Willard Posted May 8, 2003 Share Posted May 8, 2003 are they only protector SE and battlesphere gold, or are there more? Link to comment Share on other sites More sharing options...
Thunderbird Posted May 8, 2003 Share Posted May 8, 2003 are they only protector SE and battlesphere gold, or are there more? You can load a bypass program using the JUGS feature in the original BattleSphere. It's an extra step because you have to do the load into RAM every time you want to play a CD, but it does work. BattleSphere Gold has the bypass built in, so you need not load it manually. Just power on and go. Link to comment Share on other sites More sharing options...
Stone Posted May 8, 2003 Share Posted May 8, 2003 You can load a bypass program using the JUGS feature in the original BattleSphere. It's an extra step because you have to do the load into RAM every time you want to play a CD, but it does work. BattleSphere Gold has the bypass built in, so you need not load it manually. Just power on and go. Did you ever write a JUGS bypass? Just wondered...if not you can always use Symm's Stone Link to comment Share on other sites More sharing options...
jaysmith2000 Posted May 9, 2003 Share Posted May 9, 2003 are they only protector SE and battlesphere gold, or are there more? B&C also sells the CD Bypass by itself. If you have a FLASH cart you can load the bypass onto that or I can send you a copy of Battlesphere Gold ROM..... hahaha...Just kidding T-bird.... Jason Link to comment Share on other sites More sharing options...
t.skid Posted May 10, 2003 Share Posted May 10, 2003 Link to comment Share on other sites More sharing options...
Thunderbird Posted May 10, 2003 Share Posted May 10, 2003 Link to comment Share on other sites More sharing options...
Stone Posted May 10, 2003 Share Posted May 10, 2003 ...I can send you a copy of Battlesphere Gold ROM..... hahaha...Just kidding T-bird.... That reminds me, nobody's checked if BS(G) works on Virtual Jag yet Just kidding Stone Link to comment Share on other sites More sharing options...
Archived
This topic is now archived and is closed to further replies.
