RSS Bot Posted January 28, 2017 Share Posted January 28, 2017 First time I have ever taken a non-converting image, and fixed it, such that a suitable conversion is possible.Before I reduced the detail in "certain" areas, this is the best result. Note the terrible tell-tale "horizontal banding".Seeing that the image was struggling with two specific areas, I went in and removed most of the detail. Below will detail the before and after images. Reduce the image to indexed 8-bit colour, using an Atari palette file (in this case, I used the default palette from Atari 800 Win+). I chose to use no dithering at this stage I went in highly zoomed, and reduced problem areas down to basically 4 colours. This freed up additional colours for detail and completely eliminated any horizontal banding. Before:After:Here's the final conversion: Attached thumbnail(s) Attached File(s) Stephen_LaSexorcisto.xex (22.11KB)Number of downloads: 0 http://atariage.com/forums/blog/341/entry-13630-rasta-convertor/ Link to comment Share on other sites More sharing options...
