 4049 and you could hang it off a joystick and use the MPP drivers. A link with some info. https://www.tindie.com/products/Bazinga/esp8266-esp-01-serial-port-wi-fi-module/?pt=full_prod_search Lately, I've been seeing these ESP8266 development boards with NodeMcu firmware (see this article of an early model). Looks like something fun to play with. At $6 to $9 USD (typical Ebay.com pricing) it's certainly cheap entertainment. Edited November 9, 2016 by a8isa1 Quote Link to comment Share on other sites More sharing options...
w1k Posted November 9, 2016 Share Posted November 9, 2016 im using kali linux.. can i connect with slip, etc? Quote Link to comment Share on other sites More sharing options...
Android8675 Posted November 11, 2016 Share Posted November 11, 2016 For internet I use a SIO2PC (Serial) with APE for Windows, load any terminal software and use ATDT commands with IP addresses to connect via Telnet. Favorite terminal program is probably Ice-XE. I've heard RespeQT (a fork of AspeQt) is supposed to be adding R: support which would allow the same thing, and I think it has a Linux build. Here's RespeQT on Github. 1 Quote Link to comment Share on other sites More sharing options...
Steve Mynott Posted November 26, 2016 Author Share Posted November 26, 2016 I got a SIO2BT and followed the instructions in this thread http://atariage.com/forums/topic/249426-sio2pi-atari-as-a-terminal-for-a-raspberry-pi-visiting-bbs/?do=findComment&comment=3446665in order to use ICET to access a Lubuntu laptop via RespeQT. Next I need to try the VBXE true 80 cols! 1 Quote Link to comment Share on other sites More sharing options...
Mechanicjay Posted November 27, 2016 Share Posted November 27, 2016 I run ICET or flickerterm over my 850 -> Lantronix UDS100 -> Some endpoint (BBS, Linux Box, etc). I'm able to run at 9600 baud with no issues at all. This has been pretty flawless. Quote Link to comment Share on other sites More sharing options...
