Atarikid96 Posted January 2, 2017 Share Posted January 2, 2017 Hi, I have an Intellivision model 1 that I'm having a problem with. The sound is barely audible on the tv, like really low. The thing is, if i push hard on the the RF cable on the back of the system, the sound gets louder. Does anyone have any idea what this could be before I take it apart? Any help would be much appreciated. Thanks! Quote Link to comment Share on other sites More sharing options...
+KylJoy Posted January 2, 2017 Share Posted January 2, 2017 Clean the connector on the unit and on the cable end first. I would use a high grit sandpaper to clean it, 1500 to 2000-ish. Some folks may be averse to sanding on their Intellivision components. You can find a solvent that will remove corrosion but the name escapes me right now. I would also try another cable. But I would also probably open the unit and re-solder the connector's solder joints. It might clean up and work fine without soldering. Good luck! Quote Link to comment Share on other sites More sharing options...
